View Poll Results: Should Boss 260/290's be allowed billet oil pump gears | |||
Yes, Most definately ! | 17 | 44.74% | |
No, It is classified as opened ! | 14 | 36.84% | |
I dont really care ! | 7 | 18.42% | |
Voters: 38. You may not vote on this poll |
30-03-2006, 07:07 PM | #1 | ||
trying to get a leg over
I have created this poll to get some feed back on the use of billet oil pump gears in the Boss 260/290's.
As some of you are aware, there has been numerous failures of the standard gears. Some motors have had relatively minor damage if shut down quicky, some others have been completely stuffed. The LS1 brigade get a concession in their un-opened motors to run better valve springs, which imo is definatly a performance gain, not a reliability issue. I suggest that there be a concession with the Boss 260/290 motors, that allows them to run billet oil pump gears and still be classed as un-opened. Those that probably disagree, either dont own a modified "bolt on" Boss or have plenty of $$$$ to spend when their gears finally let go.
Cameron ------------------------------------------------------ |
30-03-2006, 07:10 PM | #2 | ||
windsor user
i think thats a fair call.... as you said its not a performance gain..... just a stronger oil pump gear....
further on this, the billet gears are fitted in the factory repairs yes? so therefor it should be classified as a factory part.......if its a part that ford themselves are fitting to fix the issue |
30-03-2006, 07:12 PM | #3 | |||
N/A BOSS 390+
WOOOOOOOOOO FPV GT 03 /341 RWKW OF N/A POWER. XB GT 73 /OLD FORD MUSCLE ALL AUSSIE MUSCLE |
30-03-2006, 07:16 PM | #4 | |||
Ford have replaced some motors under warranty, with a new factory motor. Other people have copped it on the chin with their warranty voided, because of modifications.
30-03-2006, 07:19 PM | #5 | |||
windsor user
you'd think ford would realise it could be so much cheaper and better repaired by fitting the gears straight out wouldnt you... |
30-03-2006, 07:24 PM | #6 | |||
Solution Was Boost 4?, 6 & 8
At some stage everyone well need to change them.
[SIGPIC][/SIGPIC]
AUTOTECH TUNED EDELEBROCK CHARGED 2017 GT Mustang Plenty of RWKW |
30-03-2006, 07:30 PM | #7 | ||
AFF.com.au
this is easy,
TO PUT VALVE SPRINGS IN A MOTOR, IT NEEDS TO BE OPENED. TO PUT OIL PUMP GEARS IN A MOTOR IT NEEDS TO BE OPENED. simple. If people are going to pull chains off a boss to do a pump, then the cam timing requires re-doing, but it doesn't matter, opened is opened. If this thread goes down the path of us following the LS1 crowd, then im putting my "unopened" 260 back in the ute and i'll kill the LS1 and Ford records. Childish. opened is opened, no matter how you play it, notwithstanding the fact that timing adjustments can be made on a boss when the oil pump is off. Moving cams around alters valetrain events, as does changing valvesprings in an LS1. Once the chains are loosened, the timing events are altered, who will be policing this?? What is your stance Cam?? |
30-03-2006, 07:31 PM | #8 | |||
AFF.com.au
opened - check it out in the dictionary guys........ |
30-03-2006, 07:35 PM | #9 | |||
AFF.com.au
30-03-2006, 07:37 PM | #10 | ||
I got to agree with Chris on this. I dont have a BA so I have nothing to gain or lose here, no motive but logic. Opened is opened. If it touches engine oil.. its open. I think the LS1 valve spring agreement is a joke personally. Something they have all convinced themselves isnt really a "real" mod. Guess what.. non factory is non factory. Open is open.
30-03-2006, 07:43 PM | #11 | ||
No one is policing it, so just do what you like call it want you want.
Just Go Hard Go Fast.. In The end its up to each person to say whats done to there car if they wish.
[SIGPIC][/SIGPIC]
30-03-2006, 07:45 PM | #12 | |||
I agree with what you are saying in principal, but as you know it is a real problem with these motors, and speaking for myself, i cannot afford for a motor to destroy itself, because of inferior oil pump gears ! I am lead to believe that the cam timing should not alter with the replacement of these gears, unless vernier gears are used or the installer has incorrectly re-assembled the timing chain assembly, or altered the cam position by dubious means.
30-03-2006, 07:47 PM | #13 | ||
I'm in a bind .. there is absolutely no performance gained by doing it .. but it definitely is opened.
