Old 26-01-2006, 01:11 PM   #1
Mr. CVE
If it aint Blown it Sucks
Mr. CVE's Avatar
Default what's a good octane booster ?
my car has a slight ping, and I want to drag it on saturday.
I may not have time to get it on the dyno to retune it before then.
I run mobil synergy 8000, so is a good fuel.
even on BP Ultimate is does as well.
won't try any other fuels, as I don't think they are as good.
but just some octane boost for sat and I can fix it next week.
So .. what works well for you ??
Australia's fastest 3V n/a Ghia 13.52 @ 102 mph
@235 rwkw !!
Now turbo 11.77 @114 mph
320 rwkw, 810 nm torque, 280rwkw @3000 rpm !! :thebirds:
Now for sale
http://www.fordforums.com.au/showthread.php?t=11296772
Thanks to Snort Performance, Headsex and CVE
Street car DeTomaso Pantera
Drag car 1995 Mustang, Haleys Comet ( It's back !)
Power by CVE
Melbourne's first SNIPER Tuner :
Now tuning E series
Mr. CVE is offline   Reply With Quote Multi-Quote with this Post
Old 26-01-2006, 01:14 PM   #2
Mark351
Built Ford Tough
Mark351's Avatar
The Nulon Octane booster seems to work fine.
Black on white '83 SWB F100 C6 auto 351C on gas and on the ground --> Project Thread
'55 F100, just a roller at the moment, new project
Silver MY12 Volkswagen Amarok
Mark351 is offline   Reply With Quote Multi-Quote with this Post
Old 26-01-2006, 01:18 PM   #3
AU1XLS
AU1XLS's Avatar
Nulon Pro Strength
AU1XLS is offline   Reply With Quote Multi-Quote with this Post
Old 26-01-2006, 03:00 PM   #4
ltd
Force Fed Fords
ltd's Avatar
Naptholene otherwise commonly known as Moth Balls. It's not an old wives tail, I saw it done on Mythbusters
If brains were gasoline, you wouldn't have enough to power an ants go-cart a half a lap around a Cheerio - Ron Shirley
Powered by GE
ltd is offline   Reply With Quote Multi-Quote with this Post
Old 26-01-2006, 03:11 PM   #5
Lukeyson
Right out sideways
Lukeyson's Avatar
Nulon or Red +104
2010 FG XR50 Turbo | 2007 FPV BFII GT, BOSS 302
Lukeyson is offline   Reply With Quote Multi-Quote with this Post
Old 26-01-2006, 03:25 PM   #6
SSBUB
SSuper SSpy
SSBUB's Avatar
nulon pro strength...increases RON by 7 points...so ultimate/synergy being 98 octane it will make 105 RON....well, so they claim anyway, but i have used it before its not too bad...be warned though, dont get it on your paint - it strips it quicker than you can say 'crikey what was that'
SSBUB is offline   Reply With Quote Multi-Quote with this Post
Old 26-01-2006, 03:41 PM   #7
dynosteve
Dyno Tuner
dynosteve's Avatar
nulon pro strength in our testing is the best
dynosteve is offline   Reply With Quote Multi-Quote with this Post
Old 26-01-2006, 04:08 PM   #8
svo347
AFF's 1st DM.......
svo347's Avatar
NitrousFormula in the BLACK bottle!!!
Alloy headed 347ci EDXR8
13.21 @107.7mph
Originally Posted by zetec
Old 26-01-2006, 07:15 PM   #9
brodfloyd
Hmmmm
methanol
brodfloyd is offline   Reply With Quote Multi-Quote with this Post
Old 26-01-2006, 07:29 PM   #10
Mr. CVE
Mr. CVE's Avatar
Originally Posted by brodfloyd
methanol
methanol doesn't mix with fuel
@235 rwkw !!
Now for sale
Power by CVE
Now tuning E series
Old 26-01-2006, 09:35 PM   #11
ltd
Force Fed Fords
ltd's Avatar
Aviation Fuel.
Cheaper than nulon and 130 octane.
PS, don't get Jet A1 as this is just Kerosene with a couple of additives.
Powered by GE
Old 26-01-2006, 09:37 PM   #12
ltd
Force Fed Fords
ltd's Avatar
Oh BTW, get it at essendon airport and tell the bloke you have an ultra light that you are needing the fuel for, otherwise they won't sell it to you.
Powered by GE
Old 26-01-2006, 09:38 PM   #13
Mr. CVE
Mr. CVE's Avatar
130 octane for avgas, u wish !!
plus is leaded, bad for cats
plus avgas is too slow burning
@235 rwkw !!
Now for sale
Power by CVE
Now tuning E series
Old 26-01-2006, 10:06 PM   #14
ltd
Force Fed Fords
ltd's Avatar
Man, the stuff we get in sydney is rated at anywhere between 115/130 octane. Avco Lycoming and Continental Engines insist on a minimum octane rating of 120. Mobil have the highest rating as well. Also, I wasn't aware you had cats, I though your V8 capri might have been an old worked cleveland without cats or something. Actually, my mate had an old XE 4.1 that was missing on two cylinders, and we ran a 50/50 mix of avgas and leaded in it, absolutley screamed.
