Hi all, my first post here
![]() I'm looking at picking up an AU2 or AU3 falcon (AU1 I don't like). I've found one I love. Perfect condition, looks very nice and been looked after really good (private sale). Even comes with all receipts since it was bought new. This is kind of where the problem lies. It's only done 70,000KMs, BUT looking through the receipts there is alot of stuff done which don't reflect this. It's got: * new radiator * new front left wheel bearing * new power steering pump * + whole bunch of other stuff I can't remember. My question is, how do i find out if the odometer has been rolled back on it? I KNOW ALOT of dealers do it, and based on pass experiences, I don't trust many people when it comes to cars. Thanks. |
PM me if you want
Welcome aboard.
OK, what state is the car registered in, i.e. NSW, VIC etc. Got full log books ? How old are the reciepts, years, months days. I dont think you can wind back AU's for the record.
#3 | |||
you can't wind them back but you can put a different cluster in.
TL40 Wagon?
its a bit unlikely to have a rolled back speedo or a new speedo cluster from a private sale unless the owner is mechanicly inclined and does all his own work.
If its a one owner AUII it quite possibly genuine. When was it first registered? |
#5 | |||
PM me if you want
Adapt or perish...
My AUII still has the original cluster and hardly had any work done on it. It could be that this particular one was a little bit of a lemon...
Carless
The information/data about the kms the car has run, is kept inside the cluster. To change the number of kms, you need to replace the e-prom on the cluster, and use an electronic tool to connect to it, to correct the kms. VDO can do this, as they make the cluster, but like to charge you $$$ to do it.
AUIII Falcon Forte, with SIX Appeal Last edited by LG; 24-02-2005 at 03:41 PM. |
#8 | |||
Ute Forum Moderator
![]() Join Date: Dec 2004
I take it there are no odometer readings on the receipts that are higher than 70,000km? Ask why the work was needed, all the things you list are entirely possible. As always, if it doesn't feel right just walk away. There will be plenty more cars to choose from, it is better (& cheaper) to miss out on a bargain than buy a lemon.
#10 | |||
PM me if you want
#11 | |||
#12 | ||
That may be with the older model Fords, or the newer. But with the AU, the kms is only kept within the cluster. It has nothing to do with the ecu.
I know so, because I changed my cluster, and instead of having 90000 kms or whatever, it got sent to VDO to put the correct 5xxxx kms on it.
AUIII Falcon Forte, with SIX Appeal Last edited by LG; 24-02-2005 at 04:31 PM. |
Don't know about BA but EA-AU was stored in the cluster, it'll change if you change the cluster, ECU has nothing to do with it.
#14 | ||
Silhouette AU1 TS50.
Well I have removed the cluster from both my previous AU XR8, and my current AU TS50. Driven the car(s) around and thought the km's would be the same as it was when I removed it, but it wasn't. For example, removed cluster with odo at 55000 km's, drove around for 50 km's, put cluster back in, and odo reads 55050 km's. This proves, to me at least, that there's more to it than just replacing the cluster.
"People can have the Model T in any colour.. so long as it's black." HENRY FORD (30/07/1863 - 07/04/1947) PIC'S OF MY T1 TS50.
#15 | ||
Next upgraded Mk1 Leopard
![]() Join Date: Jan 2005
How are the kms recorded connected to an AU cluster?
If its by a cable, the cable could be disconected a guy could dirve around for years without record any kms, (change gear / guess speed on tac readings) Uncle_Ken |
#16 | ||
PM me if you want
Uncle_Ken since the XF at least they have been electronic dashes no cables
#17 | ||||
#18 | |||
Do you know where it gets the readout from? ![]() |
#19 | |||
AUIII Falcon Forte, with SIX Appeal |
#20 | ||
Thanks for the replies guys.
