Old 18-12-2006, 07:19 PM   #1
FOCUSonTHIS
FOCUSonTHIS's Avatar
Default blocked washer jet
My right hand side washer jet is blocked, does anyone know how to fix this problem because I can't wash my windscreen when its dirty.
2015 MK7 VW GOLF GTI
Previous Cars
2002 AUIII XR6
1995 EF Falcon XR6
2003 LR Focus Zetec
1989 KE Laser TX3
Old 18-12-2006, 07:27 PM   #2
melbzetec
Old enough to know better
melbzetec's Avatar
Adam, try pushing a pin into the hole on the jet. If it is blocked there, that should clean it out
Old 18-12-2006, 07:33 PM   #3
FOCUSonTHIS
Thanks steve....its both little jets as well
Previous Cars
2002 AUIII XR6
1995 EF Falcon XR6
2003 LR Focus Zetec
1989 KE Laser TX3
Old 18-12-2006, 07:40 PM   #4
FOCUSonTHIS
broken washer jet from the inside....have to order a new on tomorrow i think
Previous Cars
2002 AUIII XR6
1995 EF Falcon XR6
2003 LR Focus Zetec
1989 KE Laser TX3
Old 18-12-2006, 07:48 PM   #5
melbzetec
melbzetec's Avatar
Did I bugger it up with my pin suggestion???
Old 18-12-2006, 07:50 PM   #6
eXtremist
2007 Ford Focus Zetec
eXtremist's Avatar
Doubt a pin would stuff it up.
You're meant to use a pin to adjust them.
eXtremist is offline   Reply With Quote Multi-Quote with this Post
Old 18-12-2006, 07:54 PM   #7
FOCUSonTHIS
no where the rubber hose connets to the plastic jet under the bonnet is broken and water just sprays on my engine. So i will fix it up. Don't know how to get the broke plastic that is stuck in the hose out....any suggestions
Previous Cars
2002 AUIII XR6
1995 EF Falcon XR6
2003 LR Focus Zetec
1989 KE Laser TX3
Old 19-12-2006, 01:03 AM   #8
amlohac
amlohac's Avatar
hahaha my old ute used to blow hoses off under there all the time.
amlohac is offline   Reply With Quote Multi-Quote with this Post
Old 19-12-2006, 09:18 AM   #9
FOCUSonTHIS
gees didn't think it was a laughing situation...lol
Previous Cars
2002 AUIII XR6
1995 EF Falcon XR6
2003 LR Focus Zetec
1989 KE Laser TX3
Old 19-12-2006, 01:55 PM   #10
FOCUSonTHIS
Well I bought the plastic elbow to replace the broke one. Only $2.25 so cheap and nasty. Still had trouble with the plastic in the rubber hose. So I crushed it with my hand and broke up the plastic and put washer on and the pressure of the water took all the bits of plastic out...great job by me once again
Previous Cars
2002 AUIII XR6
1995 EF Falcon XR6
2003 LR Focus Zetec
1989 KE Laser TX3
Old 19-12-2006, 02:01 PM   #11
melbzetec
melbzetec's Avatar
You never cease to amaze us all Adam!!!!!
Old 19-12-2006, 08:21 PM   #12
FOCUSonTHIS
I think you will amaze everyone at SFS next year Steve.....
Previous Cars
2002 AUIII XR6
1995 EF Falcon XR6
2003 LR Focus Zetec
1989 KE Laser TX3
Old 28-12-2006, 06:55 PM   #13
zetec
Zoom Zoom
zetec's Avatar
Jeez will you two get a room already?
2012 Mazda3 MPS
Old 06-01-2007, 09:04 AM   #14
Focussed
Focussed's Avatar
any reason howcome you didnt get it fixed under warranty?
Focussed is offline   Reply With Quote Multi-Quote with this Post
Old 06-01-2007, 10:47 AM   #15
FOCUSonTHIS
Because I have a 03 LR Focus and it is out of warranty.
Previous Cars
2002 AUIII XR6
1995 EF Falcon XR6
2003 LR Focus Zetec
1989 KE Laser TX3
Old 06-01-2007, 11:52 AM   #16
Focussed
Focussed's Avatar
ah yes, it is 2007! lol
Old 06-01-2007, 11:56 AM   #17
Piotr
Non-Regular Member
Does the warranty start counting from build date or delivery date?
Old 06-01-2007, 12:50 PM   #18
FOCUSonTHIS
Delivery date
Previous Cars
2002 AUIII XR6
1995 EF Falcon XR6
2003 LR Focus Zetec
1989 KE Laser TX3
