Old 06-11-2007, 02:29 AM   #1
big fella
big fella's Avatar
Default Insomnia; the brains way of showing the body who's boss
This is bloody ridiculous. Why is it that just when my body is crying out for sleep, my brain decides it is time to be wide awake and alert? I've battled this crap since I was about 15. I'm 32 now and I've tried it all. Pills will put me into a shallow sleep that lasts for 2 or 3 hours, then wake up again.
You know you're a lost cause when counting Sheep reminds you of your childhood watching "the count" on Sesame Street counting sheep, only to have your train of thought extend to 3 or 4 different areas at once; How long has Sesame Street been going? Does anyone know about Mr. Snuffelophogous other than Big Bird? If you were actually counting a flock of sheep, how could you mark them effectively so you don't count them twice, but not destroy their wool by painting a patch on their back? Who was the brain surgeon that came up with couting Sheep as a method for inducing sleep?
I'm off to try again, I might count components in a Clevo, or design a new transmission instead of counting sheep. There's no guarantee that my thoughts won't slide to the seedier, not quite right side about the little girl from "The Nanny", who is now the little slut from "Californication".
big fella is offline   Reply With Quote Multi-Quote with this Post
Old 06-11-2007, 02:40 AM   #2
Jeeepers
Merry Xmas To All
Jeeepers's Avatar
Listen to some Mantovani, try see genius in it. And you should be off to lala land in no time... LOL But yeah.... Insomnia is a biarch......
Jeeepers is offline   Reply With Quote Multi-Quote with this Post
Old 06-11-2007, 05:29 AM   #3
Fantome
Fantome's Avatar
I too suffer from insomnia at times. One of the tricks I use is to watch a DVD/video in bed. It must be a show that you have seen heaps of times but still enjoy and because you know the storyline you seem to drift into dreamland pretty quickly. Hope it helps.
Fantome is offline   Reply With Quote Multi-Quote with this Post
Old 06-11-2007, 09:06 PM   #4
DoreSlamR
Fiat POWAAH!
DoreSlamR's Avatar
thats a trick i do too, i usually stick on a favourite comedy like dumb and dumber, ace ventura, faulty towers or some monty python... why comedy? happy sleep is good sleep
works a treat
DoreSlamR is offline   Reply With Quote Multi-Quote with this Post
Old 06-11-2007, 09:09 PM   #5
Nostalgia
LOW AND SLOW
Nostalgia's Avatar
Insomnia has ruled me for too long also. I hope someone on here has a fair dinkum answer for it.
Nostalgia is offline   Reply With Quote Multi-Quote with this Post
Old 06-11-2007, 09:10 PM   #6
Outbackjack
Central to all beach's
Outbackjack's Avatar
Insomnia is the bain of my life.... I only ever sleep 4 hours at a time and then I am wide awake again.
Real Aussie muscle cars have a clutch!!
http://www.roadsense.com.au/about.html
Outbackjack is offline   Reply With Quote Multi-Quote with this Post
Old 06-11-2007, 09:15 PM   #7
Werd.
nou
If i sleep more than 5 hours I'm hell tired when i wake up...
Werd. is offline   Reply With Quote Multi-Quote with this Post
Old 06-11-2007, 09:15 PM   #8
steevo d
i knew how you felt when i quit the ciggies.
Zyban had a bad *** side effect of you fall asleep about
9:30, 10:00, the wake up about 1:30 with tinnitus screaming in both ears & being wide awake for hours. at first i'm sure i spent at least 2 weeks where i didn't go back into a deep sleep after 1:30
EB is good..
VB is better....... :
steevo d is offline   Reply With Quote Multi-Quote with this Post
Old 06-11-2007, 09:18 PM   #9
paule11
I used to have problems with Insomnia im still a light sleeper at times but if you get into meditation taichi qi gong type exercises you will sleep a lot better
paule11 is offline   Reply With Quote Multi-Quote with this Post
Old 06-11-2007, 09:26 PM   #10
SpoolMan
Solution Was Boost 4?, 6 & 8
SpoolMan's Avatar
Some of you may have sleep apnoea, your think your asleep but you really not, I once went for an over night assessment at the sleep apnoea unit at Austin Hospital my body was waking up every 40 seconds and I didn’t know it.
I thought I was sleeping this is why I would wake up with headaches and still feeling tired.