Reason I asked is because I know to change odometer on AU falcon it's merely a dash change, which are easily bought on ebay these days.... Is it possible to ring up queensland transport and see stuff like registration etc? Reason I'm askign this is, what happens if I buy it, then 6 months down the track try to renew my rego, they see that that rego number and VIN has been wound back and refuse me registration? (Is that even possible?) Or even worse...insurance. I have an accidenal, VIN trace, see it's been rolled back and refuse to cover me... |
#21 | |||
With the XR8, I modified the illumination of the cluster face where everything that lit up white at night, to light up blue. Took a couple of days to finish, so drove around with the cluster off for about 40 km's. Tried the same mod with the TS50 (but only did about 25 km's with it off), but the colour didn't work as good on the TS, as it already lights up a very very light blue. So yeah, this is why I said there's more to it than replacing the cluster as far as winding the odo back on AU's. The best way to prove this would be to get two similar AU's with very different odo readings and swap clusters to see what the read out would be. Example, my odo on the TS has 56000 currently. If I was to swap clusters with another TS50 (series 1) that had say 75000 km odometer reading, would the cluster read 75000 or 56000 km's once it's fitted to my TS50? Or you could try what I did. Disconnect the cluster, do 5 or 10 km's and reconnect, noting the km's before and after.
#22 | |||
First problem with this statement is that the transmission would have no idea of when to change gears. Removing the cluster, or speedo sender will put the car in to limp mode... Which means transmission stuck in 2nd gear, and a number of other problems. This is common knowledge... And has been the case since the good old EAs. Also think of this, the cluster sends the ECU the vehicle speed. There is no direct wiring from the EEC-V to the speedo sender. It all gets routed through the instrument cluster.... Which means How on Earth would the EEC-V, or ANY MODULE know how many Kms the car has travelled ????? ![]() |
#23 | |||||
#24 | ||
i like to be stroked
it can be done, i know someone who works for VDO, always check log books, then some visual things to check, like wear on the steering wheel and peddle rubber, then check rotors for wear and condition of underbody. also u can check speedo reading with recieps like tyre or transmission service, they always write the cars KLMs down on reciept
A good friend will come and bail you out of jail...but a true friend will be sitting next to you saying "Damn...that was fun!" |
#25 | ||
454 Power
i may be wrong here, but didn't someone mention on here a while back that the smartlock feature checks for the instrument cluster and will imobilise the car at a given number of kilometres without it there?
I'm sure i read a thread where someone had to get towed home after making this mistake, may have been on the 'unspoken of' old forum though.... AU has a different type of smartlock too doesn't it?
DAILY - 00 75th Anniversary Futura TOY - 68 SS 454 Camaro |
#26 | |||
#27 | |||
You can check to see if the cluster has been tampered with or get an auto electrician to check it if you are really concerned tho. O |
#28 | ||
not here much anymore
Those who have said the car will immobilise itself without the cluster are correct. Im unsure of how many kms it would take etc etc, but it can do it, and does. This is to prevent people stealing the car, stripping it then dumping it.
As far as i am aware, the ECU does not keep any record of, or control the recording of the kms travelled by the car. Simple way to find out - swap an ECu into your car (eg some of the E series guys put cop ECU's into their cars) - do the kms change? No, they wont. The kilometres travelled by the car are recorded and kept in the cluster itself. The Ford WDS can tell if a cluster has been swapped into a vehicle - the cluster has a code/serial, as does the ECU. Unsure of AU's but on EF's there is actually a sticker on the cluster that has the code written on it. It is possible to make a cluster say it has less kms on it than it has done, but, as LG has said, the only people who can do it are VDO and you would have to have sufficient proof that what you were asking them to do was legal and correct.
RAM 1500
#29 | ||
One way of telling the Kilometres the car has done, is to look at the pedals, a lot of people tamper with the odometers, but never touch the worn rubbers on the pedals..
#30 | |||
Regulator
As for this car, it's not that unusual having a new radiator, wheel bearing and other things at 70,000kms. Some cars have had engines, gearboxes, e.t.c replaced with less than 10,000kms on the clock.
Regards Bobby Current Cars: 2000 AU2 Fairmont (2019-current) 2003 BA1 Falcon Divvy Van (2017-current) 2009 VW Mk6 Golf 118TSi (2020-current) Previous Cars: 2003 MCX10R Avalon VXi (2017-2020) 1995 EF1 Falcon GLi (2016-2019) 1997 XH2 Falcon Van OPT20 (2016-2019) 2006 BF Fairlane Ghia (2013-2018) 2001 AU3 Futura (2010-2013) 1996 EL Fairmont (2008-2010) 2004 BA XR6 (2005-2008) 2001 AU2 Forte (2005-2006) 1988 EA Fairmont Ghia (2003-2005) 1984 AR Telstar TX5 Ghia (2001-2005) |