30-03-2006, 07:52 PM | #14 | ||
OK guys, Im not stirring ИИИИИ, but will we class cars that have had timing chain tensioners replaced under warranty as "Opened" ?????
Technically speaking they have been !
30-03-2006, 07:58 PM | #15 | |||
So maybe your oil pump gears are in the same boat, is this what you are saying Cam?
[SIGPIC][/SIGPIC]
30-03-2006, 08:06 PM | #16 | ||
G&D Performance Australia
Replacing a rocker cover gasket is OPENED.
Rectification of faulty timing chain tensioners by a ford service technician is OPENED. Removing camshaft dowels & moving cams around & tightening the hell out of the camshaft bolts is OPENED. Where does it end.I agree this oil pump gear saga is a can of worms but how many engine have to be blown up before we wake up to the fact that something has to be done.These engines aren't cheap & cost at least $10,000 - $12000 second hand with Fords retail being set at $14950. The LS1 valvespring failure issue is a common one,even holden replace many under warranty.They lose tension very early in their life cycle & create excessive valve float hence a loss in power that is quite evident on the dyno.This is a different issue though & I think the BOSS oil pump gear issue has far more merrit. I for one think that the whole bolt on/stock internal scene is a joke until we see some real scrutineering.I'd like to see it happen,maybe we can pay an independant party to do it for us.Relying on someones honesty & integrity is not good enough. Glenn |
30-03-2006, 08:07 PM | #17 | ||
I guess I see it as where do you draw the line? Its too open to "creep" where one thing, then another, then another is accepted as "unopened" still.
30-03-2006, 08:12 PM | #18 | |||
30-03-2006, 08:21 PM | #19 | ||
I'm BOSS
Location: Where all Fast Fords are From, Northern Melb.
So how far do the engines need to be pushed (making more Hp) before this becomes an issue. Or can a stock Boss be subjected to such a failure, if it leads a hard life???
====Past Rides==== '04 BA XR6T 5spd T5: Nizpro Tuned, Valve springs, CIA, Injectors, 256RWKW '04 BA XR8 4spd BTR:Bluepower Tuned, BPR CAI, Big Boy exhaust, Hi Stall, 4.11s, 248RWKW PB:13.2@105mph '92 EB Fairmont GHIA 5.0LT 5spd T5:Stock with a cat back exhaust. '06 BF Fairlane GHIA 230Boss ZF 6spd: BPR CIA, cat back Exhaust. ====Present Ride==== '10 FPV GS Ute ZF 6spd:#108. With all the fruit. |
30-03-2006, 08:22 PM | #20 | ||||
AFF's 1st DM.......
FORD GIVING POWER TO THE PEOPLE Alloy headed 347ci EDXR8 13.21 @107.7mph Quote:
30-03-2006, 08:22 PM | #21 | ||
Yup still unopened. You gain no performance from changing them. It's not like it's a cam change.
74 XB Fairmont (street car) 11.07@123.02mph. 08 LV Ford Focus XR5 (daily). Tuned by Hallam Performance |
30-03-2006, 08:29 PM | #22 | |||
The billet gears are the best insurance imo.
30-03-2006, 08:33 PM | #23 | |||
All i'm worried about is the fact that if the gears aren't allowed then the average punter out there won't get the opportunity to have a go at the records that have been set due to fear of having to sell their house to buy new engine. The other issue boils down to trust,if you allow the use of the gears it stops anyone having an unfair advantage by using them & not telling anyone about it. Glenn |
30-03-2006, 08:36 PM | #24 | |||
BOSS 5.4L Enthusiast
Personally in racing terms i wouldn't consider it opened, but i don't really care either... |
30-03-2006, 08:37 PM | #25 | |||
AFF's 1st DM.......
Okay... how it goin to advantage say me from you if you use the gears....
Hadnt realised they were good for hp also.
30-03-2006, 08:38 PM | #26 | |||
30-03-2006, 08:39 PM | #27 | |||
I think I'll just enjoy you making my car fast, opened or unopened, maybe semi opened : and everyone can all come out and go drag racing for the one reason I do it.. FUN!
30-03-2006, 08:39 PM | #28 | ||
Interesting poll results, most people appear to class them as opened, but the poll show as more leaning towards unopened, maybe it's thew wording, people may not be reading the poll correctly.
30-03-2006, 08:39 PM | #29 | |||
AFF's 1st DM.......
okay so drag racing doesnt risk your driveline or engine
30-03-2006, 08:40 PM | #30 | |||
Glenn |
