Old 14-12-2009, 10:24 PM   #1
escort mk2
Default Remote car starter
hi just want to know if anyone has installed a remote car starter, i have an xr6 turbo and thinking about putting one in if it is possible.
escort mk2 is offline   Reply With Quote Multi-Quote with this Post
Old 15-12-2009, 05:56 AM   #2
The Yeti
The Yeti's Avatar
had one on my work car they are great on really cold winters mornings when the ice is all over the car and you can kick it in the guts and have another coffee while you wait for it to de ice its self
Pariahs C.C.
What could possibly go wrong
I post images with postimg.cc (so I don’t forget)
The Yeti is offline   Reply With Quote Multi-Quote with this Post
Old 15-12-2009, 08:06 AM   #3
LTDHO
The one and only
LTDHO's Avatar
I have fitted alarms with the option but never enabled it.
Once saw an VK take of into a group of people when the owner hit start whilst it was in gear!
I'd never enable it.
Besides, there is no need for it.
Sure starting it before you get in on cold mornings is good to warm you and glaze your bores.
Tuned by CVE Performance
Old 15-12-2009, 11:03 AM   #4
Matty4
Banana
Matty4's Avatar
IIRC leaving a vehicle unattended whilst running is actually illegal. The same law applies to turbo timers.
Just found this, apparently turbo timers are not illegal in Vic anymore. This could also be applied to remote start too!!
http://www.vicroads.vic.gov.au/NR/rd...mes18234kb.pdf
2024 Ford Ranger Wildtrak V6 w/PP
2012 WK2 Jeep Grand Cherokee Overland CRD
Matty4 is offline   Reply With Quote Multi-Quote with this Post
Old 15-12-2009, 12:44 PM   #5
XplosiveR6
Viper FG XR6 Turbo
XplosiveR6's Avatar
And not to mention if your car gets stolen your insurence company will not pay out if you have a remote start fitted, may as well leave your keys inside the car.
XplosiveR6 is offline   Reply With Quote Multi-Quote with this Post
Old 15-12-2009, 01:33 PM   #6
swanee
spoolin!
swanee's Avatar
I think remote start vehicles only let enough fuel to the engine just for idling. I could be wrong.
But as mentioned... I thought remote start was illegal in Australia. A few Jap imports have this fitted to warm the car up on cold days etc.
Current Ride - 2016 FG-X Falcon XR6 Turbo Manual. Smoke Grey
Previous Rides - 2014 Black Mica PX XLT Ranger Dual Cab 3.2 Diesel
2011 FPV GS 315 Sedan. Sunburst, manual, fully optioned. Build #165.
My 1955 Ford Thunderbird Project (A tribute to my late mother) - 1955 Thunderbird Build Thread
swanee is offline   Reply With Quote Multi-Quote with this Post
Old 15-12-2009, 01:39 PM   #7
AndrewR_AUII
AndrewR_AUII's Avatar
Last time I checked the ADR's (Australian Design Rules for road vehicles) there was a stipulation that the car should not be able to run without a key in the ignition. There was exception for turbo timers on heavy vehicles.
Has this changed ? Don't know.
This is why both Turbo timers and remote starts are/were a no-no
That said, if you have one it has to be properly installed. i.e. is won't allow the engine to run unless park brake is applied and transmission is in Neutral/Park.
This stops it 'running away' and also stops somebody trying to make off with it: They put it in gear, engine stops.
AndrewR_AUII is offline   Reply With Quote Multi-Quote with this Post
Old 15-12-2009, 01:49 PM   #8
swanee
spoolin!
swanee's Avatar
Yeah that sounds about right. I just heard in passing conversation that remote starters were illegal.
Having a car running without the keys in the ignition is a defect. So what you have said sounds correct.
Old 15-12-2009, 02:15 PM   #9
JC807
sucksqueezebangblow
JC807's Avatar
i had installed one in my last car, which was part of an alarm system which had turbo timer and remote start. It was great, and they are foolproof if you wire them correctly.
Being manual, it would only allow remote start if the car had been shut down via the turbo timer (and so it would know it wasn't in gear, if the doors were opened anytime after this, it would self-disable the remote start option). I guess if you left your windows down and put it into gear by reaching through the window then there could be chaos but who leaves there car parked up with the windows open?
Also, if i remember correctly, if you dropped the handbrake without 'enabling' the key in the ignition it would cut the engine (to avoid driving without the key).
i say go for it, pretty easy to wire up if you follow the instructions. the instructions for mine were in terrible Chinglish and had to read them for ages to know what they were trying to say!
previous:-> 74 KE20 4AGTE, 04 RZN149R, 01 AE112R, 01 KR42R, 84 E30 318i, 67 MINI DELUX, 06 BF XR6T, 08 V50 T5 AWD , MY13 ISUZU D-MAX 4X4
current:-> 16 SS Sportwagon, 19 Everest BiTurbo 4WD
JC807 is offline   Reply With Quote Multi-Quote with this Post
Old 15-12-2009, 02:23 PM   #10
flappist
Well except for all the old falcons and holdens from the early 60s and before where you could remove the keys and stop start or drive the car from the "unlocked" position.
Like the "if it does not have seatbelts originally fitted you don't have to wear them" loophole, you will not get rolled but it is still a bit silly....
Old 29-12-2009, 09:56 PM   #11
escort mk2
Hi does anyone know wheather you have to bypass the smartshield so the remote starter can work
Old 29-12-2009, 11:20 PM   #12
irish2
What about new cars you start with a push of a button whilst the keys are within a certain range? There is no key in ignition possible. Does this flout the ADR?
irish2 is offline   Reply With Quote Multi-Quote with this Post
Old 29-12-2009, 11:25 PM   #13
Streets
Streets's Avatar
Never used one of them but I'd imagine you'd have to be pretty much inside the car for it to work.
Streets is offline   Reply With Quote Multi-Quote with this Post
Old 30-12-2009, 12:17 AM   #14
iliov
iliov's Avatar
I recal watching a top gear episode where they test this and the car and be driven about 50m from the keys.
iliov is offline   Reply With Quote Multi-Quote with this Post
Old 30-12-2009, 12:25 AM   #15
bigdude1011
bigdude1011's Avatar
I don't know, I know that Mercedes-Benz have been using a keyless start system for over 10 years (since the W220 S-Class's debut in 1999), and MB would not have included the feature in models headed to Australia if it was illegal.
bigdude1011 is offline   Reply With Quote Multi-Quote with this Post
Old 30-12-2009, 07:58 PM   #16
gumbs
I wouldn't bother with it. Its purely **** factor its just another thing to get defected on.
gumbs is offline   Reply With Quote Multi-Quote with this Post
Old 31-12-2009, 12:18 AM   #17
GoldCoastGTP
Luxo rocket
GoldCoastGTP's Avatar
We had 2 with the Aurion TRD's as our cars - the last ones before they ditched them and went back to the Commofalcons
We done a trick I unlocked the car after watching TG one night and a collegue got into it started it with the push button ond drove it away but it only went about 10 mtrs
2006 BF2 GTP in Vixen
GoldCoastGTP is offline   Reply With Quote Multi-Quote with this Post
