Old 14-01-2006, 04:49 PM   #1
svo347
AFF's 1st DM.......
svo347's Avatar
Default Connecting new HardDrive...??
Ok Fordfans Im in need of assistance.
I have recently bought a 160gig h/d for me comp as the old one is full and is only 40gig.
Alrighty, i have set the new onto slave i believe and have connected the power and ribbon cable.
So what now?
If i go into my computer its doesnt show up as me other "C" drive does, If i go into control panel, system and Device manager it shows up underneath the original drive but how do i store stuff on it, there seems to be no dramas nor is there a yellow exclaimation mark :
Help.......
Alloy headed 347ci EDXR8
13.21 @107.7mph
Originally Posted by zetec
Old 14-01-2006, 05:21 PM   #2
max^power
Formerly au^ute
max^power's Avatar
click start, then run, then type in diskmgmt.msc and click ok
Find the new drive in there and creat a partition on it then format it. a wizard may pop up, may not.
max^power is offline   Reply With Quote Multi-Quote with this Post
Old 14-01-2006, 05:29 PM   #3
Captain Stubing
Looking for clues...
Captain Stubing's Avatar
Did you change the BIOS settings to tell the computer that it has a new drive to look at?
Captain Stubing is online now   Reply With Quote Multi-Quote with this Post
Old 14-01-2006, 06:07 PM   #4
joshf2
striped
joshf2's Avatar
is this the same as;
control panel -> administrative tools -> computer management -> storage -> disc management
thats how i did it for my other hdd
joshf2 is offline   Reply With Quote Multi-Quote with this Post
Old 14-01-2006, 06:08 PM   #5
svo347
AFF's 1st DM.......
svo347's Avatar
Errr set bios as primary slave.. for that h/d
13.21 @107.7mph
Old 14-01-2006, 06:17 PM   #6
svo347
AFF's 1st DM.......
svo347's Avatar
ok ok ...
how would one utilise the 40 gig h/d for like windows xp pro programs and the like, and just leave the other for pics doc etc...
13.21 @107.7mph
Old 14-01-2006, 06:33 PM   #7
roodog aus
Originally Posted by svo347
ok ok ...
If you have the drive setup correct you should see both drives in 'my computer'
Just copy as much of the junk ie pics docs etc. over to the new drive.
Save everything to the new drive from now on.
roodog aus is offline   Reply With Quote Multi-Quote with this Post
Old 14-01-2006, 06:36 PM   #8
svo347
AFF's 1st DM.......
svo347's Avatar
Thankyou Fellas.... Muchly appreciated.
13.21 @107.7mph
Old 14-01-2006, 09:03 PM   #9
max^power
Formerly au^ute
max^power's Avatar
It's the same, but much quicker :
Old 15-01-2006, 01:53 AM   #10
pauljh74
pauljh74's Avatar
Initially I thought this might be a compatibility issue, but as I read down the posts it's all sorted and seems it all works, but one thing for others sticking newer larger hard drives in older computers - check the motherboard supports drives of that size. My mate has an NForce2 motherboard with an AthlonXP 2500+, so it's not that old but it supports a maximum of 120GB only - with no further BIOS updates available. At the time of his last hard drive purchase, we were looking at getting a 160GB drive - had to downgrade that to ensure it was supported.
Originally Posted by Mark Webber
Not bad for a #2 driver
Mark Webber after winning the 2010 British Grand Prix.
pauljh74 is offline   Reply With Quote Multi-Quote with this Post
Old 15-01-2006, 05:35 AM   #11
AU-Hog
AU-Hog's Avatar
If you are running Windows 2000 you would probably need to do a small change the registry to enable creation and use of a partition larger than about 120 GB on a drive that is larger than this. Windows XP has this setting enabled by default.
AU-Hog is offline   Reply With Quote Multi-Quote with this Post
Old 15-01-2006, 01:28 PM   #12
joshf2
striped
joshf2's Avatar
but what if ive lost my keyboar......
nope, found it now
Old 15-01-2006, 02:38 PM   #13
pauljh74
pauljh74's Avatar
WinXP needs SP1 to enable the OS to see larger than 120GB drives. FAT32 file systems allow partitions up to 32GB. You need to use the NTFS file system to allow 32GB+ partitions in XP
Old 16-01-2006, 09:39 AM   #14
red_october
Go on, be a monkey....
red_october's Avatar
Did you set the jumpers on the 2nd HDD to be slave?
red_october is offline   Reply With Quote Multi-Quote with this Post
Old 16-01-2006, 11:40 AM   #15
svo347
AFF's 1st DM.......
svo347's Avatar
Yes mate, what would happen if i set them both to master?
13.21 @107.7mph
Old 16-01-2006, 11:58 AM   #16
pauljh74
pauljh74's Avatar
Probably wouldn't see either drive - maybe one if you're lucky
Old 18-01-2006, 11:56 AM   #17
mo eltlaser d
If you have a problem with the OS not wanting to recognise a large HDD because of hardware limitations or whatever try going to the HDD manufacturers website as most have a small downloadable utility that lets you trick the pc into accepting the larger harddrive.
If both HDD's are set as Primary Master you would be lucky if the pc started at all.
Old 18-01-2006, 08:20 PM   #18
megsy
Undergraduate EB Operator
megsy's Avatar
garenteed it wont i will just display a message saying it cant find any operating systems. in an ideal world you should try to make both the Hard drives primary on their own peice of ribbon( if you know what i mean) rather than have them as slaves. this may or may not be possible with how the hard drives are sitting in the tower ect but thats how it shoule be.
Simon
04 BA Xr6 ... now with carpark dints
megsy is offline   Reply With Quote Multi-Quote with this Post
Old 19-01-2006, 02:52 AM   #19
mo eltlaser d
Yes, very true.
