does anyone know where a good place to get a large garden water tank [say around 10000ltr] in the ipswich area would be? my only concern would be the need to have it delivered and preferably dropped straight over the 6ft side fence.
any prices aswell.... thanks |
Falcon RTV - FG G6ET
![]() Join Date: Mar 2007
Brissie Road, just before the One Mile Bridge on the right as you head that way.
Forget the name of the joint, but you'll see where I mean.
BAII RTV - with Raptor V S/C. RTV Power FG G6ET 50th Anniversary in Sensation. While the basic Ford Six was code named Barra, the Turbo version clearly deserved its very own moniker – again enter Gordon Barfield.
We asked him if the engine had actually been called “Seagull” and how that came about. “Actually it was just call “Gull”, because I named it that. Because we knew it was going to poo on everything”. |
Where to next??
Would be easier if you could remove a section of the fence. When my parents got their 20kL tank delivered it was just rolled into position straight off the flatbed.
#4 | |||
Usually they just rolled of the truck as mentioned, lifting over a 6 foot fence youll need a crane or something,more costs,cheaper to drop a section of fence Dont forget youll need site work,clean area,bedding sand down,full itll weigh 10 tonne Also beyond the costs,youll need to check the area its goin, theres many various tank style now,its not as simple as a "10,000L tank thanks mate " Then there colours ect ect |
#5 | |||
Obsessed with wheels
#6 | |||
![]() Oh and I do have some double gates to access easily down the same side....but wasn't sure if the trucks they use tend to have cranes on them. I would have thought they would with the type of work they do ![]() ![]() Anyone used a pump off there tank to run anything but hoses...say washing machine or similar???? |
There's about four on the way out towards Gatton on the Warrego. There's one that stands out to me but I can't for the life of me remember the name of it, left hand side heading to Toowoomba...
----------------------------------------------------- 2012 Focus ST Tangerine Scream Continually having a battle of wits with unarmed opponents. Sez ![]() Photo's by Sez |
I've got approx 9Kl tank and I run a pump which does the watering system for the garden beds, front and back. It is plumbed in to the house in to the laundry, but the connection going from solid plastic pipe to the copper pipe in the house is a piece of garden hose and clamps. It leaks a little bit and I've been too lazy to fix it up, so we don't use it.
Cheers, Sam. |
#10 | |||
Where to next??
Also, regarding the bed you will sit this tank on. Make it as compacted and as solid as possible. When my parents showed me where they wanted the tank next to the house I constructed a box out of treated sleepers. Was then filled up with soil, watered and compacted (several times) to allow settlement and finally crushed rock / sand.
We positioned the tank, connected all the pipes and was great. It has now been around 5 years, the tank has sunk around 100mm, and the top of the tank is around 100mm away from the wall compared the the base. Over time, rain has removed material from the bedding material and the weight has also compacted it very well. Meaning that all attachments are now under stress. So, unless you are sitting the tank on a concrete slab that will never shift, make the pipes / hoses coming off the tank flexible, not solid and glued... I installed a PVC extension pipe to clear the sleepers to attach a hose, when the tank is empty it clears the timber by about 70mm, when it is full the base seems to flare out and we have already had to chisel out 1inch from the timber, same with the timber below the pipes attaching attaching the tank to our pump. My vote would be a slab, with a hard foam pad - like what they sell in camping stores for the base.
#12 | |||
Any pressure pump correctly fitted will run anything you like If you get a 2 or 3 way pressure pump, itll handle its required pressure for 2 or 3 outlets,pumps if not supplied will sting you ,oh around $200-$250 Ive got a 2 way on a 5,000L tank, run washing machine and gerni same time no probs A tank seller should recommend a required pump for your purpose, but go a touch bigger so later you can throw another outlet fitting or another hose on BUT remember ,if it leaks or you leave it on and it blows a fitting or hose, when the tank empties the pump doesnt turn off, if it runs for long with no water running threw it,itll burn out very quickly |
Isn't it obvious?
![]() Join Date: Nov 2009
yellow festie is on the money
build a little area ,we used quarry sand, and grab a few sleepers and some rapid set from bummings to hold it all in our 22.5 thou litre (which isnt hooked up yet) came on a flat bed and we just undid the straps and rolled it off then got me the misses and a mate to do the lift and roll around trick, move it about a meter each time till we got it in place if its being delivered, maybe look at not getting all the taps and holes cut now and wait till its off the truck and in position. but you will then need someone (or if u know what youre doing do it yourself) to drill the holes and hook it all up i was quoted 550 smackers just to come and hook the pump up plus the pump was around 600 it adds up quickly, unless you know someone curious on the price of the tank for the size you want think we paid around 1800 for a 22.5
08 Strike G6E T. 10 Ergo G6E Sept 75 XB Falcon in mushroom beige, 3 on the tree 200cid for sale, offers in the teens |
#14 | ||
thanks heaps guys. I will keep you updated with who what where and when we buy.
Ill deff be ussing crusher dust with quik set concete mixed and a gravel base. Done this in the past at work but never purchased for myself. (i even buried one under a cliets house down the coast...that was amaazing ![]() im keen on looking at a pump setup also for hoses to the garden, vegie patch, car gernie and maybe the washing machine. Sounds like a very good thing to get right and the overall rewards should be good....unless we keen this damn drought up..ta |
