Old 29-07-2012, 01:23 PM   #1
russellw
Chairman & Administrator
russellw's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: Raptor: For Continued, and prolonged service to the wider Ford Community
Default Coming soon to a vehicle we might get??
There have been some interesting features and functions added to recent US Ford models, some of which may well find their way here either in an imported model or as additional technology in our existing cars. Amongst them are:
Hands-free Tailgate (2013 Escape)
There's nothing like hands-free access when your hands are full. You can avoid going through the hassle of searching for keys or stopping to put your packages down. With the available hands-free liftgate and Intelligent Access key on you, just kick your foot under the bumper and the power liftgate can automatically open, providing easy access to the cargo area.
Intelligent Access Key (Focus, Fiesta, Escape etc.)
Intelligent Access with push-button start streamlines the whole process of opening the door to your vehicle and starting the ignition. Simply have the key fob in a pocket or purse, or anywhere else on you. Once inside, press the brake pedal, hit the start button and you're good to go.
Multi-contour Seats (Fusion)
Who hasn't felt achy and fatigued after sitting in a car for a long time? Now, with available multi-contour front seats with Active Motion®, you don't have to. This system helps reduce muscle-fatigue in your legs and lower back by using a subtle rolling-pattern massage. For added comfort, the driver can customise the seven air chambers in the seat back and seat bottom.
Active Grille Shutters (Escape, Focus, Taurus)
Active Grille Shutters close to reduce the aerodynamic drag on the vehicle caused by air travelling through the radiator. This results in increased fuel efficiency. The shutters open only when the engine needs cooling. When closed aerodynamic drag is reduced by approximately 6%.
Trailer Sway Control (Escape, Explorer)
Trailer sway control feature works with AdvanceTrac® with Roll Stability Control™ (RSC®), using the sensor that measures yaw motion to determine if the trailer is swaying. If necessary, trailer sway control applies precise asymmetric braking or adjusted engine torque to help bring both vehicle and trailer under control.
Blind Spot Monitoring System (Taurus, Explorer)
Ford offers cutting-edge technology in the available BLIS® (Blind Spot Information System) with cross-traffic alert to help make driving convenient. BLIS® is designed to use radar at the rear of the vehicle in the rear quarter panels to help detect a vehicle in a blind-spot zone. If a vehicle is detected, the system alerts you with a warning light in the appropriate side view mirror. Cross-traffic alert uses radar to detect vehicles approaching from the sides when you're slowly backing out of a parking spot or driveway. When it detects vehicles approaching from up to 45 feet away, it sends an audible warning and a visual display in the corresponding mirror and a signal in the message centre.
Inflatable Rear Saferty Belts (Explorer)
A world-first in safety and comfort.
Introducing the world's first automotive production inflatable rear outboard safety belts. They're the latest evolution in safety and comfort from Ford. In the event of a frontal or side crash, the inflated belt is designed to deploy in less than the blink of an eye. Its unique design helps distribute crash force energy across more of the occupant's torso than a traditional belt, which helps reduce the risk of injury while providing support for the head and neck. After deployment, the belt remains inflated for several seconds before dispersing its air through the pores in the air-bag. Inflatable safety belts are compatible with child safety seats. Because inflatable belts are not as large as traditional front air-bags, they can fill at a lower pressure and at a slower rate. Ford research showed that more than 90 percent of people who tested the inflatable safety belts found them to be similar or more comfortable than a conventional belt because the belts feel padded and softer.
Source: Ford Media
__________________________________________________
Observatio Facta Rotae
russellw is offline   Reply With Quote Multi-Quote with this Post
Old 29-07-2012, 01:33 PM   #2
Jason[98.EL]
Jason[98.EL]'s Avatar
Default Re: Coming soon to a vehicle we might get??
I know it more than likely wont happen but it would be great to see some of this find its way into the falcon even if it was just to see if aus were ready to get this stuff if the falcon does not go past 2016
would be very interesting to see what the aus pubic think of it
[SIGPIC][/SIGPIC]
Old 29-07-2012, 01:41 PM   #3
Moby Vic
Cynical Idealist
Moby Vic's Avatar
I test drove a Taurus SHO awhile back that had the Blind Spot Information System. Once I understood it, it was very useful, but if they would have designed the car without such a huge blind spot at the C pillar it wouldn't have been necessary.
All this high technology in new cars complicates them immensely, and quite often fails spectacularly. I prefer basic transportation with more-than-adequate power, but sadly I'm in a very small minority.
Your plastic pal who's fun to be with!
Moby Vic is offline   Reply With Quote Multi-Quote with this Post
Old 29-07-2012, 02:55 PM   #4
flooded one
yea all i care about is the car runs well and does the task required. it doesnt worry me too much if the car has fancy gizmos. I have a speed alert on both my AUs for example i very rarely use
flooded one is offline   Reply With Quote Multi-Quote with this Post
Old 29-07-2012, 08:15 PM   #5
Luke Plaizier
Lukeyson
Luke Plaizier's Avatar
Territory has Trailer Sway control doesn't it?
