View Poll Results: Should Boss owners change there Valve springs and be called unopened like the LS1's ( | |||
Should Boss owners change there Valve springs and be called unopened like the LS1's (level playing field) |
20 | 34.48% |
No, if you change valve springs you are 100% opened |
38 | 65.52% |
Voters: 58. You may not vote on this poll |
LS1 owner
hey guys just a quick question what is the Quickest Bolt on XR8 in aus ?
thanks guys BTW this is not a ****ing contest just want to prove a Point to someone that the Boss is good for the 1/4 times as well, and as they say if you want the truth then go to the horses mouth.
VX Berlina |
beep beep
12.69 i think was recorded by Chris at Blue Power Racing Developments in his BA XR8 ute (auto). Intake, exhaust, edit, probably underdrives....
I think last friday he did a 12.74 and blew the auto just after 200metres. It's going to have the engine opened and played with now... so in my opinion it will be the first 'properly opened' XR8.
Nothing to see here, move along, move along... |
#3 | |||
Your on the money Parawolf, But I think Chris is pretty determent to get a 11sec 1/4 before he opens it up. Chris has a few more tricks up his sleave that he want to try out before he cracks it open. EDIT: The Holden girls are going to hate Chris when he gets his 11 sec pass in an unopen Boss 260 |
#4 | |||
LS1 owner
VX Berlina |
#5 | |||
beep beep
Though with a high stall it could go better I guess...shesh I guess he really wants to break those CV joints!
#6 | ||||
#7 | |||
Location: Working, chasing after my daughter and working
#8 | |||
LS1 owner
VX Berlina |
#9 | |||
Gota be happy with a Hump
![]() Join Date: Dec 2004
W*n**r.!!!!!!!!!!!!!!!!!!
![]() ![]() 12.756 @ 107.16..........1.915 60' Genuine Unopened Time ![]() ![]() |
#10 | |||
#11 | |||
Solution Was Boost 4?, 6 & 8
Unless it was some else's Ute.
[SIGPIC][/SIGPIC]
AUTOTECH TUNED EDELEBROCK CHARGED 2017 GT Mustang Plenty of RWKW |
#12 | |||
#13 | |||
[SIGPIC][/SIGPIC]
#14 | |||
missing the panther
And to answer the other question the motor is staying unopened for a little while yet haven't seen the full potential of the motor yet....
#15 | ||
Giddy up.
That's right we are yet to see the Boss's FULL potential, the LS1 guy's had a few yr's up their sleves, so we are not to far behind in comparrison.
#16 | |||
Two > One
![]() There are definatly some good times ahead. The 260/290 boys are starting to peg back some of the 5yr head start the LS1 boys had, however a way to go yet. Makes for VERY intresting watching. Keep it up guys, on both sides of the fence.
#17 | |||
[SIGPIC][/SIGPIC]
#18 | |||
And didnt Rod run a 12.62 in his pursuit ages ago (pre edit etc)... got to be some more time in that!
'09 SYII TTG | Mystic '06 BF XR6 | Mercury Silver
#19 | ||
I didn't know LS1s ran 11.5s unopened? Are these common or are these once off purpose built drag commodores e.g. stripped to the bone?
~~~~~~~~~~~~~~ Rides (past and present) Current: 2004 Ford Falcon 5.4L 3v Barra 220, Manual Past: Mitsubishi Sigma (m), Toyota Seca (m), Toyota Seca SX (m), Toyota Vienta V6 (m), Toyota Soarer 4L v8 (a), BA XR8 ute (m), T3 TE50 (m), BMW Z4 (m) AFF motto - If contrary views trigger, please use ignore button. ![]() |
#20 | |||
Diff gears, hi-stall etc: can all be changed... They are a freak engine; there has been much development in the states with these engines, over in the states the unopened record is in the low 10's... The LS1 has earned its respect; we have some way to go with the Boss, to get where the LS1 is. The LS2 by all reports is even more potent.
[SIGPIC][/SIGPIC]
#21 | |||
RIP Craig - 13/11/08
![]() Join Date: Feb 2005
If a car changes valve springs that means it has been opened. IMO. Unopened means just bolt on enhancements eg: Throttle bodies, spacers, cold air, underdrives, zorst, etc. If a rocker cover comes off it has been OPENED. |
#22 | ||
beep beep
LS1's have 'weak' valve springs I think it was... so to maintain reliability it was deemed at some stage 'okay' to replace the valve springs because it doesn't go "into" the guts of the engine itself...
#23 | ||
Id like to see unopened include rockercovers, Trans, Diff and interior, most quick LS1's are stripped out virtual racecars.
335 S/C GT: The new KING of Australian made performance cars.. ![]() |
#24 | ||
To me valve springs changed = opened...
Yes it may not improive performance on its own but it allows more revs reliably which can enable more performance. To me its NO different to running a steel crank, H-beams and forged pistons, claiming that its for reliability only and running as unopened.
#25 | |||
missing the panther
This has become a big agrument with the Ls1 valve springs and have to agree that anything in a engine comes in contact with oil and is changed deems a opened engine. Geez we could turn around and change cams in the boss motors and say it's unopened as we just took the rocker cover off just like the ls1 boys..
#26 | ||
I agree with everyone about the valve springs its opened but under there LS1 rules they are not...
so what do we do.... . Why dont we just do the same, if your wanting to do it, just change them valve springs. if we are going to try compete at least we should have a level playing field to start. Just added a Poll to the top of this page, its open for 30 days. What do you think? change or no change give us your thoughts?
[SIGPIC][/SIGPIC]
AUTOTECH TUNED EDELEBROCK CHARGED 2017 GT Mustang Plenty of RWKW Last edited by SpoolMan; 28-09-2005 at 12:54 PM. |
#27 | ||
IMO valve springs is opened ...
#28 | ||
beep beep
Okay I figure level playing field is fine - replaced springs is either opened in both cases, or unopened in both.
However do the BOSS engines require spring replacements? For example the LS1s _NEED_ replacement, but do the boss engines need it to run a 13.0? or to run 12.5? or faster? Or is it a reliability thing. Personally I figure springs as it is definatively a reliability thing only as it does not affect power, but it allows for more power to be generated. I call it unopened.
#29 | |||
LS1 owner
:jab:
VX Berlina |
#30 | ||
chill boys
