My sister and I recently drove over to armidale (about 3.5 hours away). The majority of the trip is just cruising, but about 30-45 minutes of the trip you go over a major hill. The car is a EB 6cyl, the auto has very smooth gear changes, like our BA, when manually changing gears its smooth and when cruising on the highway it kicks down a gear.
But when under load such as going up a hill it slows down and the only point the engine will rev is flat to the floor ( with 7/8 of the pedal distance doing nothing). Why don't these gearboxes like changing under load, a couple of my mates parents cars are like this too? You can feel the engine has power but it doesn't put it too the ground. We had a removal truck infront on the way back and it was only going 10 km/h down the hill. I had to put it back to first and ride the brakes which was weird lol!!
Now driving an unbreakable Hilux, which is becoming full of rust ![]() |
not sure..sorry
2000 AU Wagon |
XR6 Turbo FTW
Need a winsor 5 ltr
02 BA XR6 T U R B O - 232rwkw @ 6psi Blueprint, 19" FG2 XR6 Luxo Rims, Momo Steering Wheel, XR8 Bonnet Buldge, Full Leather, 3.7 Typhoon Diff Gears, Force Lip Spoiler, De-badged, Ghia Boot Garnish, Pedders Adjustable Coil- Overs And Camber Kit 96 EL XR6 - (Daily) Gunmetal Grey, 19" Typhoon Copies, Tickford Body Kit, Pedders Sports Ryders With Shortened Shocks And Camber Kit, Full S/S Difilipo Exhaust With Matching Extractors |
some very useful posts so far. Go Team! Are you sure your accelerator cable isn't faulty ? That would explain the kick down problem.
growing up is optional
Check the throttle cable for cracks, this normally happens where it passes over the rocker cover and may prevent you from getting full throttle.
My ED had a lousy kickdown IMO at highway speeds. To help this I used to engage power mode. Give it a try. |
Girls! Drink! ****! ****!
It is recommended to engage Power when; non-stop go-stop driving ie Taxi or Police car, towing or carrying a large load, overtaking and going up steep inclines.
Automatic Driver and I'd be proud of that fact, only if I weren't so lazy. 1993 ED Fairmont Sedan - I6 - Colbalt Blue - XH Snorkel - Superlow Kings Springs and KYB Shocks - Cross Drilled and Slotted DBA front Discs - 18" pre-AU GT-P Alloy Wheels - Ford Original Bootlid Spoiler |
There is some diagnostic stuff here if you want to look: http://autorepair.about.com/cs/troub...a072702a_3.htm
![]() Join Date: Oct 2006
How long since the bands have been adjusted?
regards Blue |
thanks guys, the next time I'm allowed near her car i'll check the cable.
I will kick down most of the time but not always. I think the box may only last a year or so, it has smooth changes though.
V8 Ute V8 Boat
mmm sounds like it needs a manual convertion, i think thats all you can do, mmm yes manual,
VE SS Ute manual 09 AU XR8 UTE 200KW manual 02 Challanger Ski boat V8 01 125 Thumpster 2010 Swag All set for the weekend |
Two > One
Run a KOER/KOEO test and pull the codes for the ECU, chances are your TPS may be out of range etc
#12 | |||
Parts bin special
Weekender 1964 US Falcon Futura convertible - Rangoon Red 260 Windsor V8, 4 speed manual, LHD, Electronic ignition, Mustang wheels https://fordforums.com.au/showthread.php?t=11470868 Daily 2014 SZII Territory diesel - basic runabout Previous Cars 1990 EAII Fairmont Ghia - Tickford engine, 5 speed, SVO wheels, bodykit, much more 2000 AUII Fairmont - XR wheels, Ghia interior 2010 FG XR50T ute - XR8 bonnet, Streetfighter intake |
Sometimes with electronic transmissions kickdown will happen sooner if you floor the pedal instantly or release then floor. Remember that you are talking to a computer and it is programmed to figure out what you want. A slowly heavier pedal just means you want to go faster (the computer will maintain that gear for economy) but a instant heavier pedal means you want power and give me the max....so she kicks back a gear.
Thats the way I see it. |
