05-03-2007, 04:44 PM | #1 | ||
Hi People,
New to the post. My brake light above the rear windscreen has gone out. How you take it apart to replace the bulb? thanks for your help. |
05-03-2007, 06:38 PM | #2 | ||
GT4.
Erm there is no bulb.... Its an LED. That means that theres a wiring fault... Take it to ford.
06-03-2007, 02:37 PM | #3 | ||
ok thanks.
Will this be covered under warranty? |
06-03-2007, 05:11 PM | #4 | ||
It should be.
06-03-2007, 07:34 PM | #5 | ||
GT4.
It will be ;)
06-03-2007, 09:41 PM | #6 | ||
Clio 182 CUP!
Are you sure it's an LED in the Fiesta?...
------------- Steven 'In fact, so good is the Clio 182 with the Cup chassis set-up that I feel moved to make a bold statement - I think it's the best hot hatch ever built.' (EVO Jan 04) |
06-03-2007, 10:29 PM | #7 | ||
Non-Regular Member
Teki is right.
They arn't LED they are a 16watt wedge base bulb. "Open the tailgate and remove the rubber grommet. Depress the metal spring through the aperature using a flat-bladed screw driver. Unclip the light assembly. Unclip the bulb holder from the light assembly. Pull the bulb out and replace" *Page 135 of the manual
2005 Renault Sport Megane 225 |
