24-07-2005, 05:59 PM | #1 | ||
What tyre pressure should I run in my street tyres when I go the track?
http://members.optusnet.com.au/~two89w/mypic22.jpg |
24-07-2005, 06:40 PM | #2 | ||
DPC PERFORMANCE Race prep
Depends on what tyres you have, on a street tyre you would be safe with 36 psi as a base pressure do a couple of laps then come in and check pressure again while hot staying close to or under 40 psi this is for circuit racing
: : i will excell with the knowledge i get on here : : FPV & XR Owners Club of Victoria FPV & XR Owners Club of Victoria FPV & XR Owners Club of Victoria FPV & XR Owners Club of Victoria Ford Performance Car ClubFord Performance Car ClubFord Performance Car ClubFord Performance Car Club Last edited by GRNKPR; 24-07-2005 at 08:00 PM. |
24-07-2005, 07:13 PM | #3 | ||
NO CARBON TAX
take cheap pump with ya and drop to 20psi max. ideal about 15 imo
THE WORLDS FASTEST BISCANYE BLUE EB FALCON WITH EB BLOCK AND HEAD!!! NO AU **** THANKS Atomic performance engine, powerglide, coan converter, gtx55 turbo, 2000hp plazmaman water to air, 100mm throttle body, twin 50mm gates, side exit exhausts, 18 x 2200cc injectors, ems 8860 and race dash....... 7.83 @ 177 MPH 1100+ rwhp @ 40psi the first 7 second sohc ! eat it 1993 eb falcon 15.4 @ 90mph (tow car) |
24-07-2005, 08:29 PM | #4 | ||
It depends on whether your talking strip or track
24-07-2005, 08:35 PM | #5 | ||
also dont you spell tire as tyre
: : i will excell with the knowledge i get on here : : FPV & XR Owners Club of Victoria FPV & XR Owners Club of Victoria FPV & XR Owners Club of Victoria FPV & XR Owners Club of Victoria Ford Performance Car ClubFord Performance Car ClubFord Performance Car ClubFord Performance Car Club |
24-07-2005, 08:43 PM | #6 | |||
Boosted TQE FTW
Daily Driver: 08' ford ranger Project: EF Falcon Turbo... Not long till back on the road..... |
24-07-2005, 08:52 PM | #7 | |||
Good point. but I found it under new posts, not the drag racing section that's my excuse and i'm sticking to it |
24-07-2005, 08:56 PM | #8 | ||
Um strip out:
Couple of laps? : They are not great tyres (very hard compound) 235/60/15 hankook dynamic :
24-07-2005, 09:07 PM | #9 | ||
Everyone I've talked to has kept their street tyres at normal pressures...ie with 18's 38psi or so will be fine
Some people have tried lower psi's into the low 20's but it slows down mph and the harder sidewalls of street tyres wont expand out enough as per drag tyres to get the grip without losing roll |
25-07-2005, 10:15 AM | #10 | ||
Who's your Daddy now
If your going to run street tyers 25 is good if your wheel spinning drop them a bit more. wouldn't go lower than 20 though.
If they are a hard compound as u say do a nice burn out get them hot and sticky.
Powered by the twin screw from bluepower
Thats What I'm Talking About!!!! |
25-07-2005, 07:10 PM | #11 | |||
Now a FG XR8 in Nitro
I reckon you're right legend, the low pressures could be preventing these powerful cars getting higher speeds although they get a decent launch. I was with Chris and Wade last Wednesday night the WSID. Chris just had no grip where Wade did have. Wade got a great time in the end due to a good launch, his mph was down though. His tyre pressures were very low, if this was the reason for his lowish mph it would have also hindered his ET to a point. When I was karting we would run low pressures but was told that if they were too low it would prevent a higher speed at the end of the straight, thus more time was spent reaching that point. I suppose a little test would be to try and push you car yourself with different pressures, come to a compromise between pressure and effort to push. If you're finding it hard to push you car I'm thinking your engine would suffer as well somewhere in the equation.
Nitro XR8 6 Speed Manual - SS Inductions Growler, Herrod Headers John Bowe exhaust 0-60kph 2.46 secs |
25-07-2005, 07:17 PM | #12 | ||
Its yellow, NOT green!
I think it also depends how likely your car is to loose traction. With my stock EL XR8 its not worth lowering tyre pressures because I don't have enough power to have traction problems.
EL XR8 sedan - low & loud FG XR6 Turbo ute - Auto & Lux pack |
25-07-2005, 07:30 PM | #13 | ||
Normal tyre pressure it is! :eclipsee_
Thanks
25-07-2005, 07:57 PM | #14 | |||
26-07-2005, 06:35 PM | #15 | ||
Definately have high pressures in the front too, the less rolling resistance the better
27-07-2005, 11:28 AM | #16 | ||
X-Series Club Moderator
Surely the type of tyre would have a large bearing on the most appropriate pressure, along with power output etc.
I was recommended 18psi in 235/60/14's, and maybe lower! Seemed low to me, around 25 is what I would've expected as a good starting point. If I run my normal wheels (17's) on the strip, i would just use normal pressure!
PROJECT - '77 XC Falcon 351C - Click Here DAILY - '05 Ford Territory BIKE - '12 Suzuki GS 500 |
