26-04-2006, 08:48 PM | #1 | ||
Now With 2 Cylinders More
hey guys,
ever since doing a disk frag, my computer turns off, at any rendom time, for no apparent reason, now i pulled all the power cables out, and plugged them all abck in firmly so its not the problem at all....so what is the problem ???? |
26-04-2006, 09:05 PM | #2 | ||
need more info
what Operating System what brand if any HP, IBM, Toshiba, Sony <- all of these are your problem what did u recently do to it, installed dodgy software, installed a 7 disk program and it glitched.....etc who else uses it check your settings, power settings, not sure if ill ask u to check ur hardware settings im not paying for it! check your power points with something else like a TV or something big and sucks power - do at own risk richie |
26-04-2006, 09:26 PM | #3 | ||
yep good advice there, i would be swapping power points / double adapter,power board before replacing anything then see how it goes, could be anything check the easy stuff first check cables are in properly,etc etc goodluck
27-04-2006, 12:17 AM | #4 | ||
If you've never defragged ever sometimes it can upset all sorts of routines. I've only encountered it a few times; but just restarting the computer helps.
27-04-2006, 02:08 AM | #5 | ||
Right out sideways
also could be getting too hot ?? check heat sinks arent clogged with dust.
But being winter it should be a little cooler, my cpu idles about 7 degrees cooler than 3 months ago
2010 FG XR50 Turbo | 2007 FPV BFII GT, BOSS 302 |