Sleep apnoea is common in over weight middle aged men.
[SIGPIC][/SIGPIC]
SpoolMan is offline   Reply With Quote Multi-Quote with this Post
Old 06-11-2007, 09:30 PM   #11
Nostalgia
LOW AND SLOW
Nostalgia's Avatar
From the sound of that it may also affect 32 year old men who weigh 52 kg.
Old 06-11-2007, 09:34 PM   #12
MITCHAY
Have a bit of beer. Always sorts me out pretty good ;)
Old 06-11-2007, 09:36 PM   #13
Fev
Fev's Avatar
unless you got insomnia from drugs, go buy a tenna, have a joint.. it will send you right to sleep
*disclaimer: I do not endorse drugs, i am just quoting from visual experience*
1992 EBII Fairmont Ghia 4.0l <---Click for the Gallery!
Insta@mooneye_ghia
White on bright red smoothies with thick whitewalls. Cruising around to some rockabilly
Fev is offline   Reply With Quote Multi-Quote with this Post
Old 06-11-2007, 09:36 PM   #14
Nostalgia
LOW AND SLOW
Nostalgia's Avatar
The ol amber fluid does nothing to help me sleep.
Old 06-11-2007, 09:40 PM   #15
steevo d
mightn't help me sleep but it apparently helps me snore.....
EB is good..
Old 06-11-2007, 09:47 PM   #16
Fev
Fev's Avatar
yeah beer makes me snore.. atleast my gf doesnt leave the room when i do though.. somehow she puts up with it, even when i punch her in mysleep or kick her, talk, fart or burp on her.. she's a good lass
Insta@mooneye_ghia
Old 06-11-2007, 11:58 PM   #17
Outbackjack
That is a fact confirmed by my doctor. Alcohol is a stimulant in small amounts and a depresant in larger quantities. But I still love it..... mmmmm Beeer
Old 07-11-2007, 12:37 AM   #18
capriv8
I do not suffer insomnia but I only require a few hours of sleep everynight to be able to function properly. The person that comes up with a soloution for everyone to not having to sleep for so long will be very rich, how much of peoples lives are wasted sleeping imagine what you can experience and achieve with another four hours a day or twenty eight hours a week . If you cant sleep maybe its your mind/body telling you its still ok to keep going.
capriv8 is offline   Reply With Quote Multi-Quote with this Post
Old 07-11-2007, 09:18 AM   #19
GS608
i dont know if i have insomnia, but most nights i find it hard to fall asleep as i cant stop thinking, one thought leads to another and it just keeps going in circles until i eventually just crash, but then i might randomly wake up at 5, still very very tired, fall back asleep wake up at 7.15 but still tired, as if i got no sleep at all, this doesnt seem normal for a 16 year old guy at all..
also if i try going to sleep earlier i just wake up earlier, dont get more sleep at all, and i have trouble sleeping in, unless i stay up till 2am
should i maybe go see someone about this? :s
Old 07-11-2007, 10:30 PM   #20
steevo d
ahh puberty.... don't we all wish we could do it all again??
yeah when i was a young bloke i could run on the smell of a beer coaster all night too!
EB is good..
Old 07-11-2007, 10:42 PM   #21
EA2BA
PM me if you want
EA2BA's Avatar
I am 36 and can run on very few hours sleep, I quite often feel better with less sleep, like 3 hours a night
When I do sleep I do not dream (well I am told I must but don't remember)
Old 08-11-2007, 11:15 AM   #22
SLO-04L
It Never Ends
SLO-04L's Avatar
i have a similar problem being a uni student and working in hospitality my days and nights just become a blurr some nights dont finish till 4 in the morning and then have to be up for uni in 5 hours but try getting straight to sleep when 10 minutes ago you had some drunk grandma yelling at you because their pokie machine hasn't payed out all day when she got there at 10:00 in the morning and pumped her entire pension through it.
with all the random start and finish times of uni and work not to mention the late nights finishing assigments and the stress that comes from that it is impossible to get a regular sleeping pattern down no two weeks are ever the same i quite often find myself driving around at 4-5-6-7 in the morning because i cant sleep
doctor has given me some tablets now that i use just when i NEED to get to sleep for something the next day and have been doing alot better since
SLO-04L is offline   Reply With Quote Multi-Quote with this Post
Old 08-11-2007, 12:53 PM   #23
Rob
Living the dream
I had problems sleeping in anything but my own bed, so the doctor gave me Stilnox........
