Old 17-01-2006, 02:49 PM   #1
TheSneakiness
Adapt or perish...
TheSneakiness's Avatar
Default PC fan is dead...
Hey ho.
I was wondering why my PC at work was running so friggin hot, found out why a few minutes ago.
The fan is dead.
Just got one question though...
What can happen if you leave it as is? (PC on, no fan)
Carless
Old 17-01-2006, 02:52 PM   #2
Casper
Contributing Member
Casper's Avatar
Depends on the chip you have and if you have throttling set to yes in your bios.
Best case... it throttles back to a very slow speed to stay cool enough, worst case... dead chip.
The heatsink will help a bit but, for an AMD, its a matter of time till it burns up.
Older, wiser, poorer.
Old 17-01-2006, 02:57 PM   #3
TheSneakiness
Adapt or perish...
I think it's a Celeron
Carless
Old 17-01-2006, 03:07 PM   #4
BlackLS
If work is paying for computers, do a few hardware benchmark tests, and turn off protection in the bios. Score a new computer or at least a new processor.
Id just spend the $2.50 and buy a new fan.
Old 17-01-2006, 03:26 PM   #5
Mack 6
SUMP PLUG
Mack 6's Avatar
Depending on the protection, it might just switch uff and not switch back on. I had a work hard drive which provided info to all (10) monitors in the shop. It kept switching off and the IT boffins wouldn't let me touch it. In the end I changed the fan after 2 weeks of waiting.
https://www.facebook.com/****boxmartini
https://****boxrally2015.everydayher.../martini-rally
Ford Courier XLT Crew Cab, 160rwkW+ AUII Forte Family Sedan is now the Race Car!!!
Mack 6 is offline   Reply With Quote Multi-Quote with this Post
Old 17-01-2006, 03:37 PM   #6
MITCHAY
I know when I was cleaning my computer and didn't replace the fan correctly, it would turn on and then turn off again to protect it. I would advise against running a computer without a fan though as I have noticed quite a decline in performance on a hot day with fans lol.
Old 17-01-2006, 03:49 PM   #7
Stampy
Why is everone thinking processer fan , to me it looks like the power supply fan ..LOL
Old 17-01-2006, 04:25 PM   #8
Rodp
Regular Schmuck
Rodp's Avatar
Originally Posted by AUII_SE_Ute
Hey ho.
The fan is dead.
Depends which fan and what kind of PC you have.
If it's a processor fan on a decent board it'll probably shut the PC down when the CPU temp threshold is exceeded.
If it's a general cooling fan, depends if there's any thermistors on the motherboard and whether a temp zone is exceeded.
Question is too ambiguous to give you a definitive answer.
Old 17-01-2006, 07:31 PM   #9
the_scotsman
MY21.5 Mustang GT
the_scotsman's Avatar
Yea, need to know which fan for sure...Im guessing a case fan? In which case, generally not a priority, but should be replaced since a new one costs bugger all.
If it was the CPU fan, I wouldnt turn it on!
Old 17-01-2006, 07:59 PM   #10
max^power
Formerly au^ute
max^power's Avatar
power supply fan, i'd say. thats gets alot hotter than the cpu. PSU on the other hand, gets boiling hot, and eventually goes POP
you'll need to let us know which fan it actually is.
max^power is offline   Reply With Quote Multi-Quote with this Post
