My Fez is coming up to its 30k service. It says to change the pollen filter .
Cann't find it ? Where is it ? Thanks |
Quad Cam
Its behind the centre console. if you look in the passenger footwell there are a couple of screws to remove a part of the upper section near the heater core. The pollen filter then just slides out and you slide the new one right in.
#3 | |||
Quad Cam
Maybe I wasnt too clear with first description. If your car has air con then you've got one. You must remove the front part of the consol. 1 screw and some clips at the rear, then there are 4 torx scews to remove the cover for the pollen filter, then it slides right out and you slide the new one right in.
Ok , I have aircon, so, will let FORD do it. Don't have torx drivers.
Cheers |
