Old 10-04-2007, 06:29 PM   #1
ef_classic
ef_classic's Avatar
Default Nulon engine oil flush.
Just wondering if anyone here has used this product and what were the results?
Thanks.
ef_classic is offline   Reply With Quote Multi-Quote with this Post
Old 10-04-2007, 06:33 PM   #2
GXL078
GXL078's Avatar
It makes your wallet lighter? I doubt there would be any NOTICABLE difference to your engine
GXL078 is offline   Reply With Quote Multi-Quote with this Post
Old 10-04-2007, 06:40 PM   #3
ltd
Force Fed Fords
ltd's Avatar
Ford use this in customers cars before servicing, it apparently helps to break down any sludge as well as remove varnish from the internals of the engine. I have used it personally and whilst not finding any difference in engine performance, have found that the engine oil is generally darker when it is drained. Only costs like $7.00 for the bottle so try it, just don't leave it in for too long.
If brains were gasoline, you wouldn't have enough to power an ants go-cart a half a lap around a Cheerio - Ron Shirley
Powered by GE
ltd is offline   Reply With Quote Multi-Quote with this Post
Old 10-04-2007, 07:01 PM   #4
vztrt
IWCMOGTVM Club Supporter
vztrt's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: vztrt is one of the most consistent and respected contributors to AFF, I have found his contributions are most useful to discussion as well as answering members queries.
You could just use diesel, gives the same result.
vztrt is offline   Reply With Quote Multi-Quote with this Post
Old 10-04-2007, 07:53 PM   #5
schmidty
schmidty's Avatar
I use it every service.
Notice a big difference in how clean the oil is after the first few hundred km when it picks up and mixes with whatever was left inside.
I used it in an el that had a couple of noisy lifters. Put the flush through, dropped the oil, filled with valvoline max life, another flush after a few hundred km, re filled with max life, silenced it nicely.
schmidty is offline   Reply With Quote Multi-Quote with this Post
Old 10-04-2007, 08:18 PM   #6
fairmont1998
fairmont1998's Avatar
I use it every service too. Helps clean the crap out of the motor. Can notice the new oil stays clean a while longer.
Current Rides:
2012 KK Jeep Cherokee Limited CRD - Still going strong
2019 MG ZS Essence
1988 RD Mitsubishi Colt GL - 59kW of Fury
2022 Kia Stinger GT
fairmont1998 is offline   Reply With Quote Multi-Quote with this Post
Old 10-04-2007, 09:36 PM   #7
chief
FTF Club Moderator
chief's Avatar
If you want to flush your motor you can drain the oil, keep the old filter put in kerosene with the new oil. Run car for 60 seconds turn off the car, drain oil and new filter and off you go.
The kerosene breaks down so much carbon it can be dangerous as it may block oil galleries, so I have heard.
Albert Einstein:
Fords in the Park 2010
Old 10-04-2007, 09:40 PM   #8
mrgo40rd
mrgo40rd's Avatar
save your money (x mechanic)
Proud owner 2006 bf xr6 turbo 13.7 QTR AT 103.86MPH AT WSID
Lowndes the real 2006 champion!
Member of 'Falcon Tickford FPV Club of NSW'
www.ftf.org.au
Nolathane, Whiteline and Whiteline PLUS enhanced
car care products 1300 006 007 (keep it looking clean)
mrgo40rd is offline   Reply With Quote Multi-Quote with this Post
Old 10-04-2007, 09:44 PM   #9
J.C.
Silly move. Kerosene has abrasive properties.
J.C. is offline   Reply With Quote Multi-Quote with this Post
Old 11-04-2007, 12:25 AM   #10
Wokkas
I don't think all the plain metal bearings would appreciate being run in kero for 60 seconds.
Wokkas is offline   Reply With Quote Multi-Quote with this Post
Old 11-04-2007, 01:29 AM   #11
SpoolMan
Solution Was Boost 4?, 6 & 8
SpoolMan's Avatar
Thanks.
Did you get some a free bottle with your Nulon oil purchase?
They have a promotion on at the moment buy any 5L Nulon oil pack get a free Nulon oil flush, I got some last week.
[SIGPIC][/SIGPIC]
SpoolMan is offline   Reply With Quote Multi-Quote with this Post
Old 11-04-2007, 09:34 AM   #12
njla
Thanks.
I used it for the first time in my clevo and ive noticed the oil seems cleaner, not as black. I guess it worked.
njla is offline   Reply With Quote Multi-Quote with this Post
Old 11-04-2007, 07:51 PM   #13
chief
FTF Club Moderator
chief's Avatar
Add a little bit of kero to the fresh oil. I did not say run on kero alone.
Albert Einstein:
Old 11-04-2007, 08:35 PM   #14
Sorted
OzEcruisers PRESIDENT
Sorted's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: For all the contributions you make to the AFF community.
Haven't used Nulon but i have Used MOTUL twice.
Also helps to clean most of your dirty oil out as it makes it thinner and easier to drop out........
Did my MOTUL Flush, engine oil & filter change over 100klms ago and oil is still clean not dirty black like it was when i dumped it :1syellow1
1994 Ford Fairmont EF NA 6cyl Man 3.9 diff Sedan
PROEF 13.46 @ 105.78mph
Tuned by DYNOMOTIVE
200BUX - AFF Drag Nats 2019 EF Wagon
Common knowledge that the more weight you take out of the car the less power you need to run the time.
Sorted is offline   Reply With Quote Multi-Quote with this Post
