Old 09-10-2006, 11:37 PM   #1
JoesAu
JoesAu's Avatar
Default Quick question regarding radiator
Im about to disconnect the transmission oil lines to run a trans cooler, will i have to block the holes up??
JoesAu is offline   Reply With Quote Multi-Quote with this Post
Old 09-10-2006, 11:56 PM   #2
Baboon_AU
Baboon_AU's Avatar
yes u should cap the holes. even if u drain all the fluid, dirt can still get in there and may cause radiator damage.
01 AUII XLS Regency Red Ute 4.0L Egas Auto
Mods -transcooler, tickford intake, K&N pod filter, Pacemakers, 2.5 inch exhaust, Crow Cam,
1981 XD Fairmont 351 - 351 Cleveland, ARP bolts, flat top pistons, Stage 3 Dynotec cam, ported 2V heads with 4V valves, Roller Rockers, Weiand manifold, Mighty Demon, 1/2" fuel lines with blue Holley fuel pump, Crane hi-6 ignition, B&M megashifter, C4, hi-stall, shift kit, 3.77 Ford 9" LSD.
Thanks to: EvilChief and SJW Performance
Baboon_AU is offline   Reply With Quote Multi-Quote with this Post
Old 10-10-2006, 01:09 AM   #3
JC
JC's Avatar
No, you don't need to block the holes up. You can if you want, but there is no reason to, really.
Ford Performance Club ACT
Old 10-10-2006, 01:35 AM   #4
EvilChief
Boost Addict
what he said
the transmission cooling system is independant to the actual radiator system, so even if dirt gets in there it is unlikely that it may damage something :voldar02:
N12 Pulsar - sold
Gen1 Liberty Turbo - sold
VP Commodore Turbo - sold
LN65 Hilux Turbo - sold
EL31 Corolla Turbo - sold
Ford AU Ute Turbo - sold
Ford FG XR6T Sedan - cruiser
Old 10-10-2006, 02:18 AM   #5
blackers10
blackers10's Avatar
but what about the fact the transmission cooler segment in the standard radiator is prone to collapsing making the coolant and tran fluid mix (when both in use in the standard fashion)?? wouldnt this be of concern if you had the holes open and dropped all of your coolant due to the collapse occuring?
just my 2c
Old 10-10-2006, 02:52 AM   #6
EvilChief
Boost Addict
seen that only happen in systems where no appropiate additives were used in the cooling system ...
N12 Pulsar - sold
Old 10-10-2006, 02:52 AM   #7
blackers10
blackers10's Avatar
aa ok
just thinking of worst case scenario from what ive read is all
Old 10-10-2006, 03:06 AM   #8
EvilChief
Boost Addict
Originally Posted by blackers10
aa ok
thats fair :
N12 Pulsar - sold
Old 10-10-2006, 09:26 AM   #9
JoesAu
JoesAu's Avatar
i was just a bit un-sure. thanks for your replies guys.
