Old 30-10-2006, 08:51 AM   #1
mintomax
Question 86 KC Engine
need some advice, have been offered a 2nd hand engine from a Telstar with a 5sp gearbox, no sure of the year atm, any one know if it will fit in a 86 KC laser..??
mainly worried about it fitting to the engine mounts and that the gearbox will fit with out any modifications..
any help or advice would be great..
mintomax is offline   Reply With Quote Multi-Quote with this Post
Old 30-10-2006, 10:01 AM   #2
smally289
growing up is optional
smally289's Avatar
Wont drop straight in. It may be possible with some mucking around, but these jobs always turn out harder than they first look!
smally289 is offline   Reply With Quote Multi-Quote with this Post
Old 30-10-2006, 12:13 PM   #3
VippiN
What a performer!
VippiN's Avatar
Smally351 is right on the money. There is no point putting a Telstar engine in your KC when the B6 engines cost pittens ($200ish) and do not require modification.
People forget that it's not just fitting an engine. You then have to get *every* thing to match up, and then the real *****, the wiring.
1981 Ford Laser KA :: E5 :: 2002-2003
1989 Ford Laser KE TX3 :: BP :: 2003-2007 75fwkW
1990 Ford Laser KF TX3 :: BP :: 2010-2011
1991 Ford Laser KF TX3 :: BP-T :: 2011-2015 109fwkW
2007 Ford Falcon BF XR6 Turbo Ute :: Barra 245T :: 2014-2019 324rwkW
1998 Ford Falcon AU XR8 Ute :: Windsor V8 :: 2019-2020
2008 Ford Fiesta XR4 :: Duratec 150 :: 2021-*
1998 Ford Falcon AU XR6 :: HP Intech :: 2021-*
VippiN is offline   Reply With Quote Multi-Quote with this Post
Old 31-10-2006, 08:58 PM   #4
mintomax
Yeah thats kinda helpful, thanks guys..
I realise that the engines cost bugga all, this one is free and upgrading to a 5sp rather than the 4 is an added bonus, I really just don't wanna pull it all apart and find that its gonna be one of those 6wk nightmares to get back together.. haha
Old 31-10-2006, 09:48 PM   #5
VippiN
What a performer!
VippiN's Avatar
My spider sense is telling me.. The word customised will used a lot if you go through with this.
Old 04-11-2006, 09:08 PM   #6
mintomax
ok VippiN, what does your spider sense say about a Meteor engine..
I made a bit of a stuff up, it was never a bloody Telstar motor, brain couldn't remember that it was actually a Meteor engine..
I want to replace the 1.3 4sp Laser engine with a 1.5 Meteor 5sp engine..
Will this work, without *too many* customised/modified accessories..??
Old 04-11-2006, 09:18 PM   #7
rag top
rag top's Avatar
Is the meteor pre-86?? I'm guessing it is as you mentioned it was the 1.5, same as the KB Laser. AFAIK, the meteor and laser use the same motor, just differences in the body. Not too sure on the KB-KC swap, due to emission changes in '86.
rag top is offline   Reply With Quote Multi-Quote with this Post
Old 04-11-2006, 09:30 PM   #8
mintomax
Thanks rag top,
that will be handy too.. i have to say I am not sure of the year/model, though I am running the '86 without the emmision.. the car really 'shat its self' when I took out the plug, so am running it without emmision control hoses..
main concern is that the engine mounts and extrators and such.. I just want to make sure that the engine will all fall into place, once the old one is removed..
Old 04-11-2006, 09:52 PM   #9
VippiN
What a performer!
VippiN's Avatar
OK - This SHOULD be fine. As far as I can tell you're going from an E3 to E5 which uses same mounts, wiring, gearbox, everything should be a straight swap and bolt in fine.
Now I could be wrong as it's a KC and I haven't checked out the 1.3L that were in them (personally I always steered clear of em) but i've never heard of a B3. B6 was always the norm as far as I knew in the KC.
Either way the gearbox will interchange. That I know for sure. What you need to look at is the mounts and the wiring loom. See if it's much different if any. Just be careful before you start.
Rob
Old 09-12-2006, 05:55 AM   #10
vbtruk
vbtruk's Avatar
Hi guy's, got an 84 Laser for free with a cooked motor for getting around in while i build my ute, it's a 1.3 and i got a 1.5L from the wreckers who assured me it will swap straight over can you guy's please tell me if i can split the motor from the gearbox and pull just the motor out of the car or do i have to pull out the whole thing as one and split and attach new motor then re-insert it in the car??? Also what is the general steps to start with i have done a few engine changes with the straight six's and V8 but not front wheel drives all info highly appreciated as i want to do it tommorow.
It has a 4 speed manual.
vbtruk is offline   Reply With Quote Multi-Quote with this Post
Old 09-12-2006, 10:42 AM   #11
VippiN
What a performer!
VippiN's Avatar
So you've got a 1.3L KB Laser and you want to put in a 1.5L? If it's an E5 yes it will attach to the gearbox, if it's a B5 it won't. All depends on if it's from a KA/KB or a KC.
Old 09-12-2006, 12:29 PM   #12
vbtruk
vbtruk's Avatar
how can i know what engine it is? I know it came out of a laser. Also how do i go about getting the swap done can i leave the gearbox inside the car and seperate the motor to get the motor out or do i have to remove the whole lot??? Gearbox and motor?
Old 09-12-2006, 02:33 PM   #13
vbtruk
vbtruk's Avatar
was told by wrecker it came out of a KB laser???
Old 09-12-2006, 04:31 PM   #14
VippiN
What a performer!
VippiN's Avatar
Then you'll be right.
Old 09-12-2006, 04:55 PM   #15
vbtruk
vbtruk's Avatar
so can the gearbox be split from the motor in the car or does the whole lot have to come out to do the engine swap????
Old 10-12-2006, 08:36 AM   #16
vbtruk
vbtruk's Avatar
can it be done or is it wasting time.
Old 10-12-2006, 06:43 PM   #17
vbtruk
vbtruk's Avatar
Yes you can remove the engine without having to remove the gearbox, i split the engine from the gearbox inside the engine bay removed the single engine mount and she came straight out.
Thanks for the help.
Old 14-12-2006, 06:43 AM   #18
vbtruk
vbtruk's Avatar
OK got the new 1.5L in and bolted up perfect one problem is it is running a bit rough and wont hold idle any idea's on what to check???
