Old 21-02-2006, 03:44 PM   #1
Creampuff
149 rwkw of Style
Creampuff's Avatar
Default Top Speed..Honestly!
My father and I are argueing over the top speed of a BA XR6 '04 model..with nothing done to the engine.He read that the top speed is 200kph,I told him I have gone quicker than that........what is the top speed????
Creampuff is offline   Reply With Quote Multi-Quote with this Post
Old 21-02-2006, 03:46 PM   #2
max^power
Formerly au^ute
max^power's Avatar
100-110 in most states
max^power is offline   Reply With Quote Multi-Quote with this Post
Old 21-02-2006, 03:47 PM   #3
Smoke Pursuit
220 i think the BAs Cut out, i think the v8s and turbos maybe 230?
Not 100%, i know its higher then AU.
2022 RAM Laramie 5.7
2023.50 Ranger Wildtrak 3.0 V6 Premium Pack
2024 Everest Sport 3.0 V6 Touring Pack
2025 Mustang Darkhorse 6M Blue Ember + Appearance pack ETA April 25.
Smoke Pursuit is online now   Reply With Quote Multi-Quote with this Post
Old 21-02-2006, 03:48 PM   #4
Keepleft
Mot Adv-NSW
Keepleft's Avatar
122km/h, going any faster results in a fireball, that said if you drive with your fog lights on in clear conditions whilst exceeding 112km/h - that is the start point at which the BA explodes into flames.
Keepleft is offline   Reply With Quote Multi-Quote with this Post
Old 21-02-2006, 03:54 PM   #5
Casper
Contributing Member
Casper's Avatar
Now thats funny!!!!!
Older, wiser, poorer.
Old 21-02-2006, 03:59 PM   #6
micksta
micksta's Avatar
r we talking about the top speed we've gone ?
or the top speed in a BA ?
micksta is offline   Reply With Quote Multi-Quote with this Post
Old 21-02-2006, 04:02 PM   #7
Simmo
White Lightning
Simmo's Avatar
235 cutoff as proven by a mate with an xr6t.
Simmo is offline   Reply With Quote Multi-Quote with this Post
Old 21-02-2006, 04:10 PM   #8
Stampy
: This has been the shortest and funniest thing you have ever posted :
Old 21-02-2006, 04:28 PM   #9
Laminge
Cuban... nothing like it
I was under the impression that if utalising 3 road safety triangles secured on the roof the top speed would be increased to 128 and 118 respectively
: : :newangel: : :
Originally Posted by Laminge
...its amazing how mud sticks to ones shoes, as flies do to the elderly and bottle blondes around fame and fortune...
Laminge is offline   Reply With Quote Multi-Quote with this Post
Old 21-02-2006, 04:33 PM   #10
Casper
Contributing Member
Casper's Avatar
: : :newangel: : :
Heres one we prepared earlier!
No safety triangles (or banana's) were injured in this photoshoot!
Old 21-02-2006, 04:34 PM   #11
max^power
Formerly au^ute
max^power's Avatar
they help with downforce too apparently.
Old 21-02-2006, 04:36 PM   #12
fiery
fiery's Avatar
The problem with this one is they arent on the roof!!!!!!!!!!!
it was said (suggested) the roof.... :
fiery is offline   Reply With Quote Multi-Quote with this Post
Old 21-02-2006, 04:37 PM   #13
Dave_au
Haha, but mate, if only you had spent your money on a fire extinguisher for the car rather than triangles!
Dave_au is offline   Reply With Quote Multi-Quote with this Post
Old 21-02-2006, 04:44 PM   #14
Casper
Contributing Member
Casper's Avatar
Smacking into a BA with a triangle may not put the fire out as fast but it would be a bloody ИИИИ load more enjoyable :
Old 21-02-2006, 04:49 PM   #15
Casper
Contributing Member
Casper's Avatar
Its not a BA. The AU's were far different aerodynamically.. the triangles were set out for optimal AU non fireball speed. BA's need them all on the roof.
Old 21-02-2006, 04:57 PM   #16
fiery
fiery's Avatar
ha ha ha I didnt even actually look at the car in the pic e
So with this info at hand... I must never look at buying a BA (or AU for that matter) if I want to go as fast as I may or may not in my EF :
Old 21-02-2006, 05:03 PM   #17
Ringo
I see you....
