DJR TM#54
Long nose plier might help.
When traveling to V8 Supercar rounds, i book through KYLEE MOLE Travel agents, She Goes, She Goes, She Goes & I just went. Now Zetec Powered. 1.6lt of madness. But the XR8 still remains ![]() |
tried it still tight even with two pairs of long nose
MR INCH
DJR TM#54
Try spraying some thing like WD40 on it?
That must be one stubborn fuse.
Walking with God
I've never known a fuse to be that stubborn. I wonder what's up here?
GK
Not sure which type of fuse you have, but some slow blow fuses are actually bolted in
![]() Join Date: Dec 2006
The ones under the dash should just pull out with the little plier tool provided
Some of the hi ampage ones in the fuse box under the engine are bolted in, a short 10mm bolt goes through the prongs of the fuse from memory You have to lever fuse panel out of the box part and you can then access the bolts, there are 3 or 4 points you must click out so you can lift the fuses up out of the box |
#8 | |||
KICK START
very helpful thank you guys, thought they may have been secured from below, can anyone tell me if they are a fuseable link type fuse or the same as the ignition fuse so i can have the right one when i pull the box out. thanks