Lukeyson
If the human brain was simple enough to understand, we'd be too simple to understand it.
Luke Plaizier is offline   Reply With Quote Multi-Quote with this Post
Old 29-07-2012, 08:46 PM   #6
Pandemic
Pandemic's Avatar
Wow, they sound like some great features. Definitely would mind seeing them features in Australia.
Pandemic is offline   Reply With Quote Multi-Quote with this Post
Old 29-07-2012, 08:49 PM   #7
Polyal
The 'Stihl' Man
Polyal's Avatar
Hmm we are our own worst enemy when it comes to technology. Progression is great, but I feel the opposite happens for our responsibilities as a driver with additional "features".
  • 1973 ZF Ford Fairlane
Old 29-07-2012, 08:51 PM   #8
Nikked
Oo\===/oO
Nikked's Avatar
Falcon should get keyless start. Be a winner :-)
Check out my Photo-chop page
T...I...C...K...F...O...R...D
\≡≡T≡≡/
Nikked is offline   Reply With Quote Multi-Quote with this Post
Old 29-07-2012, 08:54 PM   #9
MWTB
I'm old and I fell
MWTB's Avatar
That blind spot thing would drive me bonkers. The way I read and understood it, it will sound a note every time a car comes within 45 feet in your blind spot?
BF2 XR6 turbo
82lb injectors, Walbro fuel pump, bigger cooler, Plazmaman piping, SS Growler, tune, ZF tune, Crow valve springs so far.
Ozracing coilovers, Pedders sway bars front and rear.
315rwkw
MWTB is offline   Reply With Quote Multi-Quote with this Post
Old 29-07-2012, 09:10 PM   #10
Road_Warrior
Pity the fool
Road_Warrior's Avatar
Lukeyson
No, Territory has Rollover Mitigation. Ranger has Trailer Sway Control which was developed into the vehicle by Ford Australia.
Active grille shutters already appeared here on the Fiesta Econetic but that model has been discontinued here. Expect to see BLIS, keyless entry and possibly adaptive headlamps for the E8 update in 2013/2014.
Fords I own or have owned:
1970 XW Falcon GT replica | 1970 XW Falcon | 1971 XY Fairmont | 1973 ZG Fairlane | 1986 XF Falcon panel van | 1987 XFII Falcon S-Pack | 1988 XF Falcon GLS ute | 1993 EBII Fairmont V8 | 1996 XG Falcon ute | 2000 AU Falcon wagon | 2004 BA Falcon XT | 2012 SZ Territory Titanium AWD
Proud to buy Australian and support Ford Australia through thick and thin
Road_Warrior is offline   Reply With Quote Multi-Quote with this Post
Old 29-07-2012, 09:38 PM   #11
Pandemic
Pandemic's Avatar
Think it's when the indicator has been turned on for whichever side.
Old 29-07-2012, 10:19 PM   #12
MWTB
I'm old and I fell
MWTB's Avatar
Ah. Makes much more sense then.
BF2 XR6 turbo
315rwkw
Old 29-07-2012, 10:19 PM   #13
flooded one
cars that can drive themselves would be pretty cool!!
Old 30-07-2012, 05:12 AM   #14
robertjp
as long as David Hasselhoff does not come along for the ride.
robertjp is offline   Reply With Quote Multi-Quote with this Post
Old 30-07-2012, 06:22 AM   #15
Bucknaked
Bucknaked's Avatar
We are planning on heading to the US next year. Hiring a car for a short period. Wouldn't mind trying the fusion if its a available.
FG2 XR6T
KIA Cerato
2022 Kawasaki Z900
Old 30-07-2012, 07:42 AM   #16
Luke Plaizier
Lukeyson
Ahh, yes, that's where I read it. Thx.
Lukeyson
Old 30-07-2012, 09:03 PM   #17
Buntz
Straight Eight
Buntz's Avatar
To me it's just technology to be integrated. Not that big a deal. Not hard or expensive. Perhaps it's not?
Anyway. What good are these tech parts if FoA don't tell people it's got them? Not that they're needed anyway in my opinion. It's just more gizmo's which differentiate models for consumers, and give people that western world one-up-manship where they can compare their standing in society with others by how much useless technology their car has that others don't.
Except for the Kick-Boot system. That is truly useful.
The Falcon is dead. Long live the Mighty Falcon.
Buntz is offline   Reply With Quote Multi-Quote with this Post
Old 30-07-2012, 11:17 PM   #18
dimka100
While all the above listed technology sounds awesome I have a simple question ... why does the Falcon not have a simple Auto window up/down functionality??? I mean seriously its stuff from the 80s ...
I think Ford needs to implement the basics into the Falcon first before try to cram some of the more fancy stuff ... front sensors would be good too ...
dimka100 is offline   Reply With Quote Multi-Quote with this Post
Old 30-07-2012, 11:20 PM   #19
Buntz
Straight Eight
Buntz's Avatar
Auto down since at least AU. But no auto up is annoying. And I've heard the complaints also.
