16-01-2006, 02:59 PM | #1 | |||
AFF's 1st DM.......
Ok got a q...
I recently had another phoneline dedicated to the internet in my room it has its own number, as i used to run a long ext line from the living room to the computer and finally got fed up with it. Now if i used a splitter and connected both the lounge room line and the new line, would the speeds be any quicker? :sm_headba Cheers.
FORD GIVING POWER TO THE PEOPLE Alloy headed 347ci EDXR8 13.21 @107.7mph Quote:
16-01-2006, 03:01 PM | #2 | ||
Foo Fighter
I'm not expert, but I doubt it.
16-01-2006, 03:38 PM | #3 | ||
Right out sideways
highly doubt it with ADSL
2010 FG XR50 Turbo | 2007 FPV BFII GT, BOSS 302 |
16-01-2006, 07:26 PM | #4 | |||
Regular Schmuck
There used to be software to combine the bandwidth of two dialup connections to one service, but if you wanted to do something similar with ADSL then you'd have to get ADSL turned on the 2nd line and essentially pay for 2 services and 2 modems. |
16-01-2006, 07:37 PM | #5 | |||
AFF's 1st DM.......
the second line has been adsl enabled, do i really need to use a filter on the line dedicated to the comp only?
16-01-2006, 07:42 PM | #6 | ||
Force Fed Fords
I run up to eight computers off my switch which is attached to modem. Only one pc has had disc from bigpond installed.
512k ADSL
2021 Focus ST-3 Mountune Enhanced |
16-01-2006, 08:00 PM | #7 | |||
AFF's 1st DM.......
Me 3 just bought a Netgear DG834v2 modem/router but only run the one comp off it.
16-01-2006, 08:11 PM | #8 | |||
You gotta pay to play
ie: telephone, alarm, fax,etc. if you use a filter on the ADSL you will stop it from working.
Regards Gilesie AU I Forte Wagon 4.0 Dodge D5N Twincab (Project) 2003 Mazda Bravo (work truck) 1979 F100 Ambo |
16-01-2006, 09:27 PM | #9 | ||
you could also get a wireless adaptor for the 2 computers... saves you having the extra phone line cost each month.
let me know if you are interested, its easy to setup
Powered by Rollin Motorsport Turbo Barra ED 4L
16-01-2006, 10:54 PM | #10 | ||
Formerly au^ute
So do you want to aggregate the two ADSL lines or do you want to use a shorter cable?
Big difference in cost and speed. |
16-01-2006, 10:56 PM | #11 | |||
AFF's 1st DM.......
Bring BOTH adsl lines into a single line into the modem/router then into the comp from there
16-01-2006, 11:24 PM | #12 | ||
Formerly au^ute
if your modem supports it you've got a good modem. you need expensive gear for that. plus you need two services. is the extra 1.5mb really worth it? why not just get cable?
16-01-2006, 11:26 PM | #13 | |||
AFF's 1st DM.......
Cable hey hmmmm.
16-01-2006, 11:29 PM | #14 | |||
AFF's 1st DM.......
I already have the 2 services connected and currently both working.
just wondered if i could thats all ...
16-01-2006, 11:30 PM | #15 | ||
Formerly au^ute
optus was 10mb when i had it a few years ago, and it flew. makes ADSL look crap. i only gave it up because of the pathetic download limits... look into it, it's certainly much quicker than two adsl lines, and about the same as what you'd pay for a good adsl line.
16-01-2006, 11:39 PM | #16 | |||
AFF's 1st DM.......
Cheers mate....
16-01-2006, 11:50 PM | #17 | ||
Formerly au^ute
not a problem. good luck with it.
17-01-2006, 08:04 AM | #18 | |||
Regular Schmuck
17-01-2006, 09:32 AM | #19 | ||||
17-01-2006, 04:13 PM | #20 | |||
Regular Schmuck
ADSL2 is actually faster than cable and has the benefit of not sharing a connection to the provider with other subscribers on the same cable. |
17-01-2006, 07:20 PM | #21 | ||
Formerly au^ute
ADSL2 is still being rolled out. It's not as readily available as Cable. It's easy to suggest it, but in reality, not many people can actually get it. iinet pretend you're getting it by calling their plans broadband2 or whatever... but you're still getting plain old adsl, unless you're in the right area.
svo wanted more speed, i know where i live and many many people i support cannot get adsl2, but they can get cable. Sure, it's shared, but the majority of customers on 1.5mb adsl plans dont actually get that either... so you can't really compare a theoretical 1.5mbit/s limit to a real 1.5mbit/s transfer rate. Cable is still worth a look in my opinion. The only drawback with cable is the lack of competition, hellstra or optass. :( Either way, better than the misleading marketing of iinet companies... |
17-01-2006, 08:22 PM | #22 | ||||
Regular Schmuck
Iinet call their ADSL2 plans broadband2 and their ADSL plans broadband1. Check their site. Quote:
I just ftp'ed a file at 8:12pm while downloading torrents at around 115k/sec right now, but that'll dip soon when I strangle my upload speed. :P 226 Transfer complete. ftp: 13631488 bytes received in 19.28Seconds 707.03Kbytes/sec. I came from Telstra and their crappy plans to iinet and I couldn't be happier. If I was looking for more speed, I'd be looking at either cable or ADSL2 provider that can connect, paying double for 2 connections isn't exactly the best way to go. |
17-01-2006, 08:27 PM | #23 | |||
Formerly au^ute
I'd say you're a lucky one Rodp, i sometimes get full speed with my torrents, but not often ill reach 100% capacity. I was only trying to point out that not everyone will get 100% link every time. |
17-01-2006, 08:58 PM | #24 | |||
Regular Schmuck
I grabbed a file off ausgamers a few minutes ago and my modem must have resynched to a higher speed than last time I checked because it came down at 1.3Mb/sec. I'd be surprised if someone was on an iinet 1.5Mbit plan and didn't get full speed if the remote server they were connected to and its path had more than enough bandwidth. |
17-01-2006, 09:03 PM | #25 | ||
Formerly au^ute
microsoft sites work well for me too such as windows update etc
17-01-2006, 09:37 PM | #26 | ||
Wait till you're exchange gets upgraded to ADSL2+ (up to speeds of 24Mbps). That's your best bet (and depending on what exchange you're on - you might have it already). It's availability is growing very very rapidly.
Dispite what anyone says - iiNet offers a great product (among many other ISP's that now start to offer ADSL2+). People that get upset usually just couldn't read or understand product info. Last edited by Deadman; 17-01-2006 at 09:47 PM. |
