12-01-2007, 03:03 AM | #1 | ||
Spr Jenkins
Ford be shamed, our latest 4 litre straight 6 puts out 185kw, the TVR Sagaris also is a 4 litre DOHC straight 6, however it puts out 298kw or 400hp. Not bad for a factory 4 litre. Although there are a lot worse engines about i.e. Dodge Viper V10, that is 8.3 litres and puts out a, wait for it, mind blowing 400hp. Although the Dodge has 630nm of torque to the TVR's 420nm, I've had a brilliant idea, why dont Dodge put two TVR engines together next time to make an 8 litre engine.
So here's my question, why don't australia/america make performance engines that are anywhere near as good as Japan and Europe? i'd really like to know? The only exception I can think of is the Holden 5 litre with the black head as found on the torana, which for its day was very powerful, am I wrong, can anyone think of another one? |
12-01-2007, 03:22 AM | #2 | ||
Are you serious mate, whats this crap about Ford should be ashamed about the inline 6 which is a great motor, looked after they will last for many many years with little problems other than a headgasket.
No point talking about the TVR Sagaris etc, totally different type of vehicle targeted for an exclusive market, cost in Australia estimated about $150,000 and I bet it won't last as long as Ford's 6. |
12-01-2007, 03:30 AM | #3 | ||
Where to next??
i thought it was 190kw but anyway.....
well the fact that it comes from a "performance factory" should be taken into consideration surely! however i was thinking similar lines.... there is a current Alfa model with a 3.2 litre GM based engine of the same family as the crapadore that puts out roughly the same power as the 3.6L so i guess engines for base models are kept at a low tune on purpose to allow for expansion and to make higher or performance models with better outputs based on the same engine. But at the same time im wondering where technology has gone, was there not a famous 1.6 "100kw" corolla engine some 10-15 years ago?? if thats correct why are the current crop of 1.8 litre engines making 100kw? perhaps engine technology through evolution allows them to be the high-po 140kw engines naturally but if they were all standard 140kw there would be minimal room for model advancement..... Well if you crunch the figures the way you did... 2x1.8L Corolla engines @ 140kw=280kw, not bad for 3.6 litres... torque is 360nm as well i think for the said 3.6L Another truly advanced engine is the honda S2000 engine... round 180kw from 2 litres... so then a 4 litre donk with the same wiz bang features should make 360kw?? yikes.... now THOSE are some figures! food for thought.... |
12-01-2007, 03:30 AM | #4 | ||
Churches Eat Souls
Remember, displacement isn't the only way to measure engine performace.
The 7.0 litre LS7 pushrod V8 engine from the newest z06 Corvette puts out 377KW from factory. The 5.0Litre DOHC V10 from the newest BMW M5 puts out 373KW. Sounds like the BMW has the Corvettes power-weight ratio thouroughly licked, doesn't it? However, the physical dimensions and weight of the 7.0 Litre are actually less than the 5.0L V-10. It has better fuel-economy and a much lower build cost to boot. Now... To the actual point... Have you read any reviews on or driven the new Aurion? 200KW from a smaller engine than the Falcon. But it's revvier, torque is higher up in the rev range. The Ford 4.0L is designed for torque and fuel-economy. It's what the Australian public want to drive. I don't want to have to kick down to second gear while I'm overtaking - I want to ride on the wave of low-down torque. Even Fords turbo six has oodles of torque, right from idle. The V8's really is the odd engine out. Much revvier. It's a Canadian engine if memory serves... Ford could easily make a high-power six to rival the Japanese and European peak-power outputs. They already have all the nessisary gear in the BF: - DOHC - Variable exhaust and intake timing - Plenty of displacement - Straight-six smoothness The only thing the 4.0L is lacking is direct injection and the stroke is a bit long. Mind you, with the new six-speed auto, Ford may be able to afford to push that torque band up a little... Yellow festiva: the old 4-AGE 1.6 was a real screamer, basically a race car engine (almost identical to the Ford Cosworth 1.6L racing engines of the same years.) 7,700 redline, DOHC, 4 or 5 ports per cylinder etc. However, the newer 1.8L toyota engines are much more of an economy-based engine, with drivability in mind. Sure you can have 100KW at 7,700RPM, but most people want 30KW at 1800RPM. |
12-01-2007, 04:36 AM | #5 | |||
12-01-2007, 05:17 AM | #6 | ||
The Falcon's inline 6 would produce well over 200kw with a higher rev ceiling.
