Old 01-06-2011, 09:07 PM   #1
randomperson
Default cooling
hi
i have a 250 pre crossflow and was wondering if it would be ok to put the garden hose in the bottom radiator hose to cool it while i have it running on a stand
thanks in advance
randomperson is offline   Reply With Quote Multi-Quote with this Post
Old 01-06-2011, 10:19 PM   #2
Geez Louise
Awesome
Geez Louise's Avatar
Location: In my own little world..Everyone here knows me :)
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: All the behind the scenes things that help the community.
Default Re: cooling
Hi randomperson. (nice username) and welcome to the forum.
That's one way of doing it. I have heard of people doing this in the past. Not sure if it will cause any damage or not. It should be okay if you are not going to run it for a long time.
Geez Louise is offline   Reply With Quote Multi-Quote with this Post
Old 01-06-2011, 10:36 PM   #3
RAREV8
Previously ScottishXC
RAREV8's Avatar
Default Re: cooling
The top hose might be better.....gravity might help but happy to be corrected.....it's worked for me in the past. Silly question but does the engine push the water up through the radiator?
Great transactions with the following members:
BJ
Gilesie
XAGTCoupe
Pilch
Aussie_afroman
Donut King
Bad Boy Benny
BAWITHLOT
Greenmachine
Pinkbits
CUZ351
OhioXB
Falconunbelievable
4VXC
Uncleraggy
FG G6 Ego, tech pack, Tropic gold 1973 Landau, Cosmic blue 1975 P5 LTD....long term project
Originally Posted by 4Vman
Im just bored of the single/narrow minded...
RAREV8 is offline   Reply With Quote Multi-Quote with this Post
Old 01-06-2011, 10:56 PM   #4
vanman_75
XD Sundowner
vanman_75's Avatar
Default Re: cooling
In the bottom will be fine. Run for as long as you like. Water goes back in top of radiator .
something old something blue
vanman_75 is offline   Reply With Quote Multi-Quote with this Post
Old 02-06-2011, 07:06 AM   #5
sudszy
Default Re: cooling
If there is no water pump connected it might be a good idea, but with the water pump connected you will be fighting the direction of flow.
The direction of flow is such due to thermal syphoning effect that was used in earlier cars that didnt have water pumps. It relies on hot water rising(inside) the engine block and cool water sinking(inside the radiator) to set up a flow. Hence why the radiators were typically long thin and vertical in older engines.
The vertical design continued over even when water pumps were fitted as it still aided circulation and the frontal design of cars still warranted a vertical flow radiator.
with cross flow radiators the effect of the cooling water in the radiator setting up a flow has gone, however, the effect of thermal syphoning in the engine block is still there, so the direction of flow has remained.
For the OP, yes, I think what you propose is okay, but have never tried it. One thing Id do is to position the inlet of the bottom radiator hose as high as possible and facing up, so that there is water lapping around the water pump, even make a near leak proof seal between your garden hose and the bottom hose.
sudszy is offline   Reply With Quote Multi-Quote with this Post
Old 06-06-2011, 07:35 PM   #6
randomperson
Default Re: cooling
thanks for the replies
i only want to start it to make sure it still runs and so that i can sell it as a runner.