It boils down to the boffins at Ford deeming in unnecessary. I guess you have to be at the brainstorming sessions at FoA skunk works to understand the logic behind it.
Old 31-07-2012, 07:47 AM   #20
2011G6E
2011G6E's Avatar
I feel bad for our G6E when I hop in a plain old base model Toyota Prado at work and realise it has auto up and down on all electric windows and keyless start (just the like the one described above where you unlock the car and then just have the fob anywhere...press the brake and push the button once and release and it starts).
Come on Ford Oz...a "premium" car deserves simple things like that which are standard fitment in even the cheapest and tinniest Korean and Indian made cars...
2011G6E is offline   Reply With Quote Multi-Quote with this Post
Old 31-07-2012, 08:18 AM   #21
Wretched
Render unto Caesar
Wretched's Avatar
If I'm going to buy a top of the range vehicle I expect to get what I pay for.
"Aliens might be surprised to learn that in a cosmos with limitless starlight, humans kill for energy sources buried in sand." - Neil deGrasse Tyson
Wretched is offline   Reply With Quote Multi-Quote with this Post
Old 31-07-2012, 08:25 AM   #22
MAGPIE
MAGPIE's Avatar
Is all this flash gear arriving before or after xenons for Falcons/Territory's
MAGPIE is offline   Reply With Quote Multi-Quote with this Post
Old 31-07-2012, 08:27 AM   #23
aussie muscle
aussie muscle's Avatar
needed because when you park front-in, someone in a big 4wd always parks next to you.
My ride: 2007 Falcon Ute BF XR8 Orange, MTO.
aussie muscle is offline   Reply With Quote Multi-Quote with this Post
Old 31-07-2012, 08:40 AM   #24
GK
Walking with God
GK's Avatar
There's certainly lots of great technology which has handy real-world application available in the Ford world.
I suspect that the first imported "Falcon" or whatever they call it will be packed with the stuff, just to ram home how wonderful the imported model will be.
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 31-07-2012, 08:51 AM   #25
Rodge
Rodge's Avatar
The multi contour seats in the Fusion sound great.
We know Ford Au have made an investment that will allow them to fit adaptive cruise and blind spot assist so it looks like that technology is coming to the 2014 Falcon, both of those things will be welcome updates.
Rodge is offline   Reply With Quote Multi-Quote with this Post
Old 31-07-2012, 09:21 AM   #26
Mad_Pom
Ford system already available on Mondeo in Australia. Just lights a LED in the wing mirror coressponding to the side of the vehicle that has a vehicle in your true blind spot - just behind your car.
Not intrusive at all and very useful.
Mad_Pom is offline   Reply With Quote Multi-Quote with this Post
Old 31-07-2012, 10:22 AM   #27
kaniSS
BIG MEMBER ;)
kaniSS's Avatar
Blind spot indicator hey? All I do is actually look at my blind spot before merging.
2010 FG XR6T, EGO, MANUAL, LUXURY PACK.
kaniSS is offline   Reply With Quote Multi-Quote with this Post
Old 31-07-2012, 04:06 PM   #28
Silver Ghia
Silver Ghia's Avatar
Isn't a blind spot where you can't see?
Intelligent access - thats something the FG Falcon should have had when the FG2 came or even earlier, would've helped sales.
Silver Ghia is offline   Reply With Quote Multi-Quote with this Post
Old 31-07-2012, 04:14 PM   #29
Smoke Pursuit
Ford Australia was working on a seatbelt airbag for Falcon / Territory.... Not sure where they got to with it.
2022 RAM Laramie 5.7
2023.50 Ranger Wildtrak 3.0 V6 Premium Pack
2024 Everest Sport 3.0 V6 Touring Pack
2025 Mustang Darkhorse 6M Blue Ember + Appearance pack ETA April 25.
Smoke Pursuit is offline   Reply With Quote Multi-Quote with this Post
Old 31-07-2012, 04:28 PM   #30
seedywagon
IWCMOGTVM club supporter
seedywagon's Avatar
Originally Posted by russellw
[COLOR=Blue]Inflatable Rear Saferty Belts (Explorer)
Every night I dream of my car having rear "saferty" belts!
2005 BAII Falcon XT "The Sextee" Winter White
Manual 5sp
K&N panel filter - XR6T Snorkel - F6 Typhoon CAI - BFXR6T 17inch Rims - RDA Slotted Rotors- Kings SL Front, SSL rear - XR shocks - Straight-through rear muffler - Blue Dash Conversion - Premium Sound Speakers - Colour-coded mirror scalps - 3.45:1 Diff Gears - Leather interior - Premium 6-stack colour ICC
FOR SALE - PM for details
Build Thread
seedywagon is offline   Reply With Quote Multi-Quote with this Post