12-01-2007, 05:38 AM | #7 | |||
LPG > You
Ok that's out of the way then. Moving right along... The Sagaris has a 4.0L Inline-Six with Dry Sump lubrication and I'll bet some high compression on it too, to make, according to TVR's own website, the following figures... 380bhp (284kW) @ 7000-7500rpm and 349ftlbs (473Nm) @ 5000rpm. It's rev limiter is set at 7800rpm. Comparatively, a Falcon 4.0 has Wet Sump lubrication and runs low compression, and makes the following figures... 190kW (255bhp) @ 5250rpm and 383Nm (283ftlbs) @ 2500rpm. The rev limit is 6000rpm like every BA/BF, bar the SOHC V8s. So then, we've got one engine with an expensive, highly strung setup, revving really high to make good power and one with a cheap, low stress setup revving low and making average power. Which one do you think is going to last a long time? Or more appropriately, which do you think is more appropriate for a 1.7 tonne family car? The one peaking torque at 2500rpm and carrying a fat curve throughout the rev range, right where its needed... or the one that needs to rev like mad to move, that propels a ~1000kg sports car? Different engines for different things. Falcon's do 1,000,000km as taxi's on the original engines. I'd love to see a Sagaris get to 1/4 of that without the whole thing imploding. It won't happen. If you want small engines from Ford with huge numbers... look at cars like the 1986 Ford RS200 Evo... 2.1litre Turbo 4cyl, 650bhp. That's 485kW, from a 2.1litre 4 cyl turbo. As for American engines, no comment. I don't like them very much and probably never will. Improving on them, sure, but otherwise... well, yeah.
LPG Lovers Association President & Member #1. : |
12-01-2007, 07:29 AM | #8 | |||
Or you could stop comparing a base model Falcon inline 6 to a high end supercar - how bout you actually compare Fords/FPV's performance marketed cars - the F6 is 270kw and wallops the TVR engine for torque yet is still half the price of the TVR and it could hose anything from Japan or Europe in that price range. I dont care if its blown its still a factory engine with warranty.
1966 Ford Mustang coupe. 347 stroker, PA reverse manual C4, TCE high stall converter, B&M Pro Ratchet, Edelbrock alum heads, Edelbrock intake manifold, MSD ignition, Holley Street HP 750 CFM carb, gilmer drive, wrapped Hooker Super Comp Headers, dual 3" straight through exhaust, Bilstein shocks, custom springs, full poly suspension, American Racing rims, Open Tracker roller spring saddles and shelby drop. Still to go - Holley Sniper EFI with integrated fuel cell. |
12-01-2007, 07:34 AM | #9 | |||
Yeah, yeah .. American engines (like Aussie designed counter parts) are all useless, big, fat, lazy engines aren't they; eg. Mopar 426 Hemi, Ford 429 SOHC, Chev LS6/7 454, Pontiac 421SD, etc, etc. That's why the smallblock Chev is still the most popular pseudo-performance engine in the world ... 'cos it's junk .. isn't it? ;) American engines were designed for American applications, which like it or not, tend to fit Australian applications too; simple design/construction, easy to repair, good performance for cost, can allow a family sedan a multifaceted role as people mover, tow vehicle and as some degree of performance. Australian FORD Forums is primarily about Fords and Ford - like it or not - is an American. I think they should be proud of that heritage ... if you don't like it, then maybe you need to think of buying European or Asian? |
12-01-2007, 09:17 AM | #10 | ||
Calm down OzJavelin,
While were slightly o/t the best thing about Aussie Fords is that they mate American style power and torque delivery with European style ride and handling. Best of both worlds
12-01-2007, 09:25 AM | #11 | ||
The head on the current Ford I6 is nothing special, but it doesn't need to be to satisfy Ford's customer requirements.
