Old 03-04-2006, 05:22 PM   #1
alpineau
alpineau's Avatar
Default AU2 determined miss (nned help) :(
Hi Guys
About 3 days ago my car devloped a miss out of the blue and very quickly. When I drove to work in the morning is wasn't there and when i went home in the afternoon it was there.
So i did a bit of research on the form to find out if anyone else had a similar problem. I found that most people just changed the leads and plugs. I had a look at the leads and plugs and from what i can tell they look like the orignal ones that the car came with. So i changed both.
After i finished i took the car for a drive around the block and all seemed good. Then this morning i drove to work only to find that the miss was back, not as bad but still there.
Before i replaced the the leads and plugs and now the miss is only noticeable when i accelate, when i get up to speed it goes away and it's not noticalbe at idle
Any ideas
Thanks
Alpineau
alpineau is offline   Reply With Quote Multi-Quote with this Post
Old 03-04-2006, 10:20 PM   #2
Racecraft
they call me Tibbo
Racecraft's Avatar
if plugs and leads has made a difference, all that is left and the most likely culprite the coil pack is weak and might need replacing
Old 03-04-2006, 10:35 PM   #3
GK
Walking with God
GK's Avatar
How do you test this?
GK
Old 03-04-2006, 10:37 PM   #4
Racecraft
they call me Tibbo
Racecraft's Avatar
I'm sorry I can't help you to test it GK, If I have a miss and plugs and leads didn't fix it, I just put a coil pack on...
Old 03-04-2006, 10:42 PM   #5
alpineau
alpineau's Avatar
The leads were hard enough to do (mainly becuase of where they are) i think i might have to take it into a shop. I think i might do more damage then good if i keep playing
Thanks for the reply racecraft. I will post the problem after it's get's back for the workshop tomorrow
Alpineau
Old 03-04-2006, 10:48 PM   #6
GK
Walking with God
GK's Avatar
How much is a coil pack? Apparently it's a shocker to replace?
GK
Old 04-04-2006, 08:47 PM   #7
V8falcons
V8falcons's Avatar
GK
was about $70 -probly cheaper now.....it can be hard to get to, do it from under the car on stands,its a little bit easier!!!!!!!!!!!!
V8falcons is offline   Reply With Quote Multi-Quote with this Post
Old 05-04-2006, 11:04 AM   #8
Futura01
horsepower
GK DOES IT HAPPEN MORE WHEN UR ACCELERATING FROM STANDING START ??
because i believe i might have the same problem , because mine only happens when i am pushing when it gets top end it goes okay and i dont feel the miss ????
and how much was the repairs in total .. ??
Futura01 is offline   Reply With Quote Multi-Quote with this Post
Old 05-04-2006, 08:45 PM   #9
XR6-VCT-2000
Fantastic Plastic
XR6-VCT-2000's Avatar
might sound silly , but did you clean/replace your air filter while doing the spark plugs and leads ? is the gap correct on the spark plugs / a few might of needed adjusting a tadd ?? .. I dunno if it would maybe goto the extent of making the car miss beat unless it was totally blocked/the air filter ( where only high revs would cause enough vacume to get the air through the rubbish in the filter suficientlyr ) ? .. just a maybe ..
:eclipsee_
Old 05-04-2006, 10:45 PM   #10
GK
Walking with God
GK's Avatar
Yes, more when taking off.
GK
Old 05-04-2006, 10:47 PM   #11
GK
Walking with God
GK's Avatar
$70 is ok, not too confident about doing it myself though! Thanks for the info. Bye the way, how long did it take you to do?
GK
