Hi Everyone!
I have a Telstar TX5 (AT2) and am desperately serching for a wireing diagram to put a sterio in. (Last one got stolen) if anyone has one or knows where i could find one could they please, please! e-mail me at No_Inteligence@msn.com |
Over Thinker
a lot of people would like the radio diagramms
my diagrams only show a red /black to radio then radio is earthed all I can suggest is the speakers share a common earth - then the + is usually the white and black stripe or a stripe of some colour not much help I know
My car goes Brumm Brumm |
yea, i got a few like that. thanks anyway.
Welsh...and proud
how old is the car, btw?
i may be able to help a bit if it's an old model Telstar, as i've just done an extensive rewire on the original clarion 2-piece unit, adding a Sony 10-disc CD Multichanger to it, and putting new speakers in the car all round, so i can tell you roughly what wire is what. you'd just have to connect the wires up afterwards, unless your harness plug hasn't been cut off |
N_I,
All you need is a $10 multimeter from Dick Smith and a 1.5v battery. Use the multimeter to find Power (Red prong on the cable, black prong on a bare part of the car body, should be ~13.5v all the time), ACC(As above but only 13.5v when the key is on ACC, Ground(Cable should be as thick as the Power or ACC, but no voltage reading. Put the multimeter on continuitity and test the ground cable and the body. There should be close to no resistance. Then for the speaker wire. Use the continuitity tester on 2 cables (they should have been next to each other on the plug. (this is when you hope they don;t have a common ground) When you find 2 cables with a reading, get the battery and join each side to the wire briefly. If the speaker cone pushes out out, the cable touching the +ve end is the +ve cable. If it goes in, reverse the battery and test again. When your doing all this be careful that the cables don;t touch each other and as soon as you work out a cable, tape up the wire and label it. You may need to get a spare radio fuse for the dash fusebox. |
Over Thinker
meanbow
any information on any telstar radio wiring would be much appreciated can you make a post on you findings it would help a lot of people ,if you have time
Over Thinker
finally found a forum that has more wiring info mazda and telstar are close
so try http://www.mx6.com they have a radio section all made up with instructions and conversions
Welsh...and proud
No problem, dirty hands.
i'll just strip the panels off tommorow and note down the wires for you, then post back here with them again. ![]() |
Over Thinker
nahh wait till you want an upgrade
do it with a song in your heart and glass of the national drink? I have made a new wiring diagramme in the "advice on telstars " post for radio wiring
My car goes Brumm Brumm Last edited by dirty hands; 06-06-2006 at 08:13 AM. |
Welsh...and proud
RIGHT!!!
i just finished stripping off the panels on my '83 Telstar and reviewed the wiring i done and this is what i came up with, but ALWAYS remember to use a multimeter/circuit tester as well to confirm the correct wiring Telstar(GC/GD Platform) radio wiring Light Green - Permenant live Dark Green - Ignition live Red/Green stripe - night illumination(light circuit) Black - Ground/Earth Speakers Front right Blue/Brown - Negative Blue/Brown with Green - Positive Front left Blue/Brown - Negative Blue/Brown with Orange - Positive Rear right Blue/Brown - Negative Blue/Brown with Red - Positive Rear left Blue/Brown - Negative Blue/Brown with White - Positive ![]() |
Over Thinker
awww that is so good of you
#12 | ||
Thanks so much guys. i'll give it a go first thing in the morning. advice much appreciated