Ringo's Avatar
A BA with red and blue coloured lights on the roof would go fastest wouldn't it
Ringo is offline   Reply With Quote Multi-Quote with this Post
Old 21-02-2006, 05:10 PM   #18
Casper
Contributing Member
Casper's Avatar
Triangles dont work on EF's... I have one.
Apparently they fireball under 70kph which is under the operational speed of a triangle (or 3). If you want to go over 70kph in an EF without risk of instant combustion you need to cover the left side of it in teacosies knitted together with zip ties.
Dont worry, could be worse, apparently only thing that stops XF's from fireballing over 63kph is a boot full of rotting sardines.. poor buggers. (They say its water damage to the carpet but we all the truth :hihi: )
Old 21-02-2006, 05:14 PM   #19
M&Ms
M&Ms's Avatar
How fast did you get. I've been in a NA XR6 upto the speedlimiter (not driving), which is a little over 200km/h (Maybe 210)
M&Ms is offline   Reply With Quote Multi-Quote with this Post
Old 21-02-2006, 05:22 PM   #20
Creampuff
149 rwkw of Style
Creampuff's Avatar
a pubic hair off 220
Old 21-02-2006, 05:23 PM   #21
fiery
fiery's Avatar
:monkes:
Old 21-02-2006, 05:30 PM   #22
flappist
The actual limits are:
XR6, 200km/h, XR6T 230km/h, FPV 250km/h.
This is a speed calculated by the ECU based on the rotational velocity of the wheels, so you can actually go a bit faster.
It is important to remember:
1) The analogue speedo reads slightly high on ALL falcons (In my F6, 100=98; GTP, 100=97). The digital one is much closer.
2) The calculation is only approx as the tyres expand and deform due to centrifical force at high speed making them larger and therefore cover more distance per rotation.
The quickest I got my GT-P up to was 254 GPS which was a bit over 260 on the speedo. I haven't been up to NT in the F6 yet.
Old 21-02-2006, 05:32 PM   #23
Sourbastard
Contributing Member
Sourbastard's Avatar
Why not have a worthwhile argument.
If I kick a midget in the balls from a 15 foot run up, how many times will he rotate until he lands on the highway? What will his peak velocity be? And will the truck that runs him down be red?
1965 XP Falcon Deluxe Sedan
2003 BA Fairlane G220
Old 21-02-2006, 05:33 PM   #24
WILDTRAKPX2
WILDTRAKPX2's Avatar
Love it!
WILDTRAKPX2 is offline   Reply With Quote Multi-Quote with this Post
Old 21-02-2006, 05:34 PM   #25
Bucknaked
Bucknaked's Avatar
I know of someone who has an FPV and had the car near the top speed. Up the top end as well.
Old 21-02-2006, 05:52 PM   #26
divine_afg
Extreme_Custom
divine_afg's Avatar
whats the top speed for a AU falcon S ?. 180 speedlimited or 200+
If You Think AU Are Ugly ! Check my X Out.........
Loved by one ... Admired by many ... Envied by most !
RIP - F6
divine_afg is offline   Reply With Quote Multi-Quote with this Post
Old 21-02-2006, 05:58 PM   #27
ef_classic
ef_classic's Avatar
The base model is limited to 180, not sure about S.
ef_classic is offline   Reply With Quote Multi-Quote with this Post
Old 21-02-2006, 06:12 PM   #28
Redrum
Force Fed Fords
Redrum's Avatar
The BA MK2 T goes at least 235kmph.
2021 Focus ST-3 Mountune Enhanced
Redrum is offline   Reply With Quote Multi-Quote with this Post
Old 21-02-2006, 06:49 PM   #29
Casper
Contributing Member
Casper's Avatar
For the record (this applies to AU1, 2 and 3 and is the rule.. but there are odd exceptions.. rare but true).
All AU Utes of any kind (including Tickfords and Pursuits) - 180kph
All LWB of any kind (Wagons, Fairlanes, LTDs and TL's) - 180kph
All NON Tickford badged Sedans (including the S) - 180kph
All Tickford Sedans (XR6, XR8, TE and TS) - between 210kph and unlimited.
Old 21-02-2006, 06:59 PM   #30
stockel
stockel's Avatar
lol thats some good ИИИИ covering there. :
stockel is offline   Reply With Quote Multi-Quote with this Post
