Old 11-02-2006, 01:00 PM   #1
64compact
Default limp home MODE
All the new cars will go in to limp home mode if you blow a tail/stop light, this is because of accidents in fog and snow conditions and cars driving with out the necessory rear lights, all Euro cars coming out this year have this "FEATURE", Nissan, Astra, Focus, Volvo, Merc, Mitisbushi,etc also as it has been the law in Europe for some time that if you are pulled over you must be carring a full set of replacement globes and 2 safty vests. it won't be long before it comes in here, so if it is in limp home , go and check your tail lights,
64compact is offline   Reply With Quote Multi-Quote with this Post
Old 11-02-2006, 01:05 PM   #2
Casper
Contributing Member
Casper's Avatar
Doesnt apply to either my EF or my AU.
How new is NEW?
Older, wiser, poorer.
Old 11-02-2006, 01:07 PM   #3
64compact
How new is NEW?
i did say NEW Cars! EF is 12 years old
Old 11-02-2006, 02:43 PM   #4
Sprint347
Tickford
Sprint347's Avatar
scary huh...
ED XR8 Sprint - 306ci SBF, GT40, Comp XE270, T5, 3.45 LSD
AU T3 TS50 - 345ci SBF, AFR 185, Comp XE274, 2800 stall, ESS LE97, 3.45 LSD
BA XT
SZ Territory TS RWD TDCi
Sprint347 is offline   Reply With Quote Multi-Quote with this Post
Old 11-02-2006, 10:37 PM   #5
XR6Dan
Why??
XR6Dan's Avatar
Fine for Europe - bugger all snow here...
Wouldn't this cause more problems and acidents - people stopped on a freeway to change a bulb?
XR6Dan is offline   Reply With Quote Multi-Quote with this Post
Old 11-02-2006, 10:54 PM   #6
AnthonyQLD
Boss power
AnthonyQLD's Avatar
You would think so. :
:the_finge BOSS 260+ :the_finge
AnthonyQLD is offline   Reply With Quote Multi-Quote with this Post
Old 11-02-2006, 11:01 PM   #7
Paxton
Cobblers!
Paxton's Avatar
Not applied to my Territory. I blew a break Light about 6 months ago. I was told during a RBT to get it fixed.
The Only LHMs that I know of is in the Gearbox and Coolant Systems in the 4.0 DVCT engines. I can't remember if the AU had the same 'feature'.
Ego BFII Ghia
Titanium Silver E53 X5 4.4i
Gunmetal EF XR6. Now retired from active duty.
Roses are red. Violets are blue. OS X rocks. Homage to you.
Paxton is offline   Reply With Quote Multi-Quote with this Post
Old 12-02-2006, 12:18 AM   #8
JC
JC's Avatar
Yes, the AUs have the gearbox one, and the AU 6s have coolant one.
So this thread is a warning not to drive behind new cars? Or only those that don't have working tailights?
Ford Performance Club ACT
Old 12-02-2006, 07:09 AM   #9
YOOT
YOOT's Avatar
I think the ADR's would have something to say about this. You can see it now, accelarating into traffic and a bulb blows and your car dies, and that big semi that you were trying to get out of the way of crushes you and your family in you NEW car. :
I think all they need is a warning light on the dash when one filament goes. My 1982 Subaru had one, when the either of the filaments blew, a sop lamp warning appeared on the dash. Simple and effective. :
YOOT is offline   Reply With Quote Multi-Quote with this Post
Old 12-02-2006, 08:22 AM   #10
fiery
fiery's Avatar
Are you saying EF's are getting on the 'older side' now........
how rude :
you mustn't be talking about mine anyway cos she is only 11 this year :
fiery is offline   Reply With Quote Multi-Quote with this Post
Old 12-02-2006, 10:41 AM   #11
ltd
Force Fed Fords
ltd's Avatar
Mate, limp home mode first made its debut in the 4 speed EA2 gearbox. It was designed to keep fluid temperatures from going to extreme, and would rectify itself as soon as the engine coolant and thus transmission fluid came back to within normal operating perameters. It also occurred when there was an electrical fault within the transmission ie, one of the seven solenoids going on the fritz.
