Closed Thread
Old 21-03-2006, 08:46 PM   #1
GTS_300_Coupe
Mandy Moore FTW!
GTS_300_Coupe's Avatar
Default Hotrodders vs. Ricers *just for comparison*
Hotrodders: keeping a low profile and letting the et's tell the story
Ricers: Hoping the outrageous body kit will distract anyone from discussing et's
Hotrodders: Sideways into third gear
Ricers: Sideways to avoid high-centering on a speed bump
Hotrodders: Tall spindle conversion for better camber gain and tire wear
Ricers: Lowering 3 inches and ruining tires with 4-degrees of negative camber
Hotrodders: 600 HP on 92-octane pump gas
Ricers: 300 HP on $4-a-gallon 100-octane race gas
Hotrodders: Swapping stock 14 inch wheels for 17s to clear trick brakes and suspension
Ricers: Swapping stock 14 inch wheels for 20's despite stock brakes and suspension
Hotrodders: Boost gauge on a blown car, nitrous gauge on a squeezed car
Ricers: Both gauges on a normally aspirated car
Hotrodders: 500 lb-ft of torque at 3500 rpm
Ricers: 50 lb-ft of torque at 35,000 rpm
Hotrodders: Headers and 3-inch exhaust
Ricers: Stock pea-shooter exhaust pipe with 5-inch tip
Hotrodders: 600 HP makes for an earth-shaking street car
Ricers: 600 watts per channel makes for an ear-shattering street car
Hotrodders: Buying an aftermarket shifter for shorter throws
Ricers: Buying an aftermarket shifter for the lighted knob
Hotrodders: Composite parts for light weight and aerodynamics
Ricers: Composite-veneer dash trim and gauges
Hotrodders: Upgrading to a 9-inch cuz you keep breaking stock rears
Ricers: Realizing that your built motor will keep breaking half-shafts forever
Hotrodders: Functional air ducts to cool the big-block
Ricers: Six different cosmetic air dams in random locations
Hotrodders: Polishing tail-light lenses to bring out the red color
Ricers: Installing clear tail-lights to bait cops
Hotrodders: Cruising and burnout contests at car shows
Ricers: Disco-dancing and stereo competitions at car shows
Hotrodders: Old-Tech pushrod chevy LS6 pushing 405 HP
Ricers: State-of-the-art, dual overhead cam Honda VTEC pushing 180 HP
Hotrodders: Race-class lettering on the rear window
Ricers: Japanese "Honda" lettering on the rear window of a Nissan
Hotrodders: Tach mounted on the dash in the drivers line of sight
Ricers: Bobbing-head doll mounted on the dash in the drivers line of sight
Hotrodders: Nitrous oxide
Ricers: "Noss"
Hotrodders: Installing a 12-point cage after breaking into the 11's
Ricers: Installing a 12-point cage for more places to mount gauges
Hotrodders: Feeling the car shake form a lumpy cam
Ricers: Feeling the car shake from booming bass
Hotrodders: Doing a short burnout to warm the tires before a pass
Ricers: Weaving from side to side cuz nascar racers do it
Hotrodders: Comfy stock buckets on a 9-second street car
Ricers: back-breaking fiberglass racing buckets on a 17-second street car
Hotrodders: Spending $2000 to get a new Z28 into the 11's
Ricers: Spending $12,000 to get a Civic into the 12's
Hotrodders: Showing off a 500 HP dyno sheet
Ricers: Boasting that their 150 HP mill makes more HP/liter
Hotrodders: Installing subframe connectors to stiffen the chassis
Ricers: Connecting the subframes with neon lights
Hotrodders: Throttle steer
Ricers: Torque steer
Hotrodders: Leaving on the third amber light at the strip
Ricers: Blowing through red lights on the street
Hotrodders: Turning a $2000 "fixer upper" into a 10 second car
Ricers: Spending $20k on a car then another $20k on mods only to turn it into a 10 second car
GTS_300_Coupe is offline
Old 21-03-2006, 08:50 PM   #2
smciner1
Detroit Locker Equiped TM
smciner1's Avatar
Thumbs up
An oldy but a goody.
