I am contemplating buying a QLD registered vehicle which has a mod plate, does this mean anything at all when i bring it into NSW registration?
Is it worth the metal tag it's stamped on? and Will the NSW boys in blue basically laugh at it, and then defect it? |
I was of the impression mod plates were nationally recognised but I could be wrong...(providing you have appropriate modification plates). You may be able to check the engineers work to see if they're nationally accredited...? To be honest, I really don't know, but....
This might be helpful for you... http://www.infrastructure.gov.au/roa...Jan2011_v2.pdf
----------------------------------------------------- 2012 Focus ST Tangerine Scream Continually having a battle of wits with unarmed opponents. Sez ![]() Photo's by Sez |
You would have to take the car to the RTA and get the car re engineered in NSW, as they have different regulations. In Victoria we do not have mod plates. Each state has it own rules and regulations to mods.
For example if I wanted to register a car in Victoria and it had been moded, I would have to goto a approved Vic Roads engineer. |
You have to go get a blue slip for the car when u rego it in NSW. Think you do nothing going the other way.
igodabigblackshinycar and I relented and allowed a BMW into the garage. ![]() |
#5 | |||
I think that other states accept approvals done in Queensland, provided that they have access to Qld Transport approval documentation. |
The mod plate should have some codes on it
Find out what the codes entail , then enquire in NSW as to whats required for these mods Alot of 4x4s approved in NSW will not ever pass in QLD Really depends whats been modded |
The car has a bolt in 4 point cage, is now a 2 seater instead of a 5 seater, and it has a turbo now. I won't know the codes until i look at the car, but just wanted to sus it all out first.
I was aware of the blue slip, which isn't a problem. Maybe i take the QLD reports to the RTA and get them to add it to their records. Thats how my NSW car is, on the rego it says "modified as per report number ......" and has a special code on the sticker too. It's not too attention grabbing, but it's just a random breath test where they might check it out, as it will be my daily driver. |
Not up to speed on the cage
Are they legal in QLD ??? The seating will defo be a mod plated for sure But a 5 seater to a 2 seater ??? The turbo as well could be an issue Now IF all the mods were done at the one place itll have only 1 mod plate On this plate will have what the codes are and the place that approoved them It will entail the place of business and their approoval number Get this info IF you can , then ring them and have a yack IF its got a multitude of mod plates scattered all over the engine bay (Yep each mod entails aprooval,and a mod plate,unless all done at once) Youll then have to contact all these places Its alot of rubbish to go threw , but id hate for you to buy then discover itll never be legal in NSW We dont have a uniform code of road laws/mods australia wide Each state is different |
#9 | |||
My ride: 2007 Falcon Ute BF XR8 Orange, MTO. |
#10 | |||
IF it has mods of sorts , these will need to checked before rego IE Some Road worthy blokes wont pass the car unless the mods are aprooved Even IF and when they mite turn a blind eye The car is your responsibilty IF you are busted with illlegal mods , you can and do get sent for a machinery I know a road worthy bloke who is a little leniant But he wouldnt pass a car because the rearward seat was removed,and the seating alteration wasnt aprooved (Was a 7 seater wagon back to a 5 seater) I either had to source the rear seat or get a mod plate for this before he would pass the road worthy |
Pro Street Au Ute
302xc a cage can be approved in qld if it's bolted in and meets other requirements like position in relation to occupants, padded where any contact can be made and intrusion bars must not be welded in and a few other things. The bolted in bit sucks i think because if you drag and run under 11s i think it is, the cage must be welded in so i'd like to know how people get around that.
