Does anyone have any idea where i can buy the special tools - (looks like a 5 sided torx) to remove the airbags so i can get to and remove the steering wheel on an AU3????
All Bran = Regular Member
welcome to the forums...
Check out this link (note the screwdriver mod):- http://www.fordforums.com.au/showpos...1&postcount=59 I've also read that Repco and Autopro sell the appropriate torx (no.30 - 5 sided). |
Thanks ronwest!!!!!! You are a life saver. I have just picked up a cruise conversion from ebay and have had many dramas with this one. I'll give Repco and Autopro a go and report back!!! CHAMPION!
#4 | |||
As a by the by, I am in the process of fitting a momo wheel to my AU. I rang my local Repco and he had no listing of a 5 point Torx bit. I then rang Blackwoods who also have no listing :( First time in 35 years that Blackwood's have failed me. I tried JC's screwdriver mod but it broke on two occasions. I ended up buying a set of 5 point torx's off ebay for $50 inc postage. Should be here in a couple of days. Good luck with yours... |
JC's screwdriver mod worked for my momo conversion!
I have a set of 5 point torx's in my toolbox at work. Actual sitting in my agrage at home at the moment! The screw driver mod was a firm favourite till I got my bits!
Its gone V
what i did was got a little screwdriver and knocked out that little knob in the middle then used a normal screw driver. with this setup you can tighten it up pretty well. Also to get the streeing wheel off i just used an allen key.
Thanks everyone!!! Great information and lots of useful tips. I have just tried the screwdriver mod and it has twice busted the ends off the driver. I am going to sus out ebay now and see what is available there. Fingers crossed.!!!
#9 | |||
![]() Join Date: Jan 2005
I just bought the ones off ebay as well - should be here by Thursday. So anyone in ACT who needs a steering wheel changed, I only charge $10. :Reverend:
#10 | |||
Commercial Sponsor
we have the genuine 5 point bit for this job , anyone in the eastern suburbs of melb is welcolm to come down and use it free of charge (in our carpark only!!)
#12 | |||
Supplier must think it's Christmas, lol. |
Walking with God
JC and Ronwest,
Can you confirm for me that it's the (#30) 5-sided bit please. I have a lead on a shop that might sell them. Cheers, GK
#14 | |||
#15 | ||
I've spoken to every Repco, Autobarn, Super Cheap etc in Brisbane to try and locate one of my own (GlennAUII has kindly let me use his when needed but I want one of my own). Only luck I've had is through Ford, but they're 40 bucks each! Bit steep for one torx bit!!
#16 | |||
#17 | |||
http://stores.ebay.com.au/Borrys-Online-Bargains and this is the product description:- "11PC PENTACLE TORX SOCKET SET 5 POINT 1/4DR 7PCS - T8, T10, T15, T20, T25, T27, T30 3/8DR 4PCS - T40, T45, T50, T55" You could ask him if he has more stock if you want a set... |
#18 | ||
I have been back at it again and the method described by SICSIX WORKED!!!!! Just use a little bit of gentle persuasion and remove the centre of the torx screw. Then use a screw driver and gently tap it into the screw head so it is a snug fit. For some extra leverage I used a pair of multi grips to help turn the screw driver. It did take patience but it did get me there!!!!! If you have the time and money to afford the 5 sided No 30 torx driver this will be easier but it is definately achievable!! My screw heads are now stuffed so I will use some Allen screws instead and make the process alot easier if iI need to service the unit in the future. New Momo and cruise control going on the beast tomorrow. Thanks for all the advice. Stay tuned for pics and update on thread sizes etc.
#19 | |||
#20 | ||
I know it's a bit off topic, but what number is the Torx bit for adjusting the U shaped door catches on the bodywork?
#21 | |||
#22 | ||
its a T30 size regular torx bit for the u shaped door catches.
