Old 27-11-2006, 08:02 PM   #1
luke24
au111 ute
Default hard starting when cold
i have a Au111 ute and lately it has been hard to start when it is cold
it turns over easy but sounds like it isnt getting any fuel, when it does fire it shudders a bit then runs ok. anyone got any ideas? i thought it might be the O2 sensor.
luke24 is offline   Reply With Quote Multi-Quote with this Post
Old 27-11-2006, 08:23 PM   #2
wesomc
wesomc's Avatar
not likely to be an oxy sensor as they don't aren't working at cold start. Fuel pump could be on the way out (pressure may be too low - does it seem to lack power an acceleration?). check/clean throttle body and IAC valve, there are many possibilities...
wesomc is offline   Reply With Quote Multi-Quote with this Post
Old 27-11-2006, 11:34 PM   #3
StealthAu
start simple, pulgs and leads.
Old 28-11-2006, 01:21 AM   #4
JC
JC's Avatar
Shuddering is a fuel/spark issue. I would start with stockau's suggestion, and then work back to fuel pump.
Ford Performance Club ACT
Old 28-11-2006, 07:26 PM   #5
luke24
au111 ute
cheers i'll take them out and have a look. i havent had the vehicle that long so the plugs might not have been changed since new.
Old 28-11-2006, 07:28 PM   #6
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
do you give it a bit of a boot when starting it? or do you just crank it and not touch the accellerator?
Old 29-11-2006, 09:28 PM   #7
luke24
au111 ute
i usually just crank it with out touching the accellerator, but if i give it a little it makes it a little better