Apollo Blue 1974 XB Falcon GT, 557 HP
Blue Pearl 2004 BA FPV GT, 290 kW
Originally Posted by MRJUCY
Simple give the car a rev & have a listen a Windsor makes a sort of wheezy drone similar to an angry Hugh Grant when a Clevo will sound like Satan has woke up with a hangover & realized he is out of coffee & cigarettes
Falcon GT Club of Geelong.
http://www.facebook.com/FalconGTClubGeelong
smciner1 is offline
Old 21-03-2006, 08:51 PM   #3
bwhinnen
You know the sad thing, the extra $20K probably wouldn't see it anywhere near the 10sec mark...
bwhinnen is offline
Old 21-03-2006, 08:58 PM   #4
Melz
Melz's Avatar
hahahaha... i like it, never seen that before. I'm waiting for a comparison of chrome and neons though
Originally Posted by Jeremy Clarkson
“The Americans lecture the world on democracy and then won’t let me turn the traction control off!”
Melz is offline
Old 21-03-2006, 09:02 PM   #5
347Stroker
347Stroker's Avatar
Hotrodder...V8 or nothing
Ricer...Installing a WRX front bar to your Falcon XR6
347Stroker is offline
Old 21-03-2006, 09:15 PM   #6
Gammaboy
Grinder+Welder = Race car
Gammaboy's Avatar
Its NAWZ!
"No, it will never have enough power until I can spin the wheels at the end of the straightaway in high gear"
- Too much power is never enough....Mark Donohue on the Can Am Porsche 917.
Gammaboy is offline
Old 21-03-2006, 09:18 PM   #7
Falcon Coupe
Clevo Mafia Inc.
Falcon Coupe's Avatar
Chairman's Award: Chairman's Award - Issue reason: The exceptional contribution made to AFF over an extended period of time. Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Your tireless efforts behind the scenes in keeping AFF the place it is.
ROFL Gammaboi, been doing those self portraits again....?
Falcon Coupe is offline
Old 21-03-2006, 09:20 PM   #8
Gammaboy
Gammaboy's Avatar
I thought it kinda looked like Dan :P
Gammaboy is offline
Old 21-03-2006, 09:24 PM   #9
chief
FTF Club Moderator
chief's Avatar
Never read that before. It is true, all true.
Albert Einstein:
Fords in the Park 2010
chief is offline
Old 21-03-2006, 09:52 PM   #10
Rev28K
re
Location: Victoria - where being slow & incompetent is considered being "safe"
Talking
For your information that is 189hp (FW) and 136hp (ATW)
Rev28K is offline
Old 21-03-2006, 09:57 PM   #11
Gammaboy
Gammaboy's Avatar
So should we be more scared? or less?:P
Gammaboy is offline
Old 21-03-2006, 10:05 PM   #12
stiddy
stiddy's Avatar
hahaha omg look out, that earth shattering 107kw at the fronts..
I havent seen it before, funny read
I saw an old stock civic last week that had about 6 or 7 gauges all different colours in it, thought that was a crack up till i saw the scissor doors..
Its just one of those things you wish you had a camera for.
stiddy is offline
Old 21-03-2006, 10:09 PM   #13
Gammaboy
Gammaboy's Avatar
Gammaboy is offline
Old 21-03-2006, 10:10 PM   #14
347Stroker
347Stroker's Avatar
Originally Posted by Gammaboy
I can see one going on a certain "RICED" red Falcon.....
Old 21-03-2006, 10:11 PM   #15
Gammaboy
Gammaboy's Avatar
Peaking at the Drift not Drag setting? :P
Gammaboy is offline
Old 21-03-2006, 10:12 PM   #16
FPV8U
BOSS 5.4L Enthusiast
FPV8U's Avatar
I love that one...
FPV8U is offline
Old 21-03-2006, 10:14 PM   #17
347Stroker
347Stroker's Avatar
Is that Driver in Drag?????
Old 21-03-2006, 10:15 PM   #18
Gammaboy
Gammaboy's Avatar
I thought we'd never speak of that again.....
Gammaboy is offline
Old 21-03-2006, 10:17 PM   #19
347Stroker
347Stroker's Avatar
Mate, you would have to disguise yourself in makeup and dress if in your world a WRX front bar is as good as owning a WRX.
I guess its cheaper than a WRX
Old 21-03-2006, 10:22 PM   #20
FAT071
Low 'N' Fat, The Only Way
FAT071's Avatar
Funny read loved it, its all true to.
