Prev Previous Post   Next Post Next
Old 10-02-2025, 12:21 PM   #1
73mick
Default TPS/ETC problems XR6 Turbo Ute
Hi Guys
New to the site.
I was recently acquired 2005 Bf XR6 Turbo ute. It hadnt been driven for a long period of time.
I serviced to car, plugs, leads etc etc. but noticed the car was using a lot of fuel and idling at a higher rpm then normal. The etc light came on a couple times after stopping the car and re starting it just to get me home. I attempted to drive the car the next day but the car once started it sent rpm's over 3rpm and came back to just 1rpm and was running like a bastard and almost stalled. I also noticed that I only had half an accelerator pedal.
After plugging ODB11 scanner on it found the STP/ETC the problem. Cleared codes.
I pulled the intake manifold off to get to the ETC, (found that the rubber joiner had perished, which I have since brought a new one and replaced). found that ETC was I need of a clean. Pulled it off to clean and also the TPS but snapped one of the screws. Brought a recon ETC/TPS from a ford dealer. In stalled the new one.
But when I started the car after installing it the car did exactly the same thing as before I changed. There is no codes coming up on the OB11 scanner.
Looking for advice help.
Michael.
73mick is offline   Reply With Quote Multi-Quote with this Post