Powered by GE
Old 26-01-2006, 10:09 PM   #15
buickman
buickman
buickman's Avatar
Which car are you running the BA Ghia as I don't think our Capri would run a cat. Has anyone used the Shell ultimate with 100 octane rating?
Old 26-01-2006, 10:13 PM   #16
HEMI POWER
N/A BOSS 390+
HEMI POWER's Avatar
Nulon Pro Strength.Works great in the clevo with no pinging issues.I have also been mucking around with Shell Extreme without octane booster, works quite well too.
WOOOOOOOOOO
FPV GT 03 /341 RWKW OF N/A POWER.
XB GT 73 /OLD FORD MUSCLE
ALL AUSSIE MUSCLE
HEMI POWER is offline   Reply With Quote Multi-Quote with this Post
Old 26-01-2006, 10:13 PM   #17
Mr. CVE
Mr. CVE's Avatar
this is the ba,
i will try the nulon max strength and see what happens
@235 rwkw !!
Now for sale
Power by CVE
Now tuning E series
Old 26-01-2006, 10:37 PM   #18
brodfloyd
Hmmmm
i didnt say mix it with anything, did i?
as the great Niki Sixx says, diluting anything is a crime
Old 26-01-2006, 10:39 PM   #19
Mr. CVE
Mr. CVE's Avatar
ok,
done that now it runs ultra lean !!
oh that's right methanol runs at 6:1, may need a bigger pump and inj.
@235 rwkw !!
Now for sale
Power by CVE
Now tuning E series
Old 26-01-2006, 10:42 PM   #20
TUF514
octane boosters in a bottle dont work.
However, hehehe, the company i work for uses alot to toluene! 114 octane......
Mix it 30/70 tol/premium and youve got about 103 octane average....... this ИИИИ works a treat!
but make sure you have hardened seates hehehe...........
i can get this for people if they live in the brisbane area. Email me for a price.....
TUF514 is offline   Reply With Quote Multi-Quote with this Post
Old 26-01-2006, 10:54 PM   #21
brodfloyd
Hmmmm
ok,
whats a fuel pump and injectors when u have 2000 horsepower?
Old 27-01-2006, 11:30 AM   #22
ebxr8240
Performance moderator
ebxr8240's Avatar
ok,
Yep multiply fuel delivery by 4...
Daily driver GTE FG..
Old 27-01-2006, 11:59 AM   #23
Des
V8 Rock'n'Roll....
Des's Avatar
Location: You got me Rootin' like a Hog, Barkin' like a Dog, Climbing trees and Jumping logs....
Add a touch of nitro, works a treat in the whipper snipper....
1 owner 03 BA XR8 Manual Sedan
208.8 rwkw stock, update soon
20x8.5 fr 20x10 rr
Rumble thanks to:
Sureflo Exhaust - Stainless Cat's & 3.5in single catback system
"Tell 'em the guy with the Blue Mohawk sent Ya"
Des is offline   Reply With Quote Multi-Quote with this Post
Old 27-01-2006, 01:55 PM   #24
Mr. CVE
Mr. CVE's Avatar
nitro actually lowers the octane rating, that is why you mix it with alky.
@235 rwkw !!
Now for sale
Power by CVE
Now tuning E series
Old 27-01-2006, 02:01 PM   #25
dansedgli
dansedgli's Avatar
Ive got a 4 litre bottle of stuff called Stealth if you want to give it a go. It is oxygenated so Im not sure if it would work well without a tune though. The guy that fitted my turbo gave it to me when I had the AU.
There is a website for it somewhere but i cant find it. Ill have to get the website for you when I get home.
Turbo AU ute ~ Nice legs, shame about the face. 282rwkw at 15psi.
dansedgli is offline   Reply With Quote Multi-Quote with this Post
Old 27-01-2006, 02:07 PM   #26
henry 351
Punch it baby, punch it.
henry 351's Avatar
Location: Working hard. If you work hard you get the goodies.
I think you'll find Avgas hasn't had lead in it for quite a few years now...
"Sweat saves blood. Blood saves lives. Brains save both" Erwin Rommel.
henry 351 is offline   Reply With Quote Multi-Quote with this Post
Old 27-01-2006, 02:08 PM   #27
HEMI POWER
N/A BOSS 390+
HEMI POWER's Avatar
this is the ba,
I have used the Nulon in the BA aswell,works great.It will defanately stop the pinging.
WOOOOOOOOOO
ALL AUSSIE MUSCLE
Old 27-01-2006, 03:38 PM   #28
gozza
gozza's Avatar
avgas is 101 low lead
gozza is offline   Reply With Quote Multi-Quote with this Post
Old 27-01-2006, 03:40 PM   #29
gozza
gozza's Avatar
thats what we used in the single prop 152-172's cessnas anyway
Old 27-01-2006, 03:55 PM   #30
LTDHO
The one and only
LTDHO's Avatar
Sure?
The reason it's banned is because it's leaded!
Tuned by CVE Performance
