Old 27-01-2006, 02:22 PM   #1
coop1er
Default 92 telstar tx5
Hi there.
I have just purchased a 92 Telstar Ghia tx5 V6 with manual transmission.
I am wondering what are common problems with these vehicles or is there
anything in particular to watch out for? Any other advice will be appreciated
too.
Thanks.
coop1er is offline   Reply With Quote Multi-Quote with this Post
Old 11-02-2006, 02:08 PM   #2
Mr_Mordred2095
i've got one, first thing that died was the gearbox.
the engine's take a lot of torture. (mines stock and I had it at 7750rpm).
Mr_Mordred2095 is offline   Reply With Quote Multi-Quote with this Post
Old 04-03-2006, 12:57 AM   #3
Jock
Service Optimist wannabe
Jock's Avatar
Hey, I had a '93 V6 manual. I had the rocker gasket leak oil into the rear bank's plugs (externally) - cost a bit to get fixed. I had to replace the lower control arms the bushes were worn out- genuine parts were like poison so equally oK non genuine ones were put on for a lot less.
Unlike the previous post, the gearbox was fine though the clutch was tired when I sold it. ALso the exhaust was on the fritz. The short runs kill any exhaust so do another run around the block to warm it through & dry out the condensation.
Check the outer CV boots for splits too. That was up till 162k when I sold it. Brake pads lasted 140k and the thing went like a stung cat. The best car I have owned bang for buck though the Territory seems good for the tasks now at hand.
TX5? Great car.
Regards,
Jock
Jock is offline   Reply With Quote Multi-Quote with this Post
Old 08-03-2006, 08:18 PM   #4
coop1er
Thanks for the replies. So far I have had to replace the front engine roll
mount and I also did the timing belt. No problems with the gearbox at this
stage but there is a slight knock from the rhf so I might check the control
arm bushes and ball joints. I also had a problem with one of the VRIS
solenoids but fixed that with a $20 replacement from the wreckers. I do
love the engine, its got good grunt down low, and pulls strongly and smoothly
to redline.
