Go Back   Australian Ford Forums > The Sales Yard > Spare Parts and Other Accessory Items > Genuine Ford Parts
Genuine Ford Parts A forum for the purchase of genuine Ford parts via an AFF member.
Old 17-07-2024, 03:36 PM   #2041
GTLEGEND
Default Re: Genuine Ford Parts
Originally Posted by wickerd View Post
Hi.I’m looking for a vrs gasket set to suit Boss 260 32v (2004 BA xr8 Ute)… any suggestions ? . I know that cheap ones aren’t necessarily good and good ones aren’t necessarily cheap .. any suggestions or advice would greatly appreciated . cheers
There used to be a genuine VRS kit for the 260 Boss,part number BAFP6079B, how ever long obsolete.
Suggest you try someone like Rocket Industries to see if there is an aftermarket equivalent through a brand like Fel Pro or the alike.
Maybe contact Herrod Performance in Melbourne who worked on this things as well.
Old 17-07-2024, 03:53 PM   #2042
GTLEGEND
Originally Posted by Baminator View Post
Howdy GT,
This may be a bit of a Hail Mary, but I'm looking for an Idle Speed Controller for my 1997 XH Falcon 4ltr. Figured it couldn't hurt to ask if any Genuine Ford NOS is still floating about, and if you even just happened to know the Ford part # that would be fantastic.
Cheers,
the Baminator
Hi mate,
More information required, GLi, Outback, XR etc? Even a VIN will help.
GT
Old 17-07-2024, 05:53 PM   #2043
GTLEGEND
Originally Posted by fgpsi View Post
Hi , GTLEGEND
Do you have or do you know where I can get some fresh airbox torx screws for the FG Falcons. Also anyone know what size they are/ part number
Have a look below and advise which screw you are referring to. Note this is for 4.0L NA or Lpi, Turbo, V8 and earlier LPG vehicles have slightly different housings, which one are you referring to?
Old 17-07-2024, 06:35 PM   #2044
fgpsi
Attachment 107396
Thanks for the reply GTLEGEND
It's for an NA FG Mk II xr6. Looking at the image you uploaded its 9B600
fgpsi is offline   Reply With Quote Multi-Quote with this Post
Old 17-07-2024, 08:05 PM   #2045
GTLEGEND
Part number is BG9B600C, unfortunately obsolete.
Old 17-07-2024, 08:24 PM   #2046
fgpsi
Damn that sucks . Wonder what I could use instead
Old 17-07-2024, 09:09 PM   #2047
GTLEGEND
I would check out you local wreckes and get one from there, keep it all original..
Old 17-07-2024, 10:32 PM   #2048
gassa
Hi Mate
I think i have a few screws if needed
Gassa
gassa is offline   Reply With Quote Multi-Quote with this Post
Old 17-07-2024, 11:23 PM   #2049
Baminator
'97 XH Falcon Longreach
Hi mate,
GT
Yeah no worries didn't realise I'd left you high and dry for info. Just a plain old GLi running the log manifold. Not a BBM car sadly, although I thought all XH 4.0's had the same ISC?
Hope that helps.
Baminator is offline   Reply With Quote Multi-Quote with this Post
Old 18-07-2024, 07:46 AM   #2050
GTLEGEND
Hope that helps.
The 4L ISC are all the same, V8 is different, but there are different sections of the catalogue and just wanted to make sure I was on the right one.
EF9F715A is part number, will check later and get back to you.
Old 18-07-2024, 09:08 AM   #2051
GTLEGEND
No luck on the EF9F715A, keep an eye out on the usual places.
Old 18-07-2024, 07:44 PM   #2052
Baminator
All good, thanks heaps GT.
Old 19-07-2024, 06:45 PM   #2053
mad2
Regular...with metamusal
Hi Legend
question today is - the 'egg crates' that support the front bumper, when did they change from the plain?.
examples below
the black lower pair are what i know/believe were standard on BA/BF, but i have NO idea what the white/black upper pair are off?. any chance you could explain what's the go is?.
