Old 15-06-2006, 09:31 PM   #1
Free347
Default Vortex 98
Called into my local Woolworths/Caltex servo the other day and discovered 'Vortex 98'... assistant said they only had it for a week. Is this commonly available now, has anyone been using it and what opinions if any?
Free347 is offline   Reply With Quote Multi-Quote with this Post
Old 15-06-2006, 09:32 PM   #2
Redrum
Force Fed Fords
Redrum's Avatar
Available in other states for a while. Not sure how long. Not sure if any good.
2021 Focus ST-3 Mountune Enhanced
Redrum is offline   Reply With Quote Multi-Quote with this Post
Old 15-06-2006, 10:21 PM   #3
pertuan
Focus on my Focus
I use it in my Focus. I think it runs better than Optimax. Gives me some more grunt I think. But with it costing 10c more than 91RON and 5c more than 95RON, I dont think its really worth it. I stick with 95RON now unless I feel really happy and I want to take the car for a fang.
Now: 2006 Ford Focus LX Manual in Satin White
Wife: 2013 Kuga Titanium in Frozen White
Then: 1990 Ford Laser - Assasinated by a 76 year old man who failed to give way.
Now normally when we have these races, Jeremy goes in the car and says "Powerrr" alot.... - James speaking about Jeremy (Top Gear S7 E05)
American parts... Russian parts... ALL MADE IN TAIWAN! - Russian guy in Armegeddon
pertuan is offline   Reply With Quote Multi-Quote with this Post
Old 15-06-2006, 10:25 PM   #4
Outbackjack
Central to all beach's
Outbackjack's Avatar
I only ever use BP ultimate or Caltex vortex in both the XR8 and Fiesta. I have crunched the milage numbers and have decided that it only costs 3 or 4 cents per litre more due to the longer distance per tank. And both cars drive noticably(SP?) better on these fuels. I cant really tell the diference between BP and caltex..... Both are good.
Outbackjack is offline   Reply With Quote Multi-Quote with this Post
Old 15-06-2006, 10:56 PM   #5
Jeeepers
Merry Xmas To All
Jeeepers's Avatar
Vortex 98 is the same fuel as BP Ultimate...
Jeeepers is offline   Reply With Quote Multi-Quote with this Post
Old 15-06-2006, 11:19 PM   #6
Martyvan
Martyvan's Avatar
One would HOPE it might become available... But who knows.... Then i will get a fuel card through my old man...
In Brisbane Caltex Charges 7c premium for 95 PULP.... Same with most BP's....
Martyvan is offline   Reply With Quote Multi-Quote with this Post
Old 15-06-2006, 11:29 PM   #7
G6ET8U
GTX Turbo & KB Blown
G6ET8U's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: ALWAYS goes out of his way to help others in need, never posts rubbish only facts he has learnt the hard way or with success in his personal experiance. Takes the time to aid more junior members and overall is a solid contributor to AFF.
I run the Optimax Extreme 100 in my car... just changed over. It seems to idle nicer than with the previously used BP Ultimate 98... and in the XR6T's, my tuner (Nizpro) tells me it's worth about 10rwkw... it allows for about another 3 degrees of timing to be added... which is always good.
Jack
DARTH 2008 FG G6ET
465.6rwkw
not a 10 @ 134.81 MPH
SNOW WHITE 2004 BA FPV PURSUIT
2.6L Kenne Bell
Brembos all round
Twin Screw Awesomeness
Supported, serviced and tuned by
BLUEPOWER RACING DEVELOPMENTS
http://www.fordforums.com.au/showthread.php?t=11354744
G6ET8U is offline   Reply With Quote Multi-Quote with this Post
Old 15-06-2006, 11:45 PM   #8
Jeeepers
Merry Xmas To All
Jeeepers's Avatar
Jack
How long have you run it? I would be interested on your comments after a few tanks. I run BP Ultimate, but always lookin' for that little extra...
Old 16-06-2006, 02:08 AM   #9
G6ET8U
G6ET8U's Avatar
I'll let you know mate... so far, so good. Though I've re-tuned the car to suit as well. Simon from Nizpro put me on to it, it is all he runs in his ute (450rwkw ish daily driver), I'm currently on my 2nd tank, and outwardly it looks expensive because it's 17c more expensive than 91RON unleaded, so it's 7c more expensive than BP Ultimate (which I ran for nearly 6 months), but with one of the Coles vouchers it works out to be only 3c more expensive than Ultimate which is f@&k all if it means another 10rwkw...
