Old 31-08-2005, 04:30 PM   #1
Stav
Smile
Stav's Avatar
Default Running the 1/4 what do you remove for weight reduction?
What do you remove from the car to run a 1/4 mile.?? Is there anything in the centre console?Does the jack come out...or spare tyre..or cargo barrier?
Old 31-08-2005, 04:32 PM   #2
EA2BA
PM me if you want
EA2BA's Avatar
If its not needed , remove it, every bit counts when chasing that .1 quicker, basically in a street car, its not really worth the effort.
Old 31-08-2005, 04:33 PM   #3
Casper
Contributing Member
Casper's Avatar
just the spare tyre and jack, everything else stays.
Older, wiser, poorer.
Old 31-08-2005, 04:36 PM   #4
RED_EL_XR8
RED_EL_XR8's Avatar
And the wife dont forget to remove the wife for runs.
RED_EL_XR8 is offline   Reply With Quote Multi-Quote with this Post
Old 31-08-2005, 04:36 PM   #5
stockstandard
spare tyre, jack, ~2kg in change from center console, sub + amp
oh and the hub caps
Edit: Also run about 1/4 tank of fuel
Originally Posted by casper
Old 31-08-2005, 04:39 PM   #6
Racecraft
they call me Tibbo
Racecraft's Avatar
I am alittle different to some that try and milk 1/10th from a street car. I leave everything in the car, stop at the nearest servo to the track and fill up and check all the tyre pressures. If you cancel out weight and tyre pressure variables everytime you race it is technique and weather conditions only. Cancel out as many variables as you can to see if any new mods or driving style, launch rpm etc make the car faster over the 1/4
Old 31-08-2005, 04:45 PM   #7
EA2BA
PM me if you want
EA2BA's Avatar
I look at it that whats the point of a 10sec time slip (if the car say runs 15s in street trim) if you have great big slicks and the car resembles a bare shell, bragging means nothing when a 120Y beats ya at the lights casue you are in full street trim.
Old 31-08-2005, 04:52 PM   #8
Casper
Contributing Member
Casper's Avatar
I agree however I think that the spare tyre and jack is accepted practice for most people. I've run with it both in and out of the car and the difference is usually less then .1 anyhow.
Old 31-08-2005, 04:54 PM   #9
EA2BA
PM me if you want
EA2BA's Avatar
yeah the removable things are fine, but when you have to undo bolts to remove things, i think thats going to far.
Old 31-08-2005, 04:56 PM   #10
neb
hibernating
neb's Avatar
I would usually just take the sub out (to pass scrutineering because it sits loose) and run on minimal fuel usually around quarter of a tank or at least less than half a tank. I did take my spare tyre out the first time I raced but havn't bothered since.
neb is offline   Reply With Quote Multi-Quote with this Post
Old 31-08-2005, 05:00 PM   #11
Racecraft
they call me Tibbo
Racecraft's Avatar
Yes I agree, that seems to be our experiences too, there is a poofteenth in it.. The reason I leave it all in is Willowbank is an hours drive for me, heaven forbid I get a blow out on the way and Willowbank doesn't have facilities for your excess parts to be locked up.. Unless you are going with a support car that can store your goodies for you while you are lining up, at Willowbank atleast you either leave it at home or just in an unattended pile in the pit carpark...
Old 31-08-2005, 05:05 PM   #12
Stav
Smile
Stav's Avatar
This is a good point.I have a cargo barrier,towbar,spare,jack centre console full of stuff,glove box full,car matts,stuff in the seat back pockets.
Would these really make a difference?...Also if I remove these does it really represent a true perfomance street car or just a 1 off drag situation.I would rather be able to run an optimal 1/4 every time not just once.
Old 31-08-2005, 05:06 PM   #13
Casper
Contributing Member
Casper's Avatar
If you have to unbolt it... then its part of the car and should stay in. Only exception is large sub boxes that may be bolted in but probably should be taken out for safety reasons.
Old 31-08-2005, 05:08 PM   #14
XA-Coupe
Absolutley nothing. I even race with the melways and change in the car.
Really, at the power levels we are talking, it's something to do to pass time before racing starts.
XA-Coupe is offline   Reply With Quote Multi-Quote with this Post
Old 31-08-2005, 05:09 PM   #15
EA2BA
PM me if you want
EA2BA's Avatar
Tow bar if you mean like the removable bit of the hayman reese then yes, they are quite heavy, sapre wheel and jack yeah you can, the cargo barrier will be a bit of weight, the rest of the stuff will not add up to much I am sure.
