Genuine Ford Parts A forum for the purchase of genuine Ford parts via an AFF member. |
#2041 | |||
Suggest you try someone like Rocket Industries to see if there is an aftermarket equivalent through a brand like Fel Pro or the alike. Maybe contact Herrod Performance in Melbourne who worked on this things as well. |
#2042 | |||
More information required, GLi, Outback, XR etc? Even a VIN will help. GT |
#2043 | |||
FG 4.0 Air Cleaner Non Turbo.png |
#2044 | |||
It's for an NA FG Mk II xr6. Looking at the image you uploaded its 9B600 |
#2045 | ||
#2046 | ||
#2047 | ||
#2048 | ||
#2049 | |||
'97 XH Falcon Longreach
Hope that helps. |
#2050 | |||
EF9F715A is part number, will check later and get back to you. |
#2051 | ||
No luck on the EF9F715A, keep an eye out on the usual places.
#2052 | ||
#2053 | ||
Regular...with metamusal
![]() Join Date: Oct 2009
Hi Legend
![]() question today is - the 'egg crates' that support the front bumper, when did they change from the plain?. examples below ![]() the black lower pair are what i know/believe were standard on BA/BF, but i have NO idea what the white/black upper pair are off?. any chance you could explain what's the go is?. Thanks ![]() Ps.i believe the upper pair do not fit the later BF2 bumper. |
#2054 | |||
Here are the relavent part numbers: For BA BF XT, Futura, Fairmont, XR, Ghia, XL, XLT, RTV & All FPV BAF217D926A: RHS 7/2002-9/2005 BAF17D926A: RHS 10/2005- 9/2006 BAF217D927A: LHS 7/2002-9/2005 BAF17D927A: LHS 10/2005-9/2006 BAF217D926A: RHS 10/2006 on BAF217D927A: LHS 10/2006 on LWB Fairlane/LTD take the below for all: BAF217D926A: RHS BAF217D927A: LHS Hope that answers your question. |
2 users like this post: |
#2055 | |||
Thanks Legend, with that 09/2006 timeline is that roughly when they changed the front springs from the earlier BA shape?. best see IF i canna find some part numbers on em 'crates' ...... cheers |
#2056 | ||
The white I have is on the AU2, both front and rear.
#2057 | ||
#2058 | ||
Might not be identical but I do have those fitted at the back, that's what was seen when we took the rear bumper off and towbar, CS123 had seen them also.
#2059 | ||
Front spring change in BA seemed to happen around 7 or 8/2007 pending on model.
#2060 | ||
“Long shot” again.
The bulb holders for B-series cornering lights. Were they serviced individually as spare parts, or was a compatible bulb holder used elsewhere on same era Fords? |
