Old 29-08-2007, 01:18 PM   #1
fernsantos
Default Globes for power window switches AUII Fairmont Ghia
Some of my power window switches do not light up.I have taken the switch out and there is a globe inside.Ford do not sell the globe you have to buy the whole switch.Is there a way of fixing this problem with out buying the whole switch.Thanks for your help
fernsantos is offline   Reply With Quote Multi-Quote with this Post
Old 30-08-2007, 03:20 PM   #2
No Judge
That's Numberwang!!!
No Judge's Avatar
Heyhey fernsantos,
I had that same problem in my AUII Ghia.
I couldn't find anywhere (AutObarn, SuperCheap, Dick Smith etc) that stocks the little LEDs by themselves. I asked Ford and they wanted $200 for the whole power window switch replacement (ie, all 4 switches as a unit)
So, off to the wreckers I went. And $5 later I owned a replacement switch (all 4 switches). That is my advice, to go to a wreckers. I knew Ford were a rip on replacement parts, but sheesh!!
The only problem I have is that in the high series (like the one you have), the LEDs are white, whereas the 'lower' series have a more yellow-ish LED. So, I swapped one from the back door to the front, and the back door now has a more yellow-ish one.
Hope it helps
www.aufalcon.com.au/only1
FAIRMONT GHIA: SO GOOD, THEY NAMED THEY NEW FALCON AFTER 'EM
Originally Posted by xr6 ausome
Nah the roads to high, your car can never be to low lol
No Judge is offline   Reply With Quote Multi-Quote with this Post
Old 30-08-2007, 06:05 PM   #3
Riksta
Captain Malcolm Reynolds
Riksta's Avatar
The lower series switches are meant to light up?
My Forte doesn't, I just assumed it was built without a light in them.
Currently: 2014 Mazda6 GT (Daily) and 1999 Mazda MX5 (Fun Car)
Previously: 2001 Ford Escape XLT; 2010 MC Mondeo; 1984 FD LTD; 2001 AU2 Falcon Forte; 2005 LS Focus Zetec; 1988 RE Colt; 1982 RB Colt; 1974 KE20 Corolla
Originally Posted by Nikked
Riksta likes VN's so much, he has the ashes of a VN in a jar on the mantle piece, a vile of VN engine oil hanging from his neck and a BT1 build plate locked up in a safe, buried under 6ft of concrete.
Originally Posted by Day-mow
pretty much what has happened here is i trolled you. and it was fun.
Riksta is offline   Reply With Quote Multi-Quote with this Post
Old 30-08-2007, 06:19 PM   #4
mattp
mattp's Avatar
Chuck LEDs in there, there's a tutorial on here somewhere, check the results out in my build thread if you're interested. I put blue LEDs in mine, look a million bucks compared to the normal bulbs, and it's easy to do. Plus, they theoretically should never blow again while you have the car, LEDs last for ages.
Matt.
mattp is offline   Reply With Quote Multi-Quote with this Post
Old 29-12-2011, 06:15 PM   #5
Shen Long
Default Re: Globes for power window switches AUII Fairmont Ghia
which LED's do you need to buy to replace the current globes on the power window switches?
Shen Long is offline   Reply With Quote Multi-Quote with this Post
Old 01-01-2012, 03:13 PM   #6
AU1XLS
AU1XLS's Avatar
Get some of these, not LED's but no soldering,resistors etc to worry about
http://www.ebay.com.au/itm/Grain-Whe...item4160dec5a0
AU1XLS is offline   Reply With Quote Multi-Quote with this Post
Old 01-01-2012, 04:18 PM   #7
Dezza
Parts bin special
Dezza's Avatar
If not LEDs, you should be able to get some globes from an electronic shop like Jaycar. You'd just need the ones with the long legs so you can twist it around the holder and trim where necessary. This is what I did for my blown dash lights, and they basically use the same style setup, just bigger.
Old 02-01-2012, 01:57 PM   #8
_Ben
_Ben's Avatar
Question - I have an AUII Futura, and my switches don't have LEDs in them - do they just not have a bulb, or are the missing the whole set up as it is a lower model?
_Ben is offline   Reply With Quote Multi-Quote with this Post
Old 03-01-2012, 02:25 AM   #9
Dezza
Parts bin special
Dezza's Avatar
Pretty sure only models with power windows all round got the illuminated switches. Models with fronts only don't get them. Not sure if you can fit bulbs afterwards or not though sorry.
Old 03-01-2012, 10:51 AM   #10
rowan194
I wonder if those are intended for automotive use? With the engine running the main supply voltage could exceed 14V, which is a fair percentage above the globe's rating of 12V.
Typically a globe which is overdriven will suffer premature death, and given that these are cheap globes from ebay they may not have such a long life anyway.
Just something to consider, since it's such a pain to replace those globes.
rowan194 is offline   Reply With Quote Multi-Quote with this Post
Old 03-01-2012, 11:45 AM   #11
my67xr
my67xr's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: This contribution: 04 SX TX AWD, drama's replacing upper outer joints w/Nolathane replacements
Matt.
here it is-
http://www.fordforums.com.au/vbporta...article&id=203
Money Talks, but all i ever hear is it saying Goodbye!!
click below to view my build threads
67 XR Fairmont
04 SX TX Territory AWD
my67xr is offline   Reply With Quote Multi-Quote with this Post