12-01-2007, 09:47 AM | #12 | ||
Formally Kia Chaser
Try towing 2400kg on a TVR....
Kia Grand Carnival (2006) Silver, Grill Mesh, Tints, Sidesteps (with lights), Towbar, 7" Touch Screen DVD Tuner with intergrated GPS & Bluetooth, Roof Mounted Flip Down 15.1" LCD Screen, Reverse Camera - 184Kw HSV Clubsport R8 VY (2003) Black, 6sp Manual, Coulson Seats, Red on black interior, Pacemaker extractors, Twin 2.5" exhaust, Custom Red 20" VE GTS Rims, Custom Red Stitching
12-01-2007, 10:54 AM | #13 | ||
re
Location: Victoria - where being slow & incompetent is considered being "safe"
One of the reasons for the S2000’s high output is it’s high rev limit. To get a Falcon 6 to rev to 9000ish rpm you’d want to look at the bore/stroke ratio and remember that you get parasitic losses when you increase the number of cylinders.
When you compare outputs of the S2000/Falcon 6 the Ford is only 55% of the Honda’s efficiency if you use kw/litre, if you calculate using BMEP the Falcon’s efficiency jumps to 77% of the S2000’s. You’re not really comparing apples with apples (or being fair to Ford) when you compare the two engines. P.S. TVR’s claimed power outputs have been “optimistic” in the past. P.P.S. Alan Melling (?) the original designer of the TVR straight 6 JAP (?) engine is getting his own car up and running – called the Hellcat.
Scuderia Rev: Otto the tow pig - 2007 3.0 litre Coupé, vernünftig schnelle aber kein peilstab, Bathurst 2007 und 2010 zwölf Stunde Gewinner Jaffa the angry ant - mid 70's Honda 市民の, 73 と立方インチ LSD Elle "the body" shell - early 70's Datsun フェアレディ coupe. いい体は彼女の内側、内側と土台を待つ |
12-01-2007, 11:08 AM | #14 | |||
Oops, I slipped....
1995 EF Fairmont 5.0 Heritage Green - BTR with TCI 2500 stall - Ported E7's - Pacemaker Tri-Y's - 3" Mandrel-bent Lukey Exhaust 1984 XE S-Pack 250 Sno White - LPG - Single Rail - 2.5" Exhaust "Just because you don't understand something, does not make it wrong" |
12-01-2007, 11:12 AM | #15 | ||
Bseries Moderator
i dont give a crap about our 4l vs theirs show us some in car videos of the beast!
Im just happy people around the world are using a 4L I6 i think its an awesome power output and should be admired not criticized. If you sleeve the 4L block and square up the bore stroke ratio or even understroke it you could rev it harder but will the displacement loss have a negative effect on power? How about boring it out to square up the bore stroke ratio. Not enough room id say but unless you had a custom block. Now lets compare this tvr engine to the almighty 265
Long Live the Rugerspeed Primer Destroyer! Only those that attempt the absurd achieve the impossible. Serviced and maintained by Mascot Auto Repairs
12-01-2007, 11:27 AM | #16 | |||
LPG > You
From a technical point of view, especially some more modern examples from GM and Dodge in paticular, there's not much to like. They're big, they're extremley thirsty and inefficient. With the odd exception like Ford's 5.0 'Cammer' engine, or the Dry-Sump 5.4 in the Ford GT etc. But then that's what I like. And in no way do I want to make anyone else like what I like, just a statement of opinion. There are alot of US engines I like, alot of them being in that group of famous old motors you posted up, and some newer slightly less known around here stuff, like the Buick LC2 V6 as a good example.
12-01-2007, 11:28 AM | #17 | ||
13.96 @ 101.65
dont forget about all that torque that the s2000 has!!!?!?!??
and torque is what feels better on the road.
