Has anyone seen the new Jeep ad? Its the new Cherokee with a HEMI V8 that produces 240kw. It also has a feature that deactivates 4 cylinders to save on fuel consumption when they arent needed.
I thought it was pretty cool. Maybe this sort of technology could be incorporated into cars. Definately could be a promising technology to develop into sedans. Flog it like an 8 when you want to and cruise on 4cyls and save petrol. |
i dont know why they(all car companies) havent done that earlier?!! Great Idea!
How well does it work i wonder? |
It's called DOD (Displacement on Demand) - I thought this was going to be a feature on the LS2?
1966 Ford Mustang coupe. 347 stroker, PA reverse manual C4, TCE high stall converter, B&M Pro Ratchet, Edelbrock alum heads, Edelbrock intake manifold, MSD ignition, Holley Street HP 750 CFM carb, gilmer drive, wrapped Hooker Super Comp Headers, dual 3" straight through exhaust, Bilstein shocks, custom springs, full poly suspension, American Racing rims, Open Tracker roller spring saddles and shelby drop. Still to go - Holley Sniper EFI with integrated fuel cell. |
I heard that it only save something like 5% fuel and its hardly worth the extra cost and more things that can break.
The one and only
Wouldn't the 'DOD' be EFI controled therefore nothing extra to brake?
I don't see why all cars don't have it. 5% add's up over the year!
1992 DC LTDHO 360rwkw built by me Tuned by CVE Performance Going of the rails on a crazy train Other cars include Dynamic ED Sprint, Dynamic DL LTD, Sparkling Burgundy DL LTD, Yellow, Red & Blue XB sedan & Black XB Coupe
Jeep claim a 20% saving on fuel economy. Thats whats on their website.
Tricolore Tard
![]() Join Date: Dec 2004
The 300C does the same thing as well AFAIK from one of the Top Gear episodes.
Chris
iRegular crossmember
i saw that earlier on the year on howstuffworks.com except it could do 360 turns on the spot, because all the wheels turned, it also looked cooler i think it was a prototype but, it had that piston cutoff feature aswell
1996 EF XR6 5 spd manual 2 1/2" manta S/S exhaust After market alpine/soundstream stereo 18" tyhpoons superlows waiting to go in.... spoilerless ![]() |
Greys tuf too :-)
Its been available on Jags for a few years now. I dont know what figures they quote for efficiency tho.
8% or 20% wonder which is closer to the truth?
There would be a lot of friction/drag to overcome; piston rings, bearings, camshafts. Wonder if it would work on the Barra I6? |
#12 | |||
Detroit Locker Equiped TM
Just wait till you see the S-RT 8 version, complete with 415 hp of 6.1 litre HEMI (tm)!
Apollo Blue 1974 XB Falcon GT, 557 HP Blue Pearl 2004 BA FPV GT, 290 kW Quote:
http://www.facebook.com/FalconGTClubGeelong |
#13 | |||
beep beep
eg: rotation 1, fire cylinders 1-8-2-5: rotation 2, fire cylinders 3-7-4-6 What they would also have to do to maintain lubration is to feed a small amount of fuel (tiny bit) into the cylinder for lubrication on the shutdown cycle vs a full load on the firing cycle. Someone has to have read something about this DoD to tell me if this is how they are doing it...
Nothing to see here, move along, move along... |
#14 | |||
Ahh .. 5.7L Hemi in my '70 Fury convertible .. sweet!! ![]() |
#15 | ||
I believe the lifters shut down deactivating the valves.
Nice motor, i'm not really keen on shutting down valves. I don't think it's the smartest way to get power and economy. why don't they just run turbo diesels?? Cummins 5.9T hauls ****. Power and economy |
#16 | ||
PM me if you want
how do you shut down lifters ? <--- umm impossible trick if you ask me
stoping injectors would be a piece if cake, and no fuel in, means fuel saved.
#17 | ||
The one and only
by just shutting of injector would make it very lean and the oxygen wil still combust, unless the spark is switched off but there will still be compression.
The valves are controlable and I believe they are a left open a little during combustion stroke so the engine will bypass the cylinder, hence fuel efficiancy.
#18 | |||
PM me if you want
#19 | ||
The one and only
ha ha
You will find that #6 is still getting fuel! Also when you accelerate the Hemi would engage all cylinders, your car probably isn't!
#20 | ||
PM me if you want
hehehehehe
its actually #2 and umm yeah its in permanent economy mode ![]()
#21 | ||
Nothing's impossible.
http://www.allpar.com/mopar/new-mopar-hemi.html In V8 mode that's lot of power for a production car! It must be a real power drain draging 4 cylinders! Last edited by XB_fairmont; 12-07-2005 at 07:06 PM. |
#22 | ||
Peter Car
It has lifters that can be electronically shut down so the valves don't open.
#23 | |||
LPG > You
LPG Lovers Association President & Member #1. ![]() ![]() |