Jack
DARTH 2008 FG G6ET
465.6rwkw
2.6L Kenne Bell
Brembos all round
Old 16-06-2006, 07:26 AM   #10
LTDHO
The one and only
LTDHO's Avatar
Caltex 98 has been around for ages, it is one of the two fuels I use.
However, it is only good to use if your engine needs the higher octane!
Tuned by CVE Performance
Old 16-06-2006, 07:39 AM   #11
Pedro
Pedro's Avatar
Vortex 98 only recently became available at the Nerang Caltex where I can use Woolworths vouchers. I'm on my fourth tank in my F6 and haven't noticed any difference from the BP Ultimate I used previously.
redfin's quote would explain why.
Pedro is offline   Reply With Quote Multi-Quote with this Post
Old 16-06-2006, 08:36 AM   #12
Martyvan
Martyvan's Avatar
Not in Qld... It has been in some southern states... But only every so often available here. Would be good if it became a permanant fixture.
Old 16-06-2006, 09:14 AM   #13
mowog
Discovery 4
mowog's Avatar
I have started to use it in my Corolla and it has made a difference. Yesterday it broke traction at 6000rpm in first it has never done that before.
The 2ZZGE in my Corolla has a set of Hi Lift cams that kick in at 6000rpm when this happens the character of the engine changes big time. So for the first time the front wheels broke traction when it hit 6000rpm. Maybe it was a combination of a cold day and the Vortex 98.
Blue Ranger Wildtrak V6 on the way. Factory Canopy & 140l ARB fuel tank.
Discovery 4 3.0 TDV6 SE. Long range aux tank, Kaymar Rear Bar, 18" Off Road rims.
Lotus Trooper.
Mini Inspired by Goodwood.
mowog is offline   Reply With Quote Multi-Quote with this Post
Old 16-06-2006, 09:49 AM   #14
csv8
csv8's Avatar
RACV tested 95 and 98 RON.
They found a FALCON has a 1.7% improvement on 95 RON and 1.5 % on 98 RON. Compared to 91 RON.
With a FIESTA 1.7% improvement on 95RON and 2.5% ON 98 RON, compared too 91 RON.
Road Ahead June/July 2006
csv8 is offline   Reply With Quote Multi-Quote with this Post
Old 16-06-2006, 09:50 AM   #15
Free347
So you've seen it come and go over time... over how long? I got the impression it was here to stay by the servo guy.
Old 16-06-2006, 09:51 AM   #16
csv8
csv8's Avatar
Mobil has also started selling SYNERGY 6000 and 8000 in Queensland since last week. Any comments on these fuels ?
Old 16-06-2006, 10:04 AM   #17
Outbackjack
I can make a backwards comparison..... Does that make sense? I have only ever used 98 in the XR8 since new in dec 05. The ONLY time I had to use 91 was a couple of months ago up to Borroloola in the gulf country. Very remote area. Nothing but 91 could be bought. On the trip back down south, the difference was noticable. The car was "kinda flat" it would still get up and go, it seemed just a little reluctant to do it. Perhaps a bit like a filthy air cleaner. And the range on that tank was close to 60k's less. Needless to say I was glad to get some proper fuel into it again. I cant really comment on city driving where you are constantly drudging from traffic snarl to traffice snarl, but on the open road there are definately advantages to the higher octane.
BTW bp 98 is about 1.89 a litre in the Alice.
Old 16-06-2006, 10:10 AM   #18
Free347
Sorry to come back to this but can you elaborate please.
Old 16-06-2006, 10:19 AM   #19
Full Noise
Life begins at 40
Full Noise's Avatar
Location: Melbourne. Socialist capital of Victoriastan.
Not quite.
BP Ultimate is actually the same as Mobil Synergy 8000.
In Victoria, Vortex 98 starts its life from another terminal.
Cheers, Danny
Marriage is like a deck of cards. In the beginning you’ll have hearts and diamonds. Towards the end, you’ll be looking for a club and a spade.
Justice is what you get when you run out of money.
Full Noise is offline   Reply With Quote Multi-Quote with this Post
Old 16-06-2006, 10:21 AM   #20
Full Noise
Life begins at 40
Full Noise's Avatar
Mobil and BP share a joint facility in Melbourne. It’s all basically the same stuff loaded into different tankers.
