Old 17-11-2006, 02:55 PM   #1
xr8 007
xr8 007's Avatar
Default DVD burners
Hey all, I want to get a DVD burner but I don’t think my PC can handle it. Whats the minmium requirements for one?
Thanks a bunch,
Also where is the best and cheapest place to get one???Any recommendations for brands?
xr8 007 is offline   Reply With Quote Multi-Quote with this Post
Old 17-11-2006, 03:00 PM   #2
BlackLS
What is your current computer specs. Especially power supply, CPU and OS. It shouldn't use much more power than a standard CD burner. Any winXP computer should take it no worries.
Check out MSY.com.au, $44
Old 17-11-2006, 03:36 PM   #3
xr8 007
xr8 007's Avatar
Okies when i go home tonight I'll post up my specs. Yeah it does run XP and its a Pentium III, but not sure on the rest..
Old 17-11-2006, 05:53 PM   #4
sgt_doofey
sgt_doofey's Avatar
Should be right then. As long as you can burn CD's then you should be able to burn DVD's. Just make sure you have the necessary space on your hard drive to create a DVD.
Cheers,
Sam.
Old 17-11-2006, 07:42 PM   #5
S3SR
S3SR's Avatar
pretty much all they need are a decent cpu 333mhz? or up 64mb ram and few hundred mb's free.
there shouldnt be a prob if XP runs fine on your current machine as its min requirements are a little higher than that of a dvd burner
My Cars:
2002 Ford Falcon AU S3 SR
2006 BF MKI Falcon XR6
2008 Mazda BT50 SDX
2004 BA XR8 ute
2006 AUDI A4 B7
2013 FG II XR6 Ute
2006 Ford Territory TX
2003 Ford Falcon XR8
2009 Territory Turbo Ghia
Current: 2012 Audi A4 B8 2.0T Quattro
S3SR is offline   Reply With Quote Multi-Quote with this Post
Old 17-11-2006, 07:55 PM   #6
Jeeepers
Merry Xmas To All
Jeeepers's Avatar
To achieve the specified writing and reading performance it is important that the DVD Burner is connected to the IDE port via an 80 way ribbon cable and that the IDE port is at least UDMA 66 or above.
So if you get 16x burner, you will need to meet the above to burn to the specs of the used media, and have error free burns.
Jeeepers is offline   Reply With Quote Multi-Quote with this Post
Old 17-11-2006, 10:09 PM   #7
Full Spectrum
Only a matter of time.
Full Spectrum's Avatar
If XP runs on your PC then it's got enough go in it, XP min was slightly higher then all other OS's.
I would have said Pioneer make the best until my new one never worked from day 1. And they replaced it with a Samsung, It's good have no problems.
There that cheap now Dual layer burners you can grab them for $40 just about anywhere.
"SOUNDS THAT GO BUMP IN THE NIGHT"
Full Spectrum is offline   Reply With Quote Multi-Quote with this Post
Old 20-11-2006, 09:08 AM   #8
xr8 007
xr8 007's Avatar
cool, thanks guys. Will see how we go,
Old 28-12-2006, 11:20 AM   #9
xr8 007
xr8 007's Avatar
hey again, just about to buy a dvd burner, What should i look out for in a goog burner?
Old 28-12-2006, 12:30 PM   #10
Blue Ice
Living the Dream
Blue Ice's Avatar
http://www.atomicmpc.com.au/forums.asp?s=2&c=9&t=9764
Have a read through that, the guy who wrote it gets drives before they are released retail, puts them through their paces. I've had Pioneer drives since the 107D, been faultless since I brought them. Current one which is the DVR-111 is pretty damn good.
He also has a website dedicated to modified firmware for drives http://www.speedlabs.org
Edit: Dang site seems to be down :
Blue Ice is online now   Reply With Quote Multi-Quote with this Post
Old 28-12-2006, 12:41 PM   #11
Venomous
Might has well jump in here,
Don't want to high jack your thread but yeah.
I have a dvd burner:
Lite-On DVDRW SHW-1635S
And i can't burn cds off it, i can burn dvds
fine, but the cds just wont burn.
Any idea what would be preventing this?
Venomous is offline   Reply With Quote Multi-Quote with this Post
Old 28-12-2006, 12:46 PM   #12
Mental
Cam Luncheon
Mental's Avatar
Some DVD Lingo to take notice of when buying
R (writeable)
RW (re-writeable)
+, -, +/- (recordable format type, + or - or both +/-)
DL (Dual Layer)
And just because it says .. say 8x DVD burner, and then lists the formats its supports (DVD+/-R,+RW etc) doesn't mean its gunna burn DVD+R, DVD-R AND DVD+RW at the same speed, some to most of the DVD drives will have staggered speeds. Eg, 8x DVD+R, 6x DVD-R, 4x DVD+RW.
If you are going to be using DVD RW alot, not many drives support DVD+/-RW, they are usualy one OR the other, so keep that in mind.
Dual Layer is the next best recordable format out the atm, but its still rather expensive for the blank DVD's. Once again, getting both +/- Dual Layer is a wise investment.
With all that in mind, browse a few of your favourite online stores and check the options listed on the drives and make your mind there.
-- Any problem is best approached sideways ... with a crowbar --
-Mental on Life, the Universe and Everything.
Mental is offline   Reply With Quote Multi-Quote with this Post
Old 28-12-2006, 01:58 PM   #13
xr8 007
xr8 007's Avatar
So by the looks of things, I'm looking at getting a Dual Layer Dvd burner???
Thanks a bunch guys for all the info!!
What do they mean by +/-??
Old 28-12-2006, 02:12 PM   #14
M14A-Mclaren
Foo Fighter
M14A-Mclaren's Avatar
Check that it isn't made by Sony.
M14A-Mclaren is offline   Reply With Quote Multi-Quote with this Post
Old 28-12-2006, 02:58 PM   #15
robjh80
robjh80's Avatar
Iv'e got the "LiteOn SHM-165P6S04C" dual layer burner, works perfectly everytime, I use both "Nero 7" and "1 Click DVD copy", it's the 2nd LiteOn Iv'e owned and certainly wont be the last.
Regarding specs, reading the box the burner came in they state system requirements as being,
CPU: Pentium 4 1.3Ghz or higher
Operating System: Windows 98SE/ME/2000/XP
Memory: 128Mb or higher (256Mb recommended)
Hard Drive: 650Mb free for software installation, 9Gb space or higher required for creating a DVD image.
robjh80 is offline   Reply With Quote Multi-Quote with this Post
Old 28-12-2006, 03:03 PM   #16
Mental
Cam Luncheon
Mental's Avatar
There 2 different DVD formats. For arguments sake, a DVD is still a DVD, its how the data is put onto the DVD that makes it a + or a -. As such you can buy blank DVD+R's and DVD-R's. So getting a burner that is DVD+/-R means it can burn to both standards, not just one.
And yes, buy a Dual Layer, it's the next step -short term- in DVD evolution. Long Term is HD-DVD (High Definition) and Blu-Ray .... >>Here's<< Something to make you cringe
Old 28-12-2006, 05:12 PM   #17
Blue Ice
Living the Dream
Blue Ice's Avatar
http://forums.speedlabs.org/index.php
Lucky it was only the index page. That link there takes you to the good stuff
