Old 01-05-2007, 12:24 AM   #1
lbrst97
Default mazda 323 cluster fit on kf laser?
My 90 kf Laser didnt have a tacho instrument cluster. I tried to find a tx3 for a straight swap but had trouble finding one anywhere.
Anyways, since mazda 323 is practically same car, i bought a 91 323 tacho cluster hoping for staight swap.
It works and is ok except now the dash lights are on in the car constantly and dont turn off even when the key is not in the ignition, and the gear shift lights dont work. The only time the lights go off is when i take the room fuse out.
Obviously the wiring isnt right.
Is there a way to fix this?????
Thanks.
lbrst97 is offline   Reply With Quote Multi-Quote with this Post
Old 01-05-2007, 10:45 AM   #2
VippiN
What a performer!
VippiN's Avatar
No idea on how to fix your problem, but as you found out they can definately be swapped over.
I've got a 323 SS cluster in my TX3.
1981 Ford Laser KA :: E5 :: 2002-2003
1989 Ford Laser KE TX3 :: BP :: 2003-2007 75fwkW
1990 Ford Laser KF TX3 :: BP :: 2010-2011
1991 Ford Laser KF TX3 :: BP-T :: 2011-2015 109fwkW
2007 Ford Falcon BF XR6 Turbo Ute :: Barra 245T :: 2014-2019 324rwkW
1998 Ford Falcon AU XR8 Ute :: Windsor V8 :: 2019-2020
2008 Ford Fiesta XR4 :: Duratec 150 :: 2021-*
1998 Ford Falcon AU XR6 :: HP Intech :: 2021-*
VippiN is offline   Reply With Quote Multi-Quote with this Post
Old 03-05-2007, 01:13 AM   #3
lbrst97
Problem SOLVED!
Found some live wires contacting from where original stereo used to be. I assume the original stereo was powered up from original cluster unit causing the thing to play up.
Anyway, its all perfect now. 323 cluster looks much nicer than original. Was lucky, its got pretty low k's too!
THanks.