Old 16-06-2006, 11:11 AM   #21
Feathers
Lucifer's Angel
Feathers's Avatar
I have used it a few times and noticed that I got more k's out of a tank than with the regular Vortex. That was around the city though, so I didn't get to take it out for a longer trip.
I work for Woolworths anyway, so with the staff discount, it works out about the same cost as for Vortex.
SINISTER BA XR6
Blueprint, manual, 4490's, Redback 2.5" dual exhaust, BA Typhoon rims, tint, fog light covers, BF tailights, blue illuminated window switches, Ghia bootlid carpet, lower grille, FPV door spears, steering wheel & interior bits, XR6T + F6 intake, K&N filter, Typhoon spoiler, tuned, sway bars, custom angel eyes & plates..YUM!
If there's one thing guys in Holdens hate more than being beaten by a Ford...
It's being beaten by a girl driving a Ford
Feathers is offline   Reply With Quote Multi-Quote with this Post
Old 16-06-2006, 11:58 AM   #22
seano14
it's been in noosa for at least the last 5 years! the old ltd seems to love the stuff and gets good milage so it's all i use
seano14 is offline   Reply With Quote Multi-Quote with this Post
Old 16-06-2006, 02:02 PM   #23
Martyvan
Martyvan's Avatar
I dont usually fill up a Caltex, but over the years, you occasionally see a Vortex 98 pump... here and there, I find it funny, that Noosa has it as well... Good that its available, but strange at the same time.... You would think if they have it one place, they would have it in all... Go figure. Would be nice if they do bring it into Qld as a permanant pump...
Old 16-06-2006, 08:20 PM   #24
qwigybo
hunting 300kw's
qwigybo's Avatar
Originally Posted by Full Noise
Not quite.
Cheers, Danny
i was under the impression ultimate & synergy were the same
ampol gold and vortex were the same
current ride: '04 XR6 Turbo, Phantom, Premium sound.BluePower Enhanced
236.9rwkw 8psi DAMN VALVE SPRINGS (stock 13.82 @ 106.08 HPR)(8psi 13.29 @ 103.93)
'99 r8 clubsport, leather, sunroof, 6speed, yeah the turbo is faster.....
qwigybo is offline   Reply With Quote Multi-Quote with this Post
Old 17-06-2006, 01:32 AM   #25
MAFIA
Grange killer!!!!
MAFIA's Avatar
YOUR JOKING RIGHT??????
Originally Posted by CAT600
Mafia, when did you install the 7.0L in the limo? That TL50 of yours sounds liker it's got a Top Fuel dragster engine in it?
INSURED BY MAFIA. YOU HIT US, WE KILL YOU!
FORD FTE AU T-SERIES CLUB OF AUSTRALIA
www.tseriesclub.org
MAFIA is offline   Reply With Quote Multi-Quote with this Post
Old 17-06-2006, 02:08 PM   #26
Full Noise
Life begins at 40
Full Noise's Avatar
Originally Posted by qwigybo
I was under the impression that Ultimate & Synergy 8000 were the same and Ampol gold and Vortex were the same.
Spot on. :Reverend:
Caltex are in the process of setting up the loading system for the new Vortex 95. It’s basically Shell 95 with a different label. This will be available soon.
Cheers, Danny
Old 17-06-2006, 06:12 PM   #27
cArSiK
No , its not.
Ive been using Vortex 98 for nearly two years now , its fine for my purpouse.
cArSiK is offline   Reply With Quote Multi-Quote with this Post
Old 17-06-2006, 06:33 PM   #28
Outbackjack
I try to use Caltex as much as I can. Only because out of all the oil companies, caltex keeps the most ammount of $$ in Australia. I try to buy Australian as much as humanly possible.
Old 17-06-2006, 06:33 PM   #29
flappist
Actually no it hasn't. There are two different vortex products. The one tha has been around for the last few years is 95ron. It is the same stuff as the BP and Mobil premiums.
The only 98 ron products in the sunny coast is Ultimate, Optimax (not 100) and Boost 98 with ethanol, unless of course, there is a new Vortex 98 just started.
Old 17-06-2006, 07:09 PM   #30
Feathers
Lucifer's Angel
Feathers's Avatar
I actually filled up with it today. was 148.9c though with my staff discount was the same price as the 95ron Vortex.
I'll have to take it for a run down the coast on my next day off.
SINISTER BA XR6
