A V8 salute to my DEATH
Hey,
I just pulled the carb of my 78' F100 to check it out due to poor running. I found that the entire fuel bowl was covered with a coat of sh1t about 3mm thick ![]() Cheers, ![]()
1981 Toyota Hilux, 4inch lift, 33" Buckshot Mudders, LSD diffs, bullbar, driving lights, rollbar, toolbox and a 253 V8 |
so what actually is this coating i`know electrolysis is common in diesels i have one in the driveway, the electrolysis ate thru one of the liners, i have heard of trucks having this problem in other forms cracks in chassis, body work etc, which can be fixed i believe with an electronic device, as far the the engines go usually diesels run an additive in their coolant which is supposed to be a preventative (alfaloc or alfloc cant remember correct spelling ), i think electrolysis is static electricity basicly, i pulled the liner out of my detroit deisel and it looked like wood borers had been eating the liners of the engine, just wondering what sort of fuel are you running???
i run on premium, or a ulp/avgas mixture. But this coating is from when the truck sat before i purchased it. It sat for 3 yrs with no fuel in the carby.
Lucifer's Angel
Ha, I took the title an entirely different way...
![]() ![]() Blueprint, manual, 4490's, Redback 2.5" dual exhaust, BA Typhoon rims, tint, fog light covers, BF tailights, blue illuminated window switches, Ghia bootlid carpet, lower grille, FPV door spears, steering wheel & interior bits, XR6T + F6 intake, K&N filter, Typhoon spoiler, tuned, sway bars, custom angel eyes & plates..YUM!
If there's one thing guys in Holdens hate more than being beaten by a Ford... It's being beaten by a girl driving a Ford ![]() |
Get the wire brush out get the tooth brush out...and some CLR or maybe sodybic and scrub the crap out of it.
FORD RULES OK The more I know ppl the more I love my DOGS. 2011 SY Territory Limited Edition TS 2000 AUII SE ute IL6 |
I take it the Carb is made of aluminium. If so, go to the local car shop and buy some Alloy wheel cleaner.. It works a treat. Mothers is the best. Don't by the cheapie one, they are practicaly all water and don't work anywhere near as well. Mothers Cost $19..
#7 | |||
no, it's a bog stock 302 2-barrel carby
Buy a small container of "sulphuric acid" apply with a cotton bud, leave it on for thirty seconds, rinse if it has done the job good, if not repeat the process until all the gunk has gone dont wipe it on you want the area wet, you will know if it working if the area foams and bubbles, keep what you have left to clean up any rust you may want to remove on other items.
#10 | |||
meow
Electrolysis from what I know involves the passing of a current through an ionic solution... Don't think you'd get that occuring in a fuel bowl...
#12 | |||
Weezland
#13 | |||
Allan Smithee
Oops.
1974 XB Falcon 500 Station Wagon - 250, 3 speed auto and running like a 2015 model 1999 AU Wagon Petrol/LPG - Cheap run around, but still a great car! 2014 PX XLT Ranger 4x4 Auto getting set up as an off road touring rig |