Old 31-08-2005, 05:10 PM   #16
Casper
Contributing Member
Casper's Avatar
Maybe in a V8 but in an auto I6 you can feel the weight of a spare wheel on the launch. Its noticable enough when you see the 60' time go from 2.3 to 2.4
Old 31-08-2005, 05:13 PM   #17
EA2BA
PM me if you want
EA2BA's Avatar
Just a quick question if I may.
Whats the average weight saving between a steel rim and an alloy rim.
Old 31-08-2005, 05:23 PM   #18
Stav
Smile
Stav's Avatar
What sort of differences will I see less all of the items I posted above?Is it great?
Old 31-08-2005, 05:24 PM   #19
Casper
Contributing Member
Casper's Avatar
.1, .2 at the most. It wil effect the launch mostly
Old 31-08-2005, 05:25 PM   #20
Stav
Smile
Stav's Avatar
Wouldnt the extra weight drag the cars speed down higher up though?
Old 31-08-2005, 05:27 PM   #21
EA2BA
PM me if you want
EA2BA's Avatar
Thats the whole point, not enough to really worry about, a new cam would give bigger gains then weight removal.
Old 31-08-2005, 05:57 PM   #22
eb six on boost
NO CARBON TAX
eb six on boost's Avatar
takeout whatever the angle grinder can cut! lol
i have run 11.65 with 50kgs taken from interior and 11.66 with full interior.
mph was 1 higher with extra weight.
dont bother taking anything out, just makes it all a big hassle.
THE WORLDS FASTEST BISCANYE BLUE EB FALCON WITH EB BLOCK AND HEAD!!! NO AU **** THANKS
Atomic performance engine, powerglide, coan converter, gtx55 turbo, 2000hp plazmaman water to air, 100mm throttle body, twin 50mm gates, side exit exhausts, 18 x 2200cc injectors, ems 8860 and race dash.......
7.83 @ 177 MPH
1100+ rwhp @ 40psi
the first 7 second sohc ! eat it
1993 eb falcon 15.4 @ 90mph (tow car)
eb six on boost is offline   Reply With Quote Multi-Quote with this Post
Old 31-08-2005, 06:03 PM   #23
xr8ute
Back on the road
xr8ute's Avatar
As the guys have already said above, spare wheel and jack.
It goes without saying that any other loose items in the car should be removed, but mainly for safety reasons. You don't want to hit the wall after an axle snaps, then have a 15kg toolbox come flying at you from the back of the car....
All up, you'll probably take out 30-40kg max which is probably worth 1 tenth. Race weight for an AU I6 wagon would be 1800kg+ (?)
Old 31-08-2005, 06:04 PM   #24
dansedgli
dansedgli's Avatar
Yeah I leave everything in. All the times I have run my cars everything is in there including the spare, melways etc.
If you want to go as fast as you can then strip it all.
Its all a case of if you can be bothered or not.
Turbo AU ute ~ Nice legs, shame about the face. 282rwkw at 15psi.
dansedgli is offline   Reply With Quote Multi-Quote with this Post
Old 31-08-2005, 06:05 PM   #25
jabba
jabba's Avatar
You can lighten the car 80 kilo's by removing the driver
Built by HERROD MOTORSPORT
Tuned by Elite Automotive
11.91 @ 117mph Vid
jabba is offline   Reply With Quote Multi-Quote with this Post
Old 31-08-2005, 06:08 PM   #26
Stav
Smile
Stav's Avatar
Hhaha cut the maccas!! I think I will leave the lot in the car for my run hopefully in October. It will be funny.
Old 31-08-2005, 07:11 PM   #27
Stav
Smile
Stav's Avatar
I may as well get it out of my system once and for all and see if I will manage a 16 or better 1/4 mile.!!!
Old 31-08-2005, 08:34 PM   #28
jonbays
TL40 Wagon?
exactly lose your own spare tyre first then worry about the cars spare.
I run it as it is just anything that is loose and could hurt in an accident is removed thats all.
Old 31-08-2005, 08:39 PM   #29
RED_EL_XR8
RED_EL_XR8's Avatar
I hope your not insinuating that Stav is carrying anything but a perfectly formed racing figure.
Old 31-08-2005, 08:42 PM   #30
Casper
Contributing Member
Casper's Avatar
Like Steven Johnson? _