This was probably 3 years ago - before Today Tonight jumped on the wagon and exposed the side effects.
I tell you what, some of the stories I heard about myself that I have absolutely no memory of..... scary stuff. Sleep drinking, sleep talking, breaking things, falling down stairs, trying to play computer games while asleep, incoherent speech and phone calls...
Careful what you take!
Rob is offline   Reply With Quote Multi-Quote with this Post
Old 08-11-2007, 03:32 PM   #24
XR06T
13.96 @ 101.65
i was exactly the same in high school and a couple of years after.. i just gave up trying to go to sleep at a reasonable hour. Loved it!! living off 5 hours sleep a night, uni, partying, working, good times.
get a good 10 hours once every 10 days and you were set!
BLUEPRINT XR6T
XR8 CAI - K&N Filter - T56 - Generic Tune
XR06T is offline   Reply With Quote Multi-Quote with this Post
Old 08-11-2007, 04:24 PM   #25
GS608
sounds good, i used to be up till 2am or around there..5 hours sleep and was fine, but after a while it start to get to me.
ah well
and now im trying to sleep at 11..doesnt work lol
Old 08-11-2007, 06:49 PM   #26
DDXR6T
DDXR6T's Avatar
Redbull gives me chronic insomnia. Multiple redbulls.
DDXR6T is offline   Reply With Quote Multi-Quote with this Post
Old 08-11-2007, 07:07 PM   #27
Van D
Van D's Avatar
I used to have real hard times getting to sleep, saw heaps of people, took drugs etc..
I now work 10 hour days, up at 5am, home at 5.30pm, by the time i've made dinner and worked out or jammed for a bit i'm out like a like light. A (that's one) beer or spliff also help.
Friend of mine used to be the same and we both changed habits and it's worked real well.
Seriously, if anyones having trouble sleeping on here and doesn't do these things.. Get outside more, do more exhausting things (even if it's sport, gym, going for a walk etc after work) during the day/evening, EAT/DRINK HEALTHY (don't drink coke/soft drink, red bulls, sugary drinks, caffeine etc, anywhere near bed time, or even at all, also stay off maccas etc as much as possible), spend as little time as possible in front of a TV/computer, especially before bed. I've been told staring at a computer screen before bed tricks the mind into thinking it's still daytime. I stopped and it helped me.
I find reading and listening to classical/technical music help me, as it exhausts my mind, and by the time I go to bed it doesn't want to think.
That's my 2c.
Originally Posted by irlewy86
Holden made the decision to make thier utes for pretty boys years ago. Wannabe tradesman drive them. If my son came home and told me he bought a holden ute I would struggle to come to grips with the fact he is a homosexual.
Van D is offline   Reply With Quote Multi-Quote with this Post
Old 09-11-2007, 12:16 AM   #28
NAPARM
I'm guessing not many of you "insomniacs" do much exercise. I normally seem to sleep better on nights that i go to the gym.
NAPARM is offline   Reply With Quote Multi-Quote with this Post
Old 09-11-2007, 12:29 AM   #29
[Tonko]
What's green is gold
[Tonko]'s Avatar
I have nights where my mind just wanders, around and around in circles, so i just chuck on a DVD that i've seen a million times, and imagine what they are doing while i listen, usually fall asleep within 10 minutes...
I cant sleep when the missus is here either, single for 3 years in a king size bed, then stuck with someone that "hogs" it... and wants to cuddle....
EF XR8 - Koni's - Cam and Headwork -3.9s - Ex VIC TMU -
1982 Nissan Patrol - 460 ci Big Block soon - Semi Gloss Black - Dark Tint - 4x 6" Infinity Kappa Perfect Splits - 5" Kappa 2 ways - Kappa 6x9's - 2x12" Kappa perfect subs - 2x4 Channel and 2x Mono Kappa amps-
[Tonko] is offline   Reply With Quote Multi-Quote with this Post
Old 09-11-2007, 06:39 AM   #30
Falc'man
You dig, we stick!
Falc'man's Avatar
They're your answers folks... its the thought of trying to stick to these that keeps me up at night.
"....You don't put the car through engineering" - Rod Barrett.
Falc'man is offline   Reply With Quote Multi-Quote with this Post
