Old 01-04-2014, 11:18 AM   #1
Tonz
Default Exhaust bag jacks
my BF ute has a custom box on and when changing the rear tyres has to be jacked from front spring mount,, but if I had a flat tyre on the road the sizzor jack or even a bottle jack wont fit in there so Iam thinkibg a 4WD type exhaust jack and then a axle stand..... opinions please.
Dont p i s s off older people. At our age the term Life in Prison is not a deterrent
Tonz is offline   Reply With Quote Multi-Quote with this Post
Old 01-04-2014, 06:29 PM   #2
Bushbasher
When in doubt, GAS IT!!
Bushbasher's Avatar
Default Re: Exhaust bag jacks
They are brilliant for getting a vehicle up off the ground but you just need to be careful of the surface you put them on as they are pretty much a big a$$ balloon and any sharp object can potentially kill the bag.
MINE- AUII Forte
Old 01-04-2014, 08:56 PM   #3
GASWAGON
I think a 4wd jack would be better and cheaper.
GASWAGON is offline   Reply With Quote Multi-Quote with this Post
Old 02-04-2014, 01:52 PM   #4
ebxr8240
Performance moderator
ebxr8240's Avatar
Depends on area ?? Used exh jack with hay bails loaded.. No problem just DONT get under neath and use stands on front tyres .. Best on level ground ..
Daily driver GTE FG..
Old 02-04-2014, 02:46 PM   #5
Tonz
check out 4WD forums most guys can these as no where to safely lift your modern ute with these.
ebxr8240Re: Exhaust bag jacks
I never get under a vehicle for ANY reason