Mick
Fuel
Oil
Rubber
Destroyer
FAT071 is offline
Old 21-03-2006, 11:21 PM   #21
Xploded
Xploded's Avatar
Never seen that before, very good read was quite funny he he ....
Xploded is offline
Old 21-03-2006, 11:40 PM   #22
Tony xa
Streetrides panel & paint
Tony xa's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Tonys qualified advice on paint and panel is always very good
Funny read .
Can I ask a stupid question why is it that you all seem to hate rice or boyracer cars .
Is it the cars themselfs or the people that usauly own them .
One thing I will say about boyracer cars is that a 10sec boyracer is better behaved on the street than a 10 sec muscle car and a 10sec boyracer can be used every day .
I guess I have trouble with bagging boyracer cars because I like all loved cars and My age sits right in between both muscle and boyracer .
Still good read like to see the other side to
Tony xa is offline
Old 21-03-2006, 11:56 PM   #23
GTS_300_Coupe
Mandy Moore FTW!
Originally Posted by Tony xa
Funny read .
I love boyracer cars more than domestics.
These include S2000, WRX, Evo, 3000GT, Supra, Skyline, FTO, RX7, VR-4, 240sx, 200sx, 300zx, etc.
However I hate standard lancers, mazdas, basically any standard 4 banger thats all show and no go.
Old 22-03-2006, 12:05 AM   #24
Tony xa
Tony xa's Avatar
These include S2000, WRX, Evo, 2000GT, Supra, Skyline, RX7, VR-4, 240sx, 200sx, 300zx, etc.
Fair enough .
I have found that alot of people right them off and was just wondering if it was in friendy rivalry or plain and simply because people just hate them .
Tony xa is offline
Old 22-03-2006, 12:09 AM   #25
GTS_300_Coupe
Mandy Moore FTW!
Fair enough .
Well most people here have probably never driven a good well maintained performance import before and have only stuck to their holdens and fords which is why there is bias.
I grew up with Holdens, mates are all import fans, I'm currently with Ford.
Same bias would apply to import drivers who have no respect for domestics.
Old 22-03-2006, 12:10 AM   #26
Rev28K
re
If you were in an auto F6 Typhoon at Winton? Maybe you would be scared....
http://www.fordforums.com.au/showthr...059#post597059
By all means bag ricers but not all four cylinder FWDs are slow (and I hate how Honda's name is dragged through the mud by them).
Rev28K is offline
Old 22-03-2006, 12:15 AM   #27
GTS_300_Coupe
Mandy Moore FTW!
Yeah, actually I dont mind Honda they make some pretty decent cars and they do hold the record for most powerful production NA 4 cylinder in the world.
Honda S2000 makes 250hp from a 2.0 litre 4cyl. Pretty impressive stuff.
Only problem is all these ricer fanboys destroying their image.
Old 22-03-2006, 12:18 AM   #28
xurbanx
xurbanx's Avatar
I guess for me, a car with a bodykit/rims is all nice for eyecandy and oogle at. But theres a thin line when people go overboard, eg/ gtwings on lancers, overdone decals, shopping lists when theres no trace of that brand/product on your car.
But there's also the clean gtr's, supras, rexies, s14-s15's, fd's that really make you go ooh, without the added rice (:
And the reason why I like those kinda of japanese car's is because of friends influence (: Despite me growing up in an all Ford family =D
Dont get me wrong, I love the typhoon/fpv designs (: but I also like the r34's "boxy" sedan look and the fd's curved design (: I know that once my I've paid off my fiesta, i'll be getting hopefully an r34, rx7 or the lancer evo (:
xurbanx is offline
Old 22-03-2006, 12:44 AM   #29
GTS_300_Coupe
Mandy Moore FTW!
This is why I absolutely love skylines. (Especially the last R34s)
If anybody is interested in checking out these 2 videos. Pretty cool stuff.
Skyline Cruise (Side Cam) -20mb
Supra and Skyline have a little fun - 12mb
I dont think these vids are illegal. If the mods find them inappropriate please just delete but they were filmed in the UK and technically they arent breaking any road rules.
Old 22-03-2006, 09:20 AM   #30
mcflux
mcflux's Avatar
Jeez Rollin sure got you hot under the collar!
mcflux is offline
Closed Thread
