Old 21-07-2005, 09:55 PM   #1
EB6
apprentice grease monkey
EB6's Avatar
Default Head gaskets
Hows it goin people.
I'v got an EB 6 with cam, head work, exhaust, chip and bbm manifold, problem being ive just blown the head gasket with some thanks to some debrit going through the engine. Anyway ive got everything all good to go back together but i am considering one of your steel head gaskets but there are 2 things i would like to know firstly about them. One is do they resist 'blowing' more than a conventional gasket and secondly are they thinner causing a raise in compression.
Also are the spark plugs you offer colder than standard ones i have had trouble with them fouling up on my car.
Any help would be great.
Nick B.
EB6 is offline   Reply With Quote Multi-Quote with this Post
Old 27-07-2005, 08:21 PM   #2
Brenden
"THE" Workshop manager.
Brenden's Avatar
Hi,
The head gaskets in the 4 litre don't typically blow out, they simply break down into mush when the engine heats up and cools down. The temp varienced cause the heads to grow longer and shorter, the gasket rubs against itself and simply breaks down. The tripple plate steel gaskets slide against themselves and resist breakdown.
Quite simply it is a 90% bullet proof system of stopping leaks.
The gasket thickness is .025" compared to most which are .060" this raises the compression about .3 in most cases...ie 9.35 to 9.65.
The plugs will foul if cam is to big and idle is rich. Can also be caused by excessive fuel pressure or poor condition ecu. Sometimes Shell Optimax has a bad habbit of fouling plugs, even in old 302 windsors.
Jim Mock Motorsport
AME Albury carshow Horsepower Hero 2005
AME Adelaide carshow Horsepower Hero 2005
AME Shepparton carshow Horsepower Hero 2005
AME Melbourne Highest horsepower 6 turbo 2005
AME Melbourne Highest horsepower N/A 6 2005
All Ford nationals DYO 10.5 and over champion 2005
Brenden is offline   Reply With Quote Multi-Quote with this Post
Old 17-08-2005, 10:14 PM   #3
proengines
Are these gaskets different to the factory Ford AU MLS gasket?
proengines is offline   Reply With Quote Multi-Quote with this Post
Old 18-08-2005, 08:40 AM   #4
Sox
RIP...
Sox's Avatar
Same gasket.
Rick.
Oval Everywhere...
Old 18-08-2005, 11:11 PM   #5
Spider_GT
Prince Of Darkness
Spider_GT's Avatar
exactly the same
Engine;
351 Crank, 302 Rods, Custom Pistons, Blue Print & Balanced Bottom End, Crower Stage 5 Cam (Cam Specs), , CHI 3V Heads. ENGINE PIC HERE
Body:
XD Fairmont Ghia
Spider_GT is offline   Reply With Quote Multi-Quote with this Post