BLUEPRINT XR6T XR8 CAI - K&N Filter - T56 - Generic Tune
12-01-2007, 11:31 AM | #18 | ||
Ex EL Falcon
I'd like to see a scaled-down version of the typhoon engine used in a small, light, RWD sports car but I doubt you will (or then, I might be talking out of my **** and its a bad idea).
Our Lady of Blessed Acceleration, don't fail us now! |
12-01-2007, 11:33 AM | #19 | |||
Formally Kia Chaser
12-01-2007, 11:35 AM | #20 | |||
Weezland
12-01-2007, 11:41 AM | #21 | ||
people need to relax, ours are based on family cars. The falcons are cheap and can be made into something special if wanted.
Now driving an unbreakable Hilux, which is becoming full of rust : |
12-01-2007, 11:57 AM | #22 | ||
Nothing wrong with the old 305s. Built for economy and durability. Compare that to the likes of Japan and Europe from the same era (hmmm ohv 4 cyl Corollas and Peugeots : ). Sure, the Euros probably make the best engines out there, but their dogs will easily out number their greats.
12-01-2007, 12:04 PM | #23 | |||
The original Viper back in 1992 has 400hp.
12-01-2007, 12:05 PM | #24 | ||
was danny888
http://www.youtube.com/watch?v=bhUecQLiIA8
this is what happened when Ford took on the world (1st minute or so anyway) The Falcon is a family car, simple try getting the kids to school in a TVR Sagaris |
12-01-2007, 12:13 PM | #25 | ||
American engines may not be high strung from the factory, but they have a massive aftermarket and adding HP costs next to nothing on just about any popular car. Euro cars are all high strung from the factory and nothing can be done aftermarket wise without spending massive dollars.
Sure the M5s engine makes similar power to the LS7 in the Z06. But add an exhaust and tune to the Z07 and it picks up 75hp, add a cam and they are well over 600hp and running 10sec quarters. In comparison for the same amount of money spent on an M5 would only buy you an exhaust and yield you 20hp if your lucky.
12-01-2007, 12:17 PM | #26 | |||
Mopar/No Car
I don't know, but I see a tear in the time-space continuum at the top of the screen... Seal it, Jethro! We're haemorraging credibility by the second!
ColumnShift Media '72 Plymouth Scamp '80 Courier '13 Kawasaki ZX14-R '13 Berlina '92 Suzuki DR650 If you don't fight - You lose
12-01-2007, 12:25 PM | #27 | |||
re
When comparing sports engines to production car engines you aren’t comparing apples with apples. Have a look at the work that Ferrari had to do to the 328(?)’s V8 to get it to work in the 4-door Lancia Thema 8.32 and I think that the turbo Thema was still quicker than it.
12-01-2007, 12:27 PM | #28 | |||
What's green is gold
EF XR8 - Koni's - Cam and Headwork -3.9s - Ex VIC TMU - 1982 Nissan Patrol - 460 ci Big Block soon - Semi Gloss Black - Dark Tint - 4x 6" Infinity Kappa Perfect Splits - 5" Kappa 2 ways - Kappa 6x9's - 2x12" Kappa perfect subs - 2x4 Channel and 2x Mono Kappa amps- |
12-01-2007, 12:36 PM | #29 | |||
I recommend you do a bit of research on engine design and application and you might just look back at you post and be a bit embarressed. A few pointers: How long is the engine designed to last? What are its operating environment parameters, e.g. temps, air pressure, purity, fuel variances, load variances, duty cycle. Production costs and tolerances? Role adaptability and potential to meet future standards. The Ford I6 is an extremely well designed engine and has proven so over that last 20 odd years by be operated by hundreds of thousands of people in some of the harshest environments on earth (Australia). N.B. Even e-mutants have difficulty in breaking them...... |
12-01-2007, 01:19 PM | #30 | ||
XP Coupe
Peak power figures are not a good indicator of performance. Not everyone wants to drive around at high revs.