Thanks
Ps.i believe the upper pair do not fit the later BF2 bumper.
mad2 is online now   Reply With Quote Multi-Quote with this Post
Old 19-07-2024, 09:21 PM   #2054
GTLEGEND
Originally Posted by mad2 View Post
Hi Legend
examples below
Thanks
Hey mate,
Here are the relavent part numbers:
For BA BF XT, Futura, Fairmont, XR, Ghia, XL, XLT, RTV & All FPV
BAF217D926A: RHS 7/2002-9/2005
BAF17D926A: RHS 10/2005- 9/2006
BAF217D927A: LHS 7/2002-9/2005
BAF17D927A: LHS 10/2005-9/2006
BAF217D926A: RHS 10/2006 on
BAF217D927A: LHS 10/2006 on
LWB Fairlane/LTD take the below for all:
BAF217D926A: RHS
BAF217D927A: LHS
Hope that answers your question.
Old 20-07-2024, 07:52 AM   #2055
mad2
Hey mate,
BAF217D926A: RHS
BAF217D927A: LHS
Thanks Legend, with that 09/2006 timeline is that roughly when they changed the front springs from the earlier BA shape?.
best see IF i canna find some part numbers on em 'crates' ......
cheers
Old 20-07-2024, 09:54 AM   #2056
bondy99
The white I have is on the AU2, both front and rear.
bondy99 is offline   Reply With Quote Multi-Quote with this Post
Old 20-07-2024, 10:08 AM   #2057
mad2
the white shown is not the same as the one you have on the AU and is only fitted to the front.
Old 20-07-2024, 10:30 AM   #2058
bondy99
Might not be identical but I do have those fitted at the back, that's what was seen when we took the rear bumper off and towbar, CS123 had seen them also.
Old 20-07-2024, 04:51 PM   #2059
GTLEGEND
cheers
Front spring change in BA seemed to happen around 7 or 8/2007 pending on model.
Old 21-07-2024, 09:32 AM   #2060
“Long shot” again.
The bulb holders for B-series cornering lights. Were they serviced individually as spare parts, or was a compatible bulb holder used elsewhere on same era Fords?
Old 21-07-2024, 01:11 PM   #2061
GTLEGEND
Originally Posted by Citroënbender View Post
“Long shot” again.
For early B Series Ghia cornering lamps from 7/02 to 9/03, yes bulb holders were sold seperate, part number BA13411B. Vehicles built after this the bulb holder was part of the lamp..
Old 21-07-2024, 01:41 PM   #2062
Thank you. Looks like I have a hunt ahead of me, unless you know of a couple.
Old 22-07-2024, 08:06 AM   #2063
GTLEGEND
Globe holders or whole lamps?
Old 22-07-2024, 08:52 AM   #2064
mad2
either.
Old 22-07-2024, 08:54 AM   #2065
Just the holders, if you can please. The lamp bodies I have are reasonable, they look nicer than the blanking pieces so I might as well make them work.
Old 22-07-2024, 09:33 AM   #2066
GTLEGEND
I have these holders from cornering lamps and a set of good second hand lamps with holders too..
But for the life of me I cannot work out how to load a good picture on here, parts images seem ok as they are less than the size limit, but a picture goes over and don't load like the others do?
Old 22-07-2024, 10:47 AM   #2067
I trust your knowledge of the holders being the right part - no picture required. If you tell me “kemm” I can leave an envelope under the doormat for tomorrow.
Old 22-07-2024, 01:01 PM   #2068
GTLEGEND
Would rather send you a pic as the holder has wiring connectors adjoining it. Send me a PM with an email and ill send a pic..
Old 22-07-2024, 01:04 PM   #2069
mad2
is there enough holders to go around?.
Old 22-07-2024, 01:08 PM   #2070
GTLEGEND
I only have 2 holders, but they have wiring plug attached and then a set of lamps including holders as per image that Citroen posted below.
They extra holders with wiring were in the same box and the lamps but my memory is vague as to what they are off. Best to view somoehow. If someone can advise how to post images, I would try.
