Old 14-03-2015, 12:00 PM   #1
BA Ford Falcon
BA Ford Falcon's Avatar
Default Engine Conversion (Barra into Project Car)
Hey guys, looking at buying a project car very soon, really wanting a Barra probably a Barra 195 as i can get one for cheap of a mate, how would i go with ECU / Wiring? putting engine in is easy part but once i put it in it will have custom exhaust etc. what will happen to the ECU will it start? will it run on limp mode? ive only ever engine converted old v8's that dont have ECU nor a big wiring loom. hoping i can put it in a start the thing but i highly doubt it.
BA Ford Falcon is offline   Reply With Quote Multi-Quote with this Post
Old 14-03-2015, 02:38 PM   #2
Raptor
Raptor's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: For quietly going about moderating in a fair and even manner.
Default Re: Engine Conversion (Barra into Project Car)
Have a read of this, the guy is putting a turbo Barra into a 66 Mustang;
http://www.boostedford.com/#!car-wiring/c14z4
'93 XG Falcon Ute( sold ) : '94 ED Falcon Classic ( sold ) : '04 Territory SX TS ( sold ) : '04 Falcon RTV BAII ute (still in the family)
Raptor is offline   Reply With Quote Multi-Quote with this Post
Old 14-03-2015, 03:10 PM   #3
Sioso
irregular member
Sioso's Avatar
I hope you're putting it in a mk1 Escort...............
Sioso is offline   Reply With Quote Multi-Quote with this Post
Old 14-03-2015, 05:09 PM   #4
Xauterus
http://www.fordforums.com.au/showthread.php?t=11382891
Xauterus is offline   Reply With Quote Multi-Quote with this Post
Old 14-03-2015, 10:04 PM   #5
2011G6E
2011G6E's Avatar
Now that's a project I could really get into...after all, every man and his dog does the easy thing and just chucks a V8 in them. Nice to see something different for a change.
2011G6E is offline   Reply With Quote Multi-Quote with this Post
Old 15-03-2015, 07:54 PM   #6
Stefan
Stefan's Avatar
I've mentioned it a few times and struggle to understand why a 6T is not being slotted into loads of XYs or any other x series falcon.
If kits where available I'd do one tomorrow...unfortunately my pockets are not deep enough to allow me to do the first...
Stefan is offline   Reply With Quote Multi-Quote with this Post
Old 15-03-2015, 08:58 PM   #7
AussieCJ7
A Barra XR6T into a XM or XP coupe has been high on my list for a while but finding a decent coupe at reasonable $$$ is almost a dream now
AussieCJ7 is offline   Reply With Quote Multi-Quote with this Post
Old 16-03-2015, 11:14 AM   #8
XP6
Formerly ST170ish
XP6's Avatar
They dont fit in our earlybirds easily, on paper it sounds good... grab yourself a tape measure and you'll soon find out!
The engine will physically fit in the bay but will put the weight way too far forward, shocky towers and bracing will need to disappear... bonnet will have clearance issues.
To make it fit the motor will need to be set back into the firewall a good 100mm and still lose the towers and bracing, a IFS to get rid of the drag link... hello IVC rego!
Not saying it cant be done it can, but getting it passed for street use will be a PITA
My bad attitude escalates in direct proportion to the amount of stupidity I am presented with!!!
XP6 is offline   Reply With Quote Multi-Quote with this Post
Old 16-03-2015, 01:03 PM   #9
Vesper Martini
Vesper Martini's Avatar
Its a pretty big engine Physically, just look at the space taken up in that Mustang or even the XE falcon.
I guess it would depend on where it ends up
______________________________
2015 Territory Titanium RWD Diesel - SOLD
2016 BMW X5 xdrive 30D Msport
Seadoo Challenger 210SE 310HP
Vesper Martini is offline   Reply With Quote Multi-Quote with this Post
Old 16-03-2015, 03:37 PM   #10
Raptor
Raptor's Avatar
Originally Posted by Bevsta007 View Post
Its a pretty big engine Physically...
YUP!
See Barra vs Windsor below
Old 16-03-2015, 03:57 PM   #11
Franco Cozzo
Thailand Specials
Franco Cozzo's Avatar
How tall roughly is the Barra?
Old 16-03-2015, 09:39 PM   #12
malazn mafia
Boss 335
malazn mafia's Avatar
YUP!
Geez the Barra looks like a train engine and the Windsor looks like a 4cyl next to it..
malazn mafia is offline   Reply With Quote Multi-Quote with this Post
Old 16-03-2015, 09:59 PM   #13
XP6
Formerly ST170ish
XP6's Avatar
About 850ish cant remember exactly was long time ago, the rear of the motor is fine for height(minus the earlybird strut tower braces)its the front... Ford definitely shoe horned these puppys under the FG bonnet!
Old 21-03-2025, 05:47 AM   #14
Burningrubber92
So anyone able to give me a decent description of what wirings I have to splice in order to splice ba loom into EF gli falcon. Have looked over the diagrams of both EF and BA, to which I get lost and uncertain on what wires to go where if that makes sense
Burningrubber92 is offline   Reply With Quote Multi-Quote with this Post
Old 21-03-2025, 07:28 AM   #15
gmw67
If you are on facebook there are several Barra conversion pages and loom makers
gmw67 is offline   Reply With Quote Multi-Quote with this Post
Old 21-03-2025, 07:55 AM   #16
EBSXR6
EBSXR6's Avatar
Many years ago a mate put an Intech into an XY.
Changed the steering column and got the smart lock working.
Hooked it up to a close ratio Toploader.
One of the big headaches was the Intake manfold which had to be cut and welded.
EBSXR6 is online now   Reply With Quote Multi-Quote with this Post
Old 21-03-2025, 08:27 AM   #17
Burningrubber92
True that and have had no luck as no one wants to give me any advice on the looms as I eventually want to start making them for people but am stuck between an EF wiring color coded index from pin out 1 to 103 and a ba wiring color coded index from a BA 1 to however many.
The bit I’m struggling with is yeah I’ve matched up the injector wires from EF to BA
Example
Ef injector 1 pin out 75 (tan)
To splice to
BA injector 1 pin out A14 (brown)
EF injector 2 pin out 101 (White)
To splice to
BA injector 2 pin out A07 (White).
Am I doing it correctly or
