Old 06-08-2005, 08:00 PM   #1
Budman
Default LPG too?
Does Jim Mock Motorsport do LPG tuning as good as petrol?
I have been looking around and I am very impressed, I have the engine described in my tag and I want to know if Jim Mock is the way to go for a tune and a bit of work.
Havent seen any mention of LPG anywhere so I thought I should ask.
Old 24-08-2005, 10:11 AM   #2
Mechan1k
Mechan1k's Avatar
I am after a cam for my AUII EGAS motor in my ute ... i need more power/torque for work usage.
Old 24-08-2005, 10:25 AM   #3
Steffo
LPG > You
Steffo's Avatar
I emailed them a while ago about fitting a DEV4 kit to the AUIII Forte LPG we used to have, and got an email back from Jim, saying they do LPG work, and that the DEV kits work fine with the LPG motors.
Old 26-08-2005, 12:24 AM   #4
NC_Steve
She needs premium dude...
NC_Steve's Avatar
I asked this question on here a while ago with regards to a DEV 5 set up and on LPG you can expect around 150rwkw where as on petrol about 170rwkw. Simply due to the gas mixer restriction.
NC_Steve is offline   Reply With Quote Multi-Quote with this Post
Old 27-08-2005, 01:21 PM   #5
Brenden
"THE" Workshop manager.
Brenden's Avatar
Gas systems are tricky at times....
Depending on the gas system and its components depends on how well it can be tuned.
Some fully electronically controlled gas systems can't be tuned at all but with some mods the correct gas mixtures can be reached for good power.
Yes we can tune most gas systems.
True Gas engines, ie AU gas, are a tricky setup also and are actually quite powerful from factory, however adding a good exhaust and a cam will still improve power, but expect nothing close to the kits true power value. Due to gas mixer sizes acting as a BIG restriction.
Jim Mock Motorsport
AME Albury carshow Horsepower Hero 2005
AME Adelaide carshow Horsepower Hero 2005
AME Shepparton carshow Horsepower Hero 2005
AME Melbourne Highest horsepower 6 turbo 2005
AME Melbourne Highest horsepower N/A 6 2005
All Ford nationals DYO 10.5 and over champion 2005
Brenden is offline   Reply With Quote Multi-Quote with this Post
Old 17-09-2005, 10:56 AM   #6
Mechan1k
Mechan1k's Avatar
So for what I am after .... I might be better off going for a low-boost S/C setup then.
Old 17-09-2005, 04:41 PM   #7
romaniac
holla at cha boy
romaniac's Avatar
yeh i rang them up last week regarding this. I was thinking of getting the dev3 kit. However its probly not worthwhile on gas. Might just get exhaust and intake mods instead.
romaniac is offline   Reply With Quote Multi-Quote with this Post
Old 11-10-2005, 10:55 PM   #8
AUFairmont
HSV, I just ate one
i have a petrol motor in my AU2 fairmont but had it gas converted, im wanted a DEV5 kit.
from what iv read ill get aprox 155rwkw from it on gas but when i flick over should it be like normal and get closer to 175rwkws ? like maybe 170 or higher ?
AUFairmont is offline   Reply With Quote Multi-Quote with this Post
Old 12-10-2005, 09:01 PM   #9
Brenden
Brenden's Avatar
No incorrect,
With the gas systems the restriction is in the intake with the gas mixer. A typical gas mixer has a hole about 2" round which would definately restrict things a bit.
The power will be restricted on both petrol and gas, with most of the time petrol producing upto 150 rwkw and gas sometimes upto 140wkw.
Jim Mock Motorsport
Old 20-10-2005, 09:29 AM   #10
GRN-WGN
GRN-WGN's Avatar
brendan, is that sort of loss through the mixer as bad with a gas research setup with the throttle body n stuff. have u ever done a car with gas research and how did it go?
.:EA wagon:. - custom green respray, superlows, tint, 18'' chromies, extractors, 2.5'' zorst, white el trims and roof, 2500wrms sound system, in dash screen, ps2. :coming soon:... sunroof, shift kit, white leather retrim.
GRN-WGN is offline   Reply With Quote Multi-Quote with this Post
Old 28-10-2005, 11:01 PM   #11
AUFairmont
HSV, I just ate one
A dev5 kit, only producing 140rwkw's even when running petrol ? are you kidding ?
why dont they make a larger gas mixer ?
Old 31-10-2005, 08:42 PM   #12
dsjoyce
Just out of interest, what sort of power would an EF make with a DEV 3, or DEV 3HL on lpg/petrol? Is the power output only limited when running on lpg or does petrol also see reduced kilowattage?
dsjoyce is offline   Reply With Quote Multi-Quote with this Post
Old 31-10-2005, 11:01 PM   #13
5speedeb
now with 3.73 lsd
a good tuned dev 3hl auto should make 140-145kw on petrol
u may have a less power becasue of the intake
5speedeb is offline   Reply With Quote Multi-Quote with this Post
Old 31-10-2005, 11:16 PM   #14
NC 5ltr
NC 5ltr's Avatar
out of interest are these figures that are being posted duel fuel setups or straight gas
QUOTE I hope your opinion of the rear end of the VE improves because you are going to be seeing a lot of it.QUOTE
QUOTE What makes you think I'm going to park behind a VE? I don't even attend the Sydney Gay Mardi Gras! QUOTE
NC 5ltr is offline   Reply With Quote Multi-Quote with this Post
