Old 08-01-2007, 07:59 PM   #1
MNM96
LIFELONG DJR SUPPORTER
MNM96's Avatar
Default New ISP?
Hey All,
I am considering upgrading to a new plan, or provider. I am currently on Bigpong with 400mb limit 512 down, 128 up. $39.95 I get insanely frustrated with Telstra, and the speed varies sooooooo bad. I normally use slightly over my limit, rarely more than 600mb. (but understand that speed will alter this)!
My question is, am I better off with a different plan, or provider.
If so, what plan, which provider?
Thanks and Cheers,
Mike
Old 08-01-2007, 08:17 PM   #2
peyote
Grandpa EF Wagon
try a search here http://bc.whirlpool.net.au/bc-plan.cfm
AAPT 512K Plus - Bundle $39 /mo 512/128 12GB Shaped
TPG Internet Light 512 $39.95 /mo 512/128 3GB Shaped
Internode HOME-512-Starter $39.95 /mo 512/128 8 GB Shaped
wade 1636 cam,wildcat X21 extractors,high flow cat&sports exhaust,tickford CAI,3" mandrel intake,AU XR 17s
slammed on superlows
peyote is offline   Reply With Quote Multi-Quote with this Post
Old 08-01-2007, 08:19 PM   #3
XRchic
Hello
XRchic's Avatar
Internode ADSL2 is great!
2008 FPV TERRITORY F6-X
Silhouette, window tint, roof racks, 3rd row seats, ROH Mantis 19s, black custom plates 'FPVF6X' and no stripes.
: Cobra :
XRchic is offline   Reply With Quote Multi-Quote with this Post
Old 08-01-2007, 08:20 PM   #4
MNM96
MNM96's Avatar
oops,please delete
Old 08-01-2007, 08:22 PM   #5
MNM96
MNM96's Avatar
What does 12gb Shaped mean? I understand 12 gig, but shaped?
While being much bigger limits, these plans are no faster, are they?
Cheers,
Mike
Old 08-01-2007, 08:26 PM   #6
tabletennisman
tabletennisman's Avatar
Cheers,
Mike
12GB shaped means that once 12gb is reached, speed is slowed to 64kbps.
For $49/month, AAPT now has 1500k with 15GB shaped which is pretty good...
tabletennisman is offline   Reply With Quote Multi-Quote with this Post
Old 08-01-2007, 09:46 PM   #7
robjh80
robjh80's Avatar
Internode = "The Best"
You will pay a bit more to set up as in getting a "modem/router" from them and paying a setup fee but after that it's all good news!!
Iv'e been with them now for approx 6 months, never known the connection to be down, always fast and reliable, lots of free content, all plans are shaped and reasonably priced.
http://www.internode.on.net/
robjh80 is offline   Reply With Quote Multi-Quote with this Post
Old 08-01-2007, 10:09 PM   #8
Hally
I am currently with AAPT on the 512/128/12g plan. To upgrade to the 1500/15g plan will I need a new ADSL modem?
Cheers,
Andrew
Hally is offline   Reply With Quote Multi-Quote with this Post
Old 08-01-2007, 10:13 PM   #9
the_scotsman
MY21.5 Mustang GT
the_scotsman's Avatar
Hally, you wont need to change modem, or anything else to upgrade to the 1500 plan.
Old 08-01-2007, 10:41 PM   #10
Hally
Thanks scotsman, I will give them a call tomorrow and see if I can upgrade.
Old 08-01-2007, 11:58 PM   #11
pauljh74
pauljh74's Avatar
Cheers,
Andrew
No, ADSL1 modems are capable of up to 8 Mbits/sec download and 1MBit/sec upload. At 512K/bits/sec or 1.5MBits/sec, it is doing it easy. You can use ADSL1 modems with an ADSL2+ connection, but you may limit your maximum speed. Most people would be very happy with 5MBits/sec or more.
To upgrade to 1.5MBits/sec, your ISP may charge you for a line speed upgrade, as Telstra will most likely do this procedure from the Telephone Exchange.
Originally Posted by Mark Webber
Not bad for a #2 driver
Mark Webber after winning the 2010 British Grand Prix.
pauljh74 is offline   Reply With Quote Multi-Quote with this Post
Old 09-01-2007, 12:01 AM   #12
pauljh74
pauljh74's Avatar
Hey All,
Thanks and Cheers,
Mike
Telstra is one of the worst value ISPs. As you have seen, you can get so much more for no extra from many ISPs - including very reputable ISPs. Internode's service is quite reliable and consistently fast.
Old 09-01-2007, 12:05 AM   #13
sgt_doofey
sgt_doofey's Avatar
Another vote for Internode here. You won't be disappointed if you go with them.
By the way, there are some new plans coming out on the 10th, so might want to hold off until then.
You only have to churn and you can use the Bigpond supplied modem, so the most it should cost is $39 to change to Internode.
If you are considering other providers, do check out www.whirlpool.net.au as there is stacks of information regarding broadband (and many other geeky computer things).
Cheers,
Sam.
Old 09-01-2007, 07:28 PM   #14
MNM96
MNM96's Avatar
Thanks All,
Internode ADSL2 looks good!
Another Dumb Q
Can I churn my email addy. Allbeit from @bigpond.net.au to @internode.com???? Whatever it will be?
cheers,
Mike
Old 09-01-2007, 07:55 PM   #15
FoxMulder
If you want faster connections, iiNet offers ADSL 2+ plans, that can give speeds up to 24000k (although you pretty much need to be next to the exchange for that speed).
You can check out their plans Here. They have a plan for $49.95, (+$9.95 VoIP) with 7+14GB (that is 7GB between 12pm and 2am [peak], and 14GB for the rest of the time [offpeak]) for a total of 21GB.
The biggest problem with the iiNet plans, is that there is no churn option, as they have layed out their own network of Dslams, as they try to separate themselves from telstra (as much as is humanly possible in Aus).
FoxMulder is offline   Reply With Quote Multi-Quote with this Post
Old 09-01-2007, 09:01 PM   #16
pauljh74
pauljh74's Avatar
If you're moving from ADSL1 to ADSL2, it may involve loss of internet for up to 2 weeks as they disconnect you from Telstra's ADSL1 network and then connect you to the ADSL2 DSLAM associated with your provider.
You can try and see if your username is available at your new ISP. What I do is use a gmail address. Gives you the option of accessing it on the web or downloading it to an email client like Outlook Express and storing it on your PC. If you change your ISP, your email address remains the same. Another option is to use something like gmail and set it to forward to your ISP hosted e-mail address.
Another option is to set up a domain for yourself. So you could see if the domain of DJRrules.com is available for example, then create e-mail addresses which will end in @DJRrules.com and it will bounce e-mails sent to that address to whatever e-mail address you specify.
Old 09-01-2007, 09:47 PM   #17
AU2PWR
Spin 'em Habib !
AU2PWR's Avatar
I Beleibe the Internet King Could Provide Faster Downloads
Whoa Captn Janeway !!
AU2PWR
AU2PWR is offline   Reply With Quote Multi-Quote with this Post
Old 09-01-2007, 10:32 PM   #18
brenx
brenx's Avatar
I've been on internode for 12+ mths now. It's far better than Telstra Cable and ADSL especially for reliability.
74 XB Fairmont (street car) 11.07@123.02mph. 08 LV Ford Focus XR5 (daily).
Tuned by Hallam Performance
brenx is offline   Reply With Quote Multi-Quote with this Post