If brains were gasoline, you wouldn't have enough to power an ants go-cart a half a lap around a Cheerio - Ron Shirley
Powered by GE
ltd is offline   Reply With Quote Multi-Quote with this Post
Old 12-02-2006, 11:48 AM   #12
falcon91
falcon91's Avatar
Not wanting to hi-jack this thread, but on the subject of brake lights. Is it my imagination or do vehicle bulbs fail more often now than in the past. The amount of cars that I follow with one or both brake lights U/S is unbeleivable.
On a lighter note, I have found that nearly all Volvo's are permanently in limp mode around here. (Automatically goes into limp home mode when hat is placed on head)
falcon91 is offline   Reply With Quote Multi-Quote with this Post
Old 12-02-2006, 11:54 AM   #13
fiery
fiery's Avatar
My poor car doesn't understand limp home mode strangely enough, but she had to try to cope last night..
What shouldn't have taken more than an hour & half (hardly any traffic)...took a few hours :(
:yeees:
Old 12-02-2006, 12:11 PM   #14
pauljh74
pauljh74's Avatar
The light bulb problem seems to be common on many newer cars. I've read somewhere it can be due to insufficient earthing that can lead to frequent globe failures. On my EL I've replaced both headlight bulbs 18 months ago and the front parking light bulbs (EL XR6 they are separate) a year or so prior. I don't recall replacing any tail light or indicator bulbs and the car has reached 113000 kms, and I bought it at 48000 kms. Yet I see many current model cars from many manufacturers with one or both tail lights blown with the high mounted stop light the only one working and many driving around with 1 headlight.
But I think a limp home mode in these events would be more dangerous as in low visibility conditions with one or more lights not working also travelling in limp home mode would be a sitting duck for a high speed rear ender. Another "safety" feature I find annoying is with autos having to be put in park to be started. Fair enough not in drive or reverse, but neutral should be OK. I was driving an auto VP Commy wagon on gas (a loan car) that was well used and driving along a driveway about to reach a main road I lifted off the throttle and it stalled. I had to stop it and put it in park to get it going again.
Originally Posted by Mark Webber
Not bad for a #2 driver
Mark Webber after winning the 2010 British Grand Prix.
pauljh74 is offline   Reply With Quote Multi-Quote with this Post
Old 12-02-2006, 02:14 PM   #15
ltd
Force Fed Fords
ltd's Avatar
The advice I received for globes that frequently blow, is to buy the globe from ford. I had a DL that was always blowing its rear left brake light, and I spent countless hours changing the bastard. Seriously, it would blow every 200-1500klms without fail. A mate who was the auto electrical foreman at city ford told me to use the genuine ford globe, as the astar ones are made in taiwan, and the filament is not as good. I took his advice, changed it over and got 70 thousand plus k's out of it.
It's the same as their oil filters. In the 5 litre windsors, the ryco filters would sometimes seperate from the baseplate and dump oil everywhere. I remember a number of EL's had the same problem. Turns out the pressure valve in the filter was rated too high for the loads and would allow oil pressure to build inside the filter to the point of explosive separation.
Sometimes genuine ford is really cool.
Powered by GE
Old 12-02-2006, 09:27 PM   #16
64compact
i was just passing on the information as it happened to a nissan pulsar the other day and when it was enquired why, the reply from Nissan Japan was "oh didn't you know that all new cars made for the world market have this feature". the Fords Focus and Transit etc their PCM's are made in Spain and The volvos is made in Ireland and the rest of the non south Pacific cars are made in Japan of course except those made by the Sweeds. another small bit of trivia is the Transit workshop manuals, the mechanical section is produced in england, and the electrical section is produced in Spain, all with different Acromens or names for the different parts. eg the PCM in england is the Vehicle control Module in Spain, so be preparied to be very confuesed.
Old 12-02-2006, 09:30 PM   #17
64compact
how rude :
don't worry i have a EF wagon and i love it to bits, also had a EF fairmont Ghia, what a car, Loved it almost as much as the 64 compact i had for 16 years.
Old 12-02-2006, 09:35 PM   #18
fiery
fiery's Avatar
I'm actually struggling to 'love' her today... seriously irritating me atm!!! :
