Old 20-06-2005, 10:14 AM   #1
lewstung
Default Premium Sound - anybody else get this?
Hi, I have noticed a weird thing in the stereo in my fairmont, it has the premium sound stuff (6 disc stacker blah blah)...I usually listen to hiphop in there and for some reason the first 'hit' in the song, like the bass drum or whatever, is really loud and thumps, and then the rest of it goes normal...any idea why it would do this? Anybody else get this with theirs? it's weird, and scares the sh*t outta you if you're not ready
lewstung is offline   Reply With Quote Multi-Quote with this Post
Old 20-06-2005, 10:19 AM   #2
MrQuan
Social Disaster
MrQuan's Avatar
The first problem is you're playing hip-hop (that's a chargeable offence kiddo).
Apart from that, is the sudden hit like a "pop" sound when you first turn on the stereo? or does it happen at the start of each track?
Also, is it all factory sound?
1995 EF Falcon GLi, Auto, 4.0L I6
Mods:
3.73 LSD | Darkest legal tint | tinted back lights | Sprayed Dash | Custom Trims
Sound System:
Fusion front splits, rear 3-ways, and 2 x 12" subs with ctrl, 3 x Fusion amps | Clarion HU | 1F Cap | 60GB Zen Xtra | 800W RMS output!
MrQuan is offline   Reply With Quote Multi-Quote with this Post
Old 20-06-2005, 11:51 AM   #3
lewstung
well lets not get into the music, that's your opinion! but yea it's all factory sound, and the first hit is at the start of each track...any idea why it would do that?
Old 20-06-2005, 03:02 PM   #4
Dauphin
Irregular member
Dauphin's Avatar
Maybe is it's a burnt CD, it has bad "rips" or something from the original CD. Some burning software / driver / hardware combinations can produce pops and sounds like you describe at the start of tracks.
Old 20-06-2005, 04:44 PM   #5
lewstung
Nah this is on regular CD's... and only the very first beat is real loud, then it's like it adjusts itself and plays normally...
instead of boom, bap, boom, bap...
it's like BOOM bap, boom bap etc
Old 20-06-2005, 04:55 PM   #6
Dauphin
Irregular member
Dauphin's Avatar
Ahh right.. well at least its not going boom BAP boom bap. Then you'd be in a pickle.
Old 20-06-2005, 05:31 PM   #7
Axle-F
AU - YEA YOU!
Axle-F's Avatar
lol!!
AU II XR6 VCT - JMM DEV3+
Axle-F is offline   Reply With Quote Multi-Quote with this Post
Old 20-06-2005, 09:57 PM   #8
richo77
richo77's Avatar
might be your power limiter kicking in??
richo77 is offline   Reply With Quote Multi-Quote with this Post
Old 20-06-2005, 10:01 PM   #9
sfr rob
sfr rob's Avatar
touch it
Old 20-06-2005, 10:09 PM   #10
Laminge
Cuban... nothing like it
Sounds a like a problem with your amp maybe, or a bad earth on the system.
Have a look at the amp and play with the wires and connections
Originally Posted by Laminge
...its amazing how mud sticks to ones shoes, as flies do to the elderly and bottle blondes around fame and fortune...
Laminge is offline   Reply With Quote Multi-Quote with this Post
Old 20-06-2005, 10:19 PM   #11
Sylox
Uterus M.I.A.
Sylox's Avatar
Press the Audio button a few times and you'll find bass/treble/fader/balance and SLA I think it is. Its an on/off option turn that off and it wont do it anymore.
Hope that helps
Sylox is offline   Reply With Quote Multi-Quote with this Post
Old 21-06-2005, 10:03 AM   #12
lewstung
hopefully that works, thanks for the help!
Old 22-06-2005, 08:10 PM   #13
chief
FTF Club Moderator
chief's Avatar
I beleive it is a safety measure from the headdeck noticing that the speakers can not go that loud or that deep and override the volume to prevent you blowing your speakers.
Old 24-06-2005, 02:30 PM   #14
Axle-F
AU - YEA YOU!
Axle-F's Avatar
In my novice opinion that's what i think is happening as well. I have the std CD player in my falcon and it does the same thing....scared the crap outta me at full volume this morning (then dropped down) but hey now you know its not just the premium sound doing it :yeees:
Old 26-06-2005, 01:35 PM   #15
kiwi
Mode button above volume, keep pressing until compression comes up (CPn) turn it off. This is to level out the cd volume so the quiet bits are played louder and the loud bits get turned down. So you hear everything when its not playing loud basically.
kiwi is offline   Reply With Quote Multi-Quote with this Post
Old 28-06-2005, 03:15 PM   #16
lewstung
It doesn't have a CPn option unfortunately. If you skip through in Mode past bass, treb etc, the last option is 'loud'. I turned this off to see if that was the prob but it's not, turning it off just made it sound p*ssweak.
Old 28-06-2005, 04:21 PM   #17
kiwi
Default Compression thing / CPn
Mines a Dec 2001 AUII, dont know if that makes a difference. Thats definately how it works on mine, found it in the manual, I wondered the same thing when I got it. Do you have an earlier model that has it as a factory setting, that can't be adjusted. I'm only assuming this though. Good luck sorting it.
PS the way I typed CPn in the above post is how it comes up on the LCD display for anyone else. (capital,capital,lower case)
Old 28-06-2005, 04:23 PM   #18
kiwi
The loud button basically gives your sound more balls/bottom end. (Very brief description) You would have noticed that quite a bit already seems you listen to hip hop.
Old 25-07-2005, 07:50 PM   #19
Demonio
Dropkick
Demonio's Avatar
I think it is the Power Limiting feature. simply go thru the menu until you see PL ON and turn it PL off. that should fix ya problem
Demonio is offline   Reply With Quote Multi-Quote with this Post
