#1 | ||||
it's probably been done before, but it seems to be a passionate subject to most of us. So I created this thread to stop poluting another thread http://www.fordforums.com.au/showthr...7&page=2&pp=25
I have used LPG, I have a fitters licence and have had something to do with it for the past 15 years. My feelings are mixed though, from what I have seen a well maintained LPG engine for the average user will last as long as a petrol engine, but most don't get the correct servicing & end up with oil leaks, mechanical noise & excess emissions. Quote:
LPG > You
As I've stated many times, LPG all the way. It's a hell of alot cheaper then petrol (118.9 cpl regular, 127.9cpl premium, 38.9cpl LPG), and IMO, a much better fuel.
LPG Lovers Association President & Member #1. ![]() ![]() |
i know LPG isnt 100% propane , i think its got a mix of Butane? But it's a lot more than 5% more in consumption, burns hotter, smells aweful, isnt much cheaper than petrol when you remove the big tax component from both and take in to consideration its 25% increase in consumption, non lubricating for the engine, and despite all the theories in the world, less power is usually achieved in reality. So i cant see a lot of advantage to it, other than its taxed a lot less at the moment
LPG > You
![]() I'll also post this up from that other thread.
Last warning
lol @ when you remove the big tax component, when is that going to happen.
given excise on LPG will still have LPG costing around 1/2 what ULP does.. and when u consider its currently almost 1/3 the cost of ULP.. LPG rocks.
FALCN6 - Turbo, Air Bag Suspension - Hibernating EL GT - Supercharged NASCAR - 83 Thunderbird , Bagged DAILY - BA Fairlane Ghia, Boss 260 Turbo OFFROADER - Ford Explorer ![]() |
#6 | |||
LPG > You
And petrol fumes are alot worse to smell then LPG fumes... petrol fumes give me a headache... LPG fumes just stink like rotten egg, but no associated issues from smelling them. They're far less toxic.
X-Series Club Moderator
Cost effectiveness of LPG is the number 1 argument for LPG, not matter which way you look at it. $0.50 vs $1.30 is an amazing difference, and even with the so called 28% difference as stated above, it's still a cost effective fuel compared to petrol!
I think the biggest problem with LPG that gives it a bad name is people run dual fuel and leave their engine setup for petrol.... obviously you litres consumption for every 100km's and power output will be better on petrol in this situation. If instead you change your setup for LPG, economy and performance figures will tell a very different story. The other point I'd like to make is LPG will be around for the same length of time as Petrol, and is likely to always be cheaper! Plus LPG produces less emmisions and is therefore given exemptions to restrictions on certain laws to govern emmisions released into the environment. The point above about oil and LPG causing it to go acidic is a crucial point, and some oils don't even tolerate this well and will breakdown VERY quickly. regular maintenance with special attention to oil and ignition system is crucial to a good LPG powered vehicle. I don't think I could ever drive a petrol powered car, simply on the basis of cost! that's my 2c ![]()
PROJECT - '77 XC Falcon 351C - Click Here DAILY - '05 Ford Territory BIKE - '12 Suzuki GS 500 |
I use LPG...... on LPG 20 bucks for 2 days..... on petrol 60 bucks for 2 days
#9 | |||
LPG > You
http://www.caltex.com.au/products_oil_detail.asp?id=316 Plus don't forget the higher octane rating for LPG, making it able to utilise higher compression and higher boost without knock. That's a great thing in a performance orientated engine. I'm still of the opinion that LPG is going to become the next big thing in Australia, until we all move to hydrogen fuel cell cars...
#10 | |||
![]() Join Date: Dec 2004
#11 | |||
LPG > You
#12 | |||
1965 XP Falcon Deluxe Sedan 1978 XC Falcon Wagon Rallypack 2003 BA Fairlane G220 Windsor Powah!!! http://www.youtube.com/watch?v=m7hT9dxD2hM |
Last warning
how many people out there are running aftermarket ECU's and thus are getting perfect AFR's on Petrol? not many, therefore they're getting $hitful AFR's and the theoretical 'difference' doens't apply.
LPG consumption is closer then 20% due to the AFR's being far closer then that of a factory ULP car. sure, if you have an aftermarket ECU then your petrol consumption will be better, but your LPG performance will be better too (ignition curves)
#14 | |||
#15 | |||
LPG > You
#16 | |||
Grinder+Welder = Race car
"No, it will never have enough power until I can spin the wheels at the end of the straightaway in high gear" - Too much power is never enough....Mark Donohue on the Can Am Porsche 917. |
#17 | |||
#18 | ||
Both of my cars are LPG, one dedicated and one duel fuel.
Yes, LPG requires a bit more care, but the price difference on a weekly basis ($26 versus $78 per tank of gas) more than makes up for the cost of higher grade oil when changing, or higher spec spark plugs, etc. LPG is a non-imported product, is less polluting than petrol, and allows me to spend more money on goods and services which benefit the domestic economy. If you've never run a car on gas, then you're not qualified to comment. |
#19 | ||
I only spend about $30 a week so it isnt too expensive. Of course i wouldnt mind the price to come down but at the moment it isnt a turning point to go to LPG.
#20 | |||
#21 | ||||
I stated that changing your setup to suit LPG is necessary to achieve realistically comparable performance and economy figures, if I was to elaborate I would say what you said.... plus a recurved dizzy or aftermarket ECU. The only thing I don't agree on is LPG becoming big in Australia. It won't happen because so many people believe the myths that surround the fuel. Quote:
A petrol powered car simply can't compete with a well setup LPG car with todays prices!!! :voldar02:
#22 | ||
likes falcon's
as a student on virtually no income gas is the answer for me
www.carhubsales.com.au |
#23 | ||
RED EL, I don't understand what you're trying to criticise.
My so-called "scientific claims" are baed on primary school mathematics: 65l x $1.20 = $78 65l x $0.40 = $26 I'm not pulling crap out about reduced air flow, blah, blah. Yes, the car does use gas more than petrol, I'm not disputing that. But at 1/3 the cost of petrol...even a primary school kid can see the difference |
#24 | |||
Most fleet managers have done a lot more sums than the high school math you quote. |
#25 | |||
#26 | ||
One thing I forgot to mention, and everyone else seem oblivious to is;
LPG puts extra stress on the cooling system & auto transmissions. Most auto's use coolers inside the radiator tank, so higher cooling system stress cause higher transmission stress, on top of this the engine produces less power, so more throttle is required which increases transmission stress & heat which is dumped into the radiator cooler, and round it goes again. And what about that exhaust temperature, what is that doing to catalytic converters & oxygen sensors? |
#27 | |||
If you are arguing against the conversion of an existing car to LPG, there are a number of valid points against doing so. No of cylinders of car, no of kms driven and in what conditions, etc, etc. If in my case, I had the choice between spending money on a car only on petrol, and on the same model car with LPG. It was a no brainer. LPG wins hands down. Do I drive my duel fuel car on petrol because of theoretical efficiency advantages and x kw difference at the wheel? NO |
#28 | ||
Formerly Black EX-R6
Ok, will those on the con side of this debate actually start posting some hard information that has actually been researched beyond heresay and questionable personal experience?
I had performed about an hour or so searching on google to try and find articles on lpg and could not find one credable site that proclaimed LPG was bad for your engine or pocket. Plenty though said the opposite.
""It's not the ideal way to win, but we got here, so yeah baby," said Kelly." Stinking, mongrel, dog. |
#29 | |||
#30 | |||
LPG is fine in engines optimised to run LPG though the economy arguements still hold true. Duel fuel and its budget & backyard conversions on petrolium engines, I'll leave that to those more desperate.... |
