29-01-2006, 11:15 PM | #1 | ||
[ 5L ]
hey i just fitted a new battery today and as the computer re-learnt itself the idle has dropped to 500rpm is there any reason for this, i have takin it for a long drive to see if it goes back up and nothing (idle use to be at 800rpm). this actually caused my car to stall also- as i was coming to a stop i put the clutch in and turned the steering wheel and it died. so what is the best way to adjust the idle speed, cheers fellas
[ 5L ] 2001 AU series 2 xr8, 220kw, 5speed, leather interior, premium sound, narooma blue, cat back exhaust, k&n filter,willall edit,MSD coil packs, MSD leads, monroe gt gas shocks, superlow kingsprings 187rwkw (mainline) www.ignitionimages.com
30-01-2006, 12:54 PM | #2 | ||
[ 5L ]
so no one knows
30-01-2006, 01:00 PM | #3 | ||
Shoot.
I don't know exactly myself mate, but there should be a couple of threads on the same thing. But you need to get into diag? mode but connecting two pins, and then go through a particular procedure.
20V Turbo |
30-01-2006, 01:30 PM | #4 | ||
[ 5L ]
couldnt u just tighten up the throttle cable to adjust it, i have had a look on the throttle cable and i can tighten up the top of it but then it goes to the spring and i cant tighten up the bottom bit.
